Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 280475 times)
haynor666
  • Last login:January 03, 2026, 01:58:04 pm
  • retro maniac
Re: GroovyMAME/ARCADE32/64 custom build
« Reply #360 on: January 02, 2022, 10:14:45 am »
If this is derived from the official ARCADE64, then you don't need a nonag patch - it's got a built-in one that only needs to be turned on.
It was used form MKChamp source :/
BTW. Some old problems with audio for various Konami games has been (?) fixed so probably many hacks are not nedeed now. Someone could confirm proper audio in Super Contra, Aliens, Simpsons, Crime Fighters ?
« Last Edit: January 02, 2022, 11:37:04 am by haynor666 »
haynor666
  • retro maniac
« Reply #361 on: January 03, 2022, 04:34:42 am »
Audio fixes/hacks for various Konami games are not needed in version 239 now but would be nice to see confirmation from users if it's really ok.
Also audio fix Gradius, Galactic Warriors is not needed now.
Are there other hacks that are needed to remove? I didn't look closely into mame source for long time using old version in my semicab env so feedback would be welcome as well.
« Last Edit: January 06, 2022, 03:56:09 pm by haynor666 »
haynor666
  • retro maniac
« Reply #362 on: January 05, 2022, 10:35:08 am »
Version 238 is out.
Version from 229 to 238 are renamed - removed 64 suffix just like in official mame.
haynor666
  • retro maniac
« Reply #363 on: January 13, 2022, 02:54:14 pm »
Version 239 is out
Recapnation
    • Eiusdemmodi
« Reply #364 on: January 13, 2022, 07:01:21 pm »
Likely the one fixing Captain America and the Avengers' audio, in case there was one for that.
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
« Reply #365 on: January 14, 2022, 06:03:20 am »
NVM
« Last Edit: January 14, 2022, 05:59:43 pm by Trnzaddict »
haynor666
  • retro maniac
« Reply #366 on: January 15, 2022, 02:01:27 pm »
No ,there wasn't any fix for this game.
haynor666
  • retro maniac
« Reply #367 on: February 13, 2022, 01:18:41 pm »
Version 240 is out.
silvereagle
  • Last login:April 05, 2023, 05:10:23 pm
« Reply #368 on: February 20, 2022, 02:09:30 pm »
Please pardon the noob question, but would your latest versions have the killer instinct audio stutter fix by any chance? Thank you.
haynor666
  • retro maniac
« Reply #369 on: March 07, 2022, 05:48:22 am »
I didn't modify Killer Instinct source so if there are problems in official mame then also here.
MK3FANATIC
  • Last login:November 08, 2025, 08:56:50 am
« Reply #370 on: March 09, 2022, 02:59:21 pm »
 @haynor666  Would it be possible to compile a groovymame with the mame0139b_64bit version? With the modifications that this version allows, of course. Me and many Killer Instinct fans would be very happy.
psakhis
« Reply #371 on: March 11, 2022, 03:07:13 am »
Hi, you can run cmdline switchres with mame passing 320x240@60 resolution, right?
MK3FANATIC
« Reply #372 on: March 11, 2022, 11:06:48 am »
I'm not very familiar with command lines, but I can change the mame to 320x240 through .ini , I didn't quite understand your question...
psakhis
« Reply #373 on: March 12, 2022, 11:52:20 am »
switchres.exe -f 320x240x60 320 240 60 -s -l "mame.exe kinst" -i "switchres.ini"
haynor666
  • retro maniac
« Reply #374 on: April 02, 2022, 01:21:17 pm »
Version 241 and 242 are out. I'm sorry for delay.
Moksi
  • Last login:December 07, 2025, 10:21:53 am
« Reply #375 on: April 05, 2022, 06:25:16 am »
IS the latest version of your Groovymame best to date ? , wasnt there some probs with the latest releases of groovymame ?
whats is the best version to date ?
where do you add that line in the ini ?  i want to setup that specific version of mame for killer instinct aswell or do you have an example ini file thanks
haynor666
  • retro maniac
« Reply #376 on: May 03, 2022, 06:34:46 am »
Version 243 is out. Added resolution fix for slapfght driver. - broken. I will soon upload fixed version.
EDIT. Re-uploaded :)
« Last Edit: May 03, 2022, 04:02:55 pm by haynor666 »
eewoke
  • Last login:April 14, 2023, 05:18:23 pm
« Reply #377 on: May 04, 2022, 02:48:46 pm »
Thanks! Appreciate your contribution!
haynor666
  • retro maniac
« Reply #378 on: May 29, 2022, 07:50:44 am »
Version 244 is out. Removed patch for slapfght driver - not needed.
haynor666
  • retro maniac
« Reply #379 on: July 01, 2022, 03:52:05 pm »
Version 245 is out.
haynor666
  • retro maniac
« Reply #380 on: August 11, 2022, 05:59:59 pm »
Version 246 is out.
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« Reply #381 on: August 17, 2022, 12:53:17 pm »
Hello haynor666
How are you, hope you are fine !
Tried to download 0.246 but Chrome are complain about a virus on the file.
Can you checkout please.
Marcos
haynor666
  • retro maniac
« Reply #382 on: August 19, 2022, 08:41:27 am »
ESET says it's fine. No complain from latest Chrome either.
Olivcade
  • Last login:December 28, 2025, 01:15:48 pm
« Reply #383 on: August 19, 2022, 10:42:09 am »
Hi,
I am under XP32 SP3 and the maximum version that I can use is the Custom Groovymame32 0.211 version, from 0.212 it no longer works on my XP32, any idea?
I saw that you had compiled the 32-bit 0.215 too but ditto it does not want to work on my XP32 I get a system compatibility error.
