Author Topic: Hide the SwitchRes command prompt when starting a rom  (Read 4058 times)
arcadeswede
  • Last login:February 15, 2025, 10:03:44 am
    • Revansch!
« on: February 01, 2016, 05:56:53 am »
Hi everyone!
As the titel says, I'm wondering if it's possible to hide or minimize the "SwitchRes found matching resolution"-command prompt that pop ups when starting a game.
I'm using the latest GroovyMame with Mala and to make it a little less "computer:ish" I was hoping to get rid of the command prompt window somehow.
Anyone have any pro tip?
//Victor
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
Re: Hide the SwitchRes command prompt when starting a rom
« Reply #1 on: February 01, 2016, 07:20:39 am »
You mean the screen that shows the resolution?
If so, just set skip_gameinfo in the ini to 1 and disable_nagscreen_patch to 0.
arcadeswede
    • Revansch!
« Reply #2 on: February 01, 2016, 07:26:06 am »
No, no, no. That I know.
The command prompt window from SwitchRes that pop ups just right after you've picked a game in your front end. Maybe other front ends are always on top but Mala isn't?
Foxhole
« Reply #3 on: February 01, 2016, 09:48:31 am »
Probably, because i'm not seeing that with hyperspin.
Foxhole
« Reply #4 on: February 01, 2016, 09:52:48 am »
Try this and let me know if that helps.
Create a shortcut for the mame64.exe, go to properties of the shortcut, set "Run" to "Minimized".
Of course in mala point the program to the shortcut and not the exe.
There's probably a better way to achieve this, though.
« Last Edit: February 01, 2016, 10:01:49 am by Foxhole »
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #5 on: February 01, 2016, 10:15:35 am »
In MaLa options, go to MAME Config, Basics tab. Make sure DOS Windows State is set to Hidden.
(This thread should probably be moved to the MaLa forum)
arcadeswede
    • Revansch!
« Reply #6 on: February 01, 2016, 10:34:26 am »
Sorry, didn't work.  :-\
It worked! Thank you so much big10p!
You're right, maybe this could be moved to the Mala thread.
Problem solved! Thanks again
EDIT: Well it kinda worked. If I choose Hidden and can't control Mala after exiting Mame. If I choose Minimized, I'm able to control Mala so, Minimized it is!
« Last Edit: February 01, 2016, 10:39:46 am by arcadeswede »
