Author Topic: Labeled Buttons vs. Labeled Control Panel  (Read 6468 times)
bperkins01
« on: October 18, 2017, 10:47:55 pm »
Hi All,
90% done with the design of my cabinet and I'm in the process of picking out buttons.
I plan on using these for the game buttons:
I also planned on using them for the control buttons (Player1, Player2, Coin, esc, pause... etc)  and labeling the CP.
However..
I can also go with
and then add inserts
I'll be using RGB LED's so controlling the back lighting should work fine.
The short question is:  Do you like CP labels or button labels?
Curious to know what you like best.
Bob
rackoon
  • Last login:May 14, 2024, 01:12:10 pm
  • I EAT PENCILS!
Re: Labeled Buttons vs. Labeled Control Panel
« Reply #1 on: October 18, 2017, 10:50:24 pm »
my 2 cents is that the labeled buttons look cooler but I have seen some nice looking cp's with labels under the buttons ;D
They treated me like an animal and that's what I became.
  • Last login:December 21, 2025, 02:02:09 am
« Reply #2 on: October 18, 2017, 11:15:57 pm »
CP labels are old school
Titchgamer
« Reply #3 on: October 19, 2017, 02:28:20 am »
I think they both have a place depending on they style and look you are going for.
I have used both methods to good effect.
bperkins01
« Reply #4 on: October 19, 2017, 11:53:51 am »
Thanks for the feedback - I was leaning toward the backlit buttons and it seems like there are no real drawbacks.
So once they are back in stock - a big button order is in the works.
thanks again
sollyscomputers
  • Last login:March 06, 2019, 01:31:51 am
  • Jukebox? check! Now on to cocktail cab
    • Softweb Developments
« Reply #5 on: November 24, 2018, 09:24:34 pm »
Hi All,
However..
I can also go with
Bob
Hi,
I know this was posted last year, but how would you print these button labels?  Do you just print them on good quality paper with an inkjet?  Do you use the original disk as well, that the button comes with or just the printed label?  The LED is white for the buttons I want to label
Thanks John
  • Last login:Today at 12:52:43 am
« Reply #6 on: November 24, 2018, 10:16:40 pm »
Clear adhesive labels are better than paper labels -- better light transmission, no visible fibers.
You can inkjet print your own inserts like the ones here or here on Avery 18665 (10 pack) or Avery 8665 (25 pack) media.
If you have a laser printer, use Avery 15665.
Attach the adhesive Avery label to the diffuser (2nd from right), then carefully trim the excess.
- I usually put the label adhesive-side up and carefully lower the assembled plunger and diffuser onto it.
- The plunger legs are a convenient handle while trimming the excess.
- Inkjet ink flakes off very easily so print extra labels for just such an emergency. [/Foghorn Leghorn]
You may want to apply a ***small*** amount of superglue to keep the diffuser from turning under the cap.
Obligatory "CSI warning":  Allow the superglue to dry and offgas completely before assembling the buttons or they might end up like this.
« Last Edit: November 24, 2018, 10:24:51 pm by PL1 »
