Author Topic: vynil stickers on chipboard  (Read 8677 times)
f.pelosa
  • Last login:October 06, 2017, 08:19:14 am
« on: September 24, 2017, 10:00:48 am »
Hi all,
will a vinyl stick on a very smooth chipboard?
Or do I need to use a primer pain first?
thomas_surles
Re: vynil stickers on chipboard
« Reply #1 on: September 24, 2017, 10:15:21 am »
I would sand and prime and sand again
f.pelosa
« Reply #2 on: September 24, 2017, 12:13:48 pm »
is it a "I would" or is it a "if you don't, it won't stick"?
« Reply #3 on: September 24, 2017, 12:50:37 pm »
It’s a “it will look like ass if you don’t do what Thomas suggested”
f.pelosa
« Reply #4 on: September 24, 2017, 02:45:05 pm »
We're probably speaking about different materials.
What I'm referring to is extremely smooth. Sanding it in the first place is pointless if not for allowing the primer to stick better.
It is something like this: http://factfile.org/wp-content/uploads/2015/12/Chipboard.jpg
In fact, the reason I'm asking the question is that it is so smooth that I wonder if a vinyl would even stick.
PF
SlammedNiss
  • Last login:Today at 07:11:09 pm
  • Mine Drags the Ground!
« Reply #5 on: September 24, 2017, 05:12:18 pm »
I'm not sure what chipboard is, but whether or not vinyl sticks to it will depend on the type of vinyl. Just google the vinyl type located on the backing paper.
« Reply #6 on: September 24, 2017, 05:14:02 pm »
PF
Ok, that’s not chipboard the way Surles and I understand it.
As long as the surface is clean on that, if it’s quality vinyl, you should be fine.
« Reply #7 on: September 24, 2017, 05:17:31 pm »
This is generally called chipboard:
  • Last login:Today at 07:29:21 pm
« Reply #8 on: September 24, 2017, 08:46:52 pm »
^^^^^OSB (Oriented Strand Board)^^^^^
chipboard:
particleboard
MDF (Medium Density Fiberboard)
« Reply #9 on: September 24, 2017, 08:48:33 pm »
chipboard:
particleboard
ANYHOO,
A clean, dust free surface and good vinyl is the key.
« Reply #10 on: September 24, 2017, 09:01:08 pm »
but chipboard and/or OSB...whatever you want to call it... will have an uneven surface that will show through the vinyl that would have to be sanded or filled before applying.
MDF and particleboard typically is smooth enough not to need sanding or filling...results may vary depending on quality of material.
« Reply #11 on: September 24, 2017, 09:03:41 pm »
Which is why I agreed with Surles on primering and sanding in the first place.
jennifer
« Reply #12 on: September 24, 2017, 11:37:34 pm »
     Sega wiped it off, applied black matte vinyl, and then slapped a sticker on it, Problems came with time, as the wrap on bare wood  started to peel around the edges, and if the edge got dinged Well, starting point for issues, and then people would just start peeling around on it. Primer and sealer, is an option, but this too has its shortcomings, When the cab gets scuffed someday (they all do) you will have a bullseye of colored sealer around the damage (using a cheap waterbased product line) .... Jenn uses a clear sprayed on sealer, covered with sprayed on acrylic, color sanded to remove orangepeel and resprayed for flat,and then the sticker.(possibly burying that too in 9-15 coats of clear, for uv protection, and coverage over the depth of the sticker) depending on what your working on.
