Author Topic: GroovyMame/Command Prompt Opening Before Game  (Read 2062 times)
billy75
  • Last login:December 01, 2017, 12:34:27 pm
« on: December 01, 2017, 11:55:53 am »
Hello all. First time using GroovyMame, which has worked without issue (thank you, Calamity). One question. I'm using GroovyMame v0.190 along with Hyperspin 1.4.0.0 and a command prompt always opens before a game starts, which I suspect is SwitchRes. I would like the command prompt to be hidden and not popup before starting a game. I have skip_gameinfo 1 in my mame.ini, but obviously this has nothing to do in hiding the command prompt. I found this thread (https://forum.arcadecontrols.com/index.php?topic=149404.0), but it's in regards to using GroovyMame with Mala, and not Hyperspin. Any ideas, or some guidance to a thread that may assist with this? Thanks all.
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
Re: GroovyMame/Command Prompt Opening Before Game
« Reply #1 on: December 01, 2017, 03:01:11 pm »
Ask / look on a HS forum. Not a GM issue. Maybe have look in the HS settings for window options, it's a simple enough drop down menu in my FE but HS is a completely different beast.