Hardcade / PlayRetro Frontend development / Mame 0.168 Slider Refresh Save 1.2 development
Hardcade Frontend : https://sourceforge.net/projects/arcade-frontend/
Mame 0.168 Slider Refresh Save 1.2 : https://github.com/HardCade/hardcade
haynor666
  • retro maniac
« Reply #384 on: August 19, 2022, 12:42:36 pm »
I stopped support DX8 cards from version 216 but starting from version 212 seems to stopped working on Windows XP sadly probably due official changes.
« Last Edit: August 19, 2022, 12:52:34 pm by haynor666 »
Olivcade
« Reply #385 on: August 19, 2022, 03:22:59 pm »
what is strange is that the official versions of Mame/Arcade32 all work on XP32 until the latest.
arghh it's a shame for version 0.216 because it has the "low latency" option but from what I've read it's the equivalent of Groovymame's Frame delay option. so I don't know if it's interesting.
I'm happy to be able to use version 0.211 on my XP32 thank you very much for your work
peterson65
  • Last login:December 13, 2025, 03:57:23 pm
« Reply #386 on: August 25, 2022, 11:35:16 am »
cant download on chrome says it has a virus. download on edge also the same but if I choose download as a zip it works but trying to unzip defender blocks and says , see attached
haynor666
  • retro maniac
« Reply #387 on: September 01, 2022, 03:48:05 am »
FireEye (very restrictive) in my work place does not see any virus either. ESET at my home also says it's ok (at least for versions 245 and 246).
« Last Edit: September 01, 2022, 03:50:32 am by haynor666 »
haynor666
  • retro maniac
« Reply #388 on: September 18, 2022, 05:23:35 pm »
Version 247 is out.
Endprodukt
  • Last login:December 30, 2025, 07:55:39 am
« Reply #389 on: September 24, 2022, 09:09:29 am »
Thank you so much for your work. Would it be possible to include Mk2+ and Umk3+ into the build?
https://github.com/antonioginer/GroovyMAME/pull/2/commits/f7afacd4811f3cb26930712908652f492986042e
It's an amazing update to the original Mortal Kombat games. https://mortalkombat.plus/
« Last Edit: September 24, 2022, 10:25:28 am by Endprodukt »
psakhis
« Reply #390 on: September 24, 2022, 11:28:36 am »
HBMame
Endprodukt
« Reply #391 on: September 25, 2022, 05:22:27 am »
HBMame
Has nothing to do with GM though.
psakhis
« Reply #392 on: September 25, 2022, 11:16:25 am »
You need a HBMame with switchres patch, aka HBGroovymame.
Endprodukt
« Reply #393 on: September 25, 2022, 12:09:20 pm »
Okay, that would make sense, but from what I see non of the files in HBMame are matching, completely different romset.
  • Last login:Today at 03:53:38 am
« Reply #394 on: September 26, 2022, 01:16:11 am »
Yes, the ROM hacks and homebrew games that are in HBMAME (or some of the other MAME spinoff builds) are not the same as the un-hacked and non-homebrew ROMs that are in mainline MAME.
HBMAME (HomeBrew MAME) is a derivative of MAME, and contains various hacks and homebrews. It is based on the latest MAME source at the time of release.
What's in it?
    - Homebrew games meant for arcade hardware, or emulators of arcade hardware
    - Hacks of arcade games
    - Test roms and similar that do not generate revenue
    - Selected bootlegs that are not in MAME
    - Games that are enhanced or improved but not suitable for MAME
https://hbmame.1emulation.com/index.html
haynor666
  • retro maniac
« Reply #395 on: September 26, 2022, 03:44:25 am »
I'm sorry but my build adds only some modifications for existing games. I don't have any plans to add new games.
As was mentioned earlier HB MAME would be the best choice.
Endprodukt
« Reply #396 on: September 26, 2022, 07:18:48 am »
Bummer! Have been trying to make my own HBMame version with your patch and gm, no success here.
spiderzsoft
  • Last login:August 07, 2024, 08:09:02 pm
« Reply #397 on: October 22, 2022, 09:44:01 am »
Version 247 is out.
i want to add KOF98AE in Arcade32. can some one do this?
« Reply #398 on: October 22, 2022, 10:23:24 am »
AFAIK KOF98AE is a hack from 2007.
- Did a quick check on github and it looks like it's not currently in mainline MAME or HBMAME.   :dunno
You should be able to run it using the Final Burn Alpha (FBA) emulator.   :cheers:
EDIT: Found this in the HBMAME 0.175 release notes here.
- [kof98ae3]
- [kof98ae20160308] Kof'98 Anniversary Edition 2016
Digging further, "kof98ae" and a large number of other related titles + code (lines 33-2282  :o) were removed from the HBMAME kof98.cpp driver with this commit on September 14th.
- No idea when/if those titles and code might be fixed and added again.
- If you use a GroovyHBMAME or HBMAME release between v0.175 and the last version released before September 14th, "kof98ae" should be supported.
If you're looking for the 2016 version hack, line 3731 of the kof98.cpp driver reads "ROM_START( kof98hh02 ) //kof98ae2016h" in current HBMAME source.
- I assume that means that "kof98hh02" is the current ROMname of the 2016 hack.
« Last Edit: October 22, 2022, 12:01:11 pm by PL1 »
Robbbert
  • Last login:January 01, 2026, 03:22:06 pm
« Reply #399 on: October 23, 2022, 04:50:40 am »
Yes there was a lot of cleaning up recently to remove games that had issues, including all the kof98ae series. Problems included rebooting unexpectedly (with euro bios) or Address Error (with unibios), bad graphics or just not working at all.
Most neogeo hacks originate in China, where they favour using mc68000 cpus that don't have exception processing (such as FBNeo, nebula, kawaks, neorage, etc) and therefore the faulting games won't work on real hardware.
