Author Topic: Venting my cabinet  (Read 11504 times)
morton
Venting my cabinet
« on: November 04, 2017, 10:01:00 am »
I am just about to prime my cabinet and the only thing I need to do is place some ventilation on the back side of the cabinet. I originally was going to install two 120mm fans at the top to exhaust the hot air, but realize many cabinets simply have venting. I have a few options, but due to the weather and such, have to drill, and a router is out of the question.
I can either:
- Buy a 4.5" hole saw to cut two 120mm fan vents
- Use a 1.5" hole saw and drill 4 or 5 holes across the top of the cabinet
Would the passive venting with the 1.5" holes be sufficient or would I be best to spend the $$ on a new 4.5" hole saw and install fans? I realize the fans will be more effective, but also see some don't believe fan is necessary and others say its better to have more, but would like to limit my expenditure if possible. Any help would be greatly appreciated. Thanks in advance.
Titchgamer
Re: Venting my cabinet
« Reply #1 on: November 04, 2017, 11:50:36 am »
It really depends how much heat your set up generates.
I would drill some 4.5” vent holes and put a cover over them.
If you need extra cooling just add fans after.
morton
« Reply #2 on: November 04, 2017, 12:08:17 pm »
Fans I have. The 4.5" bit will set me back almost $40 with tax tho... that's my biggest issue at this point. I'm just using a CRT and a Pi at this point. Not sure if heat will be more than a traditional cab, some of which i notice have minimal venting.
Titchgamer
« Reply #3 on: November 04, 2017, 02:05:02 pm »
If you are using a Pi you wont need and big fans.
Just put a small fan on a pi case and heat sinks on the chips.
Just a few small holes for CRT heat to pass in the top should be good to go :)
morton
« Reply #4 on: November 05, 2017, 08:43:37 am »
Thanks Titch :)
Spawn2k
  • Last login:May 24, 2022, 12:27:47 am
« Reply #5 on: November 05, 2017, 03:04:22 pm »
If you use a speaker cover over fan hole then the hole doesn't need to be perfect.
WetpantsMcGee
  • Last login:July 28, 2019, 03:44:18 pm
  • Last login:Yesterday at 08:25:01 am
« Reply #7 on: November 06, 2017, 11:49:30 am »
Draw a space invader on graph paper, tape it to your cabinet, use a nail punch to mark the holes, and then drill them out.  That will give you plenty of venting and doesn't cost anything.
bperkins01
« Reply #8 on: November 06, 2017, 01:00:50 pm »
Cutting larger circles is pretty simple with a router.
https://www.amazon.com/Jasper-200J-Circle-Cutting-Plunge/dp/B00009K77A
They sell jigs for it - but you can make one out of scrap for free for a single use like 4" circles.
No need to purchase a large hole saw..
This style does a neater job.  If the hole saw jumps - you just ruined the surface of your work..
The router style plunges and you just spin around the center pin..
Simple and clean.  cut any size hole you need.
proplayer77
  • Last login:November 09, 2019, 03:23:58 pm
« Reply #9 on: November 08, 2017, 12:02:53 pm »
On my bartop i used 120x120 fan for the cabin and a 40x40 on Rasp (a bit big but at least stays cool :))
I driller holes and then used a electric saw to cut the square out.
morton
« Reply #10 on: November 08, 2017, 07:13:56 pm »
The router makes too much of a mess... that was my original plan and would like to, but it was too wet outside. Realized normal cabinets didn't come with fans, and just elected to drill 5 1.5" holes along the top of the cabinet. They provide more than some cabs appeared to have. If it proves insufficient, I will go back to the drawing board in the spring. Have enough on my plate trying to get this primed ATM... painting is the worst  :banghead:
eds1275
  • Rock and Roll!
« Reply #11 on: January 05, 2018, 01:33:48 am »
I threw a few heater vent covers on the back of mine, and only had a back on the upper portion of the cabinet, mostly for stability. The bottom 2/3rds are open to the air, and I'm sure the only person that knows it is me since it's near a wall. I am not against a full back, but in my case it would have been another sheet of MDF.
barrymossel
  • Spectrum
« Reply #12 on: January 05, 2018, 05:21:52 am »
I like this idea, with whatever design...
« Reply #13 on: January 05, 2018, 02:59:48 pm »
Attached a pic of what I'm talking about.
morton
« Reply #14 on: January 07, 2018, 11:33:54 am »
Nice! That's a CNC job tho I reckon. Or buddy had some time  :lol
I just put 5 holes in the back in a row that allow rising warm air to escape the cabinet. I am trying to keep it looking somewhat OG like the cabs its based off... I have a feeling its going to go through a few incarnations throughout its life. The Pi and the PSU both have fans that will push warm air up (and hopefully out).
Thanks for the tips tho. My next cab will have an active ventilation component added to it, but am gonna roll the dice here on some passive cooling.
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #15 on: July 06, 2018, 01:38:35 pm »
I know the thread is getting old but I wanted to say thanks for this -- especially the space-invaders idea. I am adding a back door to my cabinet and want to add a simple convection vent... that space invaders idea is simple and really cool looking... and I don't need to get into routing MDF in my family room. I might even get lucky enough to get marquee light leakage projecting an invader on the wall or ceiling.
It's a Defender-style cabinet and I'm thinking I'll replace the two oval vents with a centered invader.
Zebidee
  • Last login:February 18, 2026, 09:18:11 pm
« Reply #16 on: July 31, 2018, 06:50:30 pm »
If you are installing a vent and/or fan, why not cut a small piece of bug screen mesh to fit? Do it to all your cabs little openings, speakers too. This will keep most of the little bugs out of your cabs.
Cut it just a bit smaller than your vent/fan/speaker cover and mount it in behind (cut the mesh so that the cover screws go through it); or in the space invader cutout idea, put the mesh on the inside. The mesh is made of nylon mostly these days and is easy to cut with scissors.
I just used some mesh left-over from a door screening project, but you can buy it very cheaply by the metre at your hardware store. Use a light grey colour if possible (less obtrusive/obvious for most situations).  I can't even see the mesh unless I look very carefully.
This really helps me as I am in a hot humid climate with lots of little bugs and also little lizards (geckos mostly, and larger too) that just love to go inside and lay eggs, sh!t, get electrocuted, and generally ruin my cabs.
« Reply #17 on: August 01, 2018, 02:42:22 pm »
Graph paper, nail punch, and a drill.
Draw the "invader" on the graph paper, use the nail punch to mark the holes, drill the nail punch marks.
morton
« Reply #18 on: August 31, 2018, 10:32:20 am »
On a bartop or with a huge press maybe, but I'm not drilling a 30x30 panel on no press. I need them holes perfect. Nothing worse than an invader on the outside and one that looks made from a burnt marshmallow inside haha.
Cool idea tho and I will likely use it somewhere.
