Author Topic: Write up on the New Magenta Stick from Paradise  (Read 5154 times)
Ian
  • Last login:February 27, 2026, 11:36:05 pm
« on: August 21, 2017, 05:38:37 pm »
I feel like it's been a while since we had some new joystick hardware action... this looks very similar to the U360's. Interested to see if anyone has yet to try these?
http://shoryuken.com/2017/08/18/shoryuken-preview-paradise-arcade-shops-magenta-could-be-most-customizable-lever-ever-created/
Titchgamer
Re: Write up on the New Magenta Stick from Paradise
« Reply #1 on: August 22, 2017, 02:02:50 am »
Looks interesting, I would not want to drop £100 on one without some extensive play time first though.
I can see where the price comes from though to be fair.
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« Reply #2 on: August 22, 2017, 12:25:51 pm »
Setup mapping app looks interesting.  If it can't swap maps automatically at game launch it would be a non-starter for me.
Funny how there is not a single mention of the Ultrastik in that article.
  • Last login:Yesterday at 08:00:13 pm
« Reply #3 on: August 22, 2017, 12:31:08 pm »
"Lever?"  WTF.
Slippyblade
« Reply #4 on: August 22, 2017, 03:45:22 pm »
I chuckled when I saw that you can attach microswitches to it so you can have the "feel and sound" of a clicky stick.
Ian
« Reply #5 on: August 22, 2017, 04:38:33 pm »
I thought that was funny too...
Mr. Peabody
  • Last login:February 12, 2026, 12:32:17 am
« Reply #6 on: August 28, 2017, 09:54:08 pm »
You're not understanding. This stick measures in radians. At six times the resolution of the U360.
This means you're not restricted to a grid. Diagonals have the same volume of space as cardinal directions = diagonals are as easy to reach as cardinal directions (pokes Randy at GGG). Division between directions is a straight line, rather than stepped. And it is more responsive than any stick ever made - with the exception of any analog design (pot-based, or the original hall effect design).
A stick shaft moves in an arc, and the Magenta tracks it 'natively'. This is what the U360 should have been capable of at least within a year of roll-out, and is probably the answer to why it hasn't been embraced by the shmup and fight stick communities. I don't know why Paradise Arcade designed the Magenta with those communities in mind, but it is the joystick for the emulation community. I assume software map change on the fly is a trivial matter, if not already feasible but not showcased. If so, and if they can get the cost down to $70, Andy at Ultimarc may be scrambling to re-fit the U360. Which still won't be as accurate as the Magenta, due to the sensor design.
« Last Edit: August 28, 2017, 10:15:08 pm by Mr. Peabody »
strblast
  • Last login:November 21, 2018, 07:44:35 am
« Reply #7 on: August 29, 2017, 02:21:44 am »
I had to take the U360. I may be waiting  ???
ark_ader
  • I glow in the dark.
« Reply #8 on: August 29, 2017, 03:38:26 am »
Which part of the joystick was magenta?  :dunno
gamepimp
« Reply #9 on: August 29, 2017, 12:12:23 pm »
I liked the part where it says that you "can tell exactly where your shaft is at all times". Seems pretty important to me! LOL.
Ian
« Reply #10 on: August 30, 2017, 11:42:59 pm »
Thanks for the clarification! It looks like a great option for mame!
Brian74
  • Yep... I built that!!
« Reply #11 on: August 31, 2017, 10:21:24 pm »
I was at Paradise Arcade Shop two weeks ago and seen this stick. Its pretty impressive.
