Author Topic: Mala frontend snaps  (Read 10900 times)
scottyNLG
  • Last login:December 01, 2018, 11:24:58 am
  • New Life Games slot/arcade tec
Mala frontend snaps
« on: June 28, 2017, 02:39:21 pm »
i need some assistance i have a mame cabinet i am building with a mala frontend running win xp pro and my problem is i have mala set to boot with windows and when it dose none of the snaps for my tree show up but if i exit mala and boot it back up manually it shows the snaps dose anyone have a solution for this? ??? ??? ??? ???
Your friendly neighborhood arcade tec
scottyNLG
Re: Mala frontend snaps
« Reply #1 on: June 29, 2017, 03:49:48 pm »
any help at all would be greatly appreciated  :) :) :)
  • Last login:January 01, 2026, 05:29:50 am
« Reply #2 on: June 30, 2017, 09:41:58 am »
Instead of checking the box in Mala to have it start with windows, create a shortcut to mala and place it in the windows startup folder.
It will delay Mala starting.
I'm thinking maybe Mala is launching before some required background service needed to show the pics.
Maybe giving other things more time to start before Mala launches will fix it.
It's just something to try.  I don't know if it will help or not.
I had a problem with Mala launching before the sound card software was ready and this fixed that.
scottyNLG
« Reply #3 on: June 30, 2017, 03:28:44 pm »
I gave your suggestion a try and still no luck the only way i can git the snaps to show up is by manually double clicking on mala to start it. tanks for the suggestion tho.
empardopo
  • Last login:Today at 06:02:48 am
    • My personal forum
« Reply #4 on: July 01, 2017, 07:00:24 am »
Are you using the last version of Mala? (1.082 I think...)
Have you the log enabled? Perhaps, you could see any error on it...
Greetings.
scottyNLG
« Reply #5 on: July 01, 2017, 12:46:32 pm »
I do have the latest version running and according to the log everything is running as it should
big10p
  • Mmmm, arcade classics!
« Reply #6 on: July 01, 2017, 04:21:15 pm »
What format are your snap images in?
scottyNLG
« Reply #7 on: July 01, 2017, 08:41:31 pm »
png
big10p
« Reply #8 on: July 02, 2017, 05:37:06 am »
Hmm, well, MaLa can be pretty quirky at times. Sometimes you just need to poke at things to get them to work. Here's a few things to try:
First off, make sure all your snaps are held in a MaLa sub folder. e.g. C:\mala\images\snaps
The png file format can be quirky, too. I've had png files that display fine in Windows preview and Paint, but are screwed up when loaded into PhotoShop. Try converting a couple of images to another format, just to see if they display.
In Mala config (GUI->Options->Picture and Video), change the picture quality to "fast,low". Also try checking/unchecking the 'keep aspect ratio" box.
Try another layout to see if snaps show OK. If they do, you know MaLa has some problem with your layout. Post it here if you can, so we can test it.
See if you can find a codec pack online to install. Videos weren't working for me until I did this, despite them playing fine in Windows.
scottyNLG
« Reply #9 on: July 02, 2017, 05:57:37 pm »
ok after 3 days of messing with it i finally got the game snaps to show on startup (had mala looking in the wrong folder) but i still cant get the snaps for my tree to show on startup but they do show up when i manually boot  :banghead: :banghead: :banghead: :dunno
Pageapoo
  • Last login:August 10, 2020, 05:41:46 pm
« Reply #10 on: July 22, 2017, 06:43:32 pm »
Not sure if you've solved this. I seem to remember having to change to JPEG for my snaps to get them all to show up consistently. Otherwise, it seemed like every other one would just show a white screen when I used png files.
Also, I think I had to save the tree snap jpegs in the same directory as the .mll file. For example, my Nintendo.mll file is in a directory. In that same directory is a Nintendo folder with the JPEG in it. I then had to copy and paste the Mala Menu_Nintendo.jpg in the same directory as the mll file. Not sure why it had to be this way, but that was the only way to get the tree snaps to show up.
Hope that helps, good luck!
