Author Topic: Use old control wheel to make fast and more easy (i think) monitor rotation  (Read 18902 times)
takoni
  • Last login:February 07, 2019, 07:13:17 am
Just an a idea for pleople like me. I am not a tech man and is very dificult for me to build all parts from zero, so i decided to use a logitech old wheel to create rotation monitor system.
« Last Edit: August 28, 2017, 06:52:32 am by takoni »
  • Last login:February 01, 2026, 05:25:13 pm
Re: Use old control wheel to make fast and more easy (i think) monitor rotation
« Reply #1 on: September 01, 2017, 08:05:40 pm »
Looks good!
takoni
« Reply #2 on: September 06, 2017, 04:55:31 am »
A new state of the project.
« Reply #3 on: September 06, 2017, 08:38:05 am »
Looks real good. I like your rotating mechanism.
Using a button to rotate the monitor is ok, but if you really want to wow the people, make it turn automatically upon the selected game.
« Reply #4 on: September 06, 2017, 10:17:53 am »
a video of pictures....... why not just post pictures and a write up here?
« Reply #5 on: September 06, 2017, 10:35:25 pm »
He's new and still learning how we do things around here.
takoni
« Reply #6 on: September 11, 2017, 07:54:29 am »
Sorry about not getting with rules, still learning. Here are some new pictures of the project, i am going to finish the project and then i will work in making rotation dispach from raspberry witn led blinking or gpios or what about... cheers!!
« Reply #7 on: September 11, 2017, 08:02:19 am »
Its not a rule!  I prefer pictures over video, especially when the video is pictures ;)
I think the best course would be a write of what you did with pictures then a video of it in action. It looks super neat.
takoni
« Reply #8 on: September 15, 2017, 04:52:00 am »
Hi ...
What kind or model of hook system (I mean hardware system to listen RGBController command from Retropie) need i to use to appli rotation of monitor thru RGBController with raspberry? cheers
takoni
« Reply #9 on: September 22, 2017, 05:45:59 pm »
Solved , thanks a lot
