Author Topic: Need for speed carbon  (Read 3374 times)
spanks_4
  • Last login:September 28, 2018, 10:41:24 am
« on: May 31, 2017, 09:46:52 am »
Anyone that has messed with global vr products knows the computers are junk. So I built a newish pc with an asrock motherboard that uses the same processor/chip set which I was told would be compatible with the original stuff. I have a friend trying to get the game running, but he's having issues getting the drivers and other stuff to install.
The latest issue, excuse me if I state this wrong I'm pc inept, is this: Something about the INF asking for pci.sys file. From what we're told this file should be on the operating restore disk, but the system is saying the pci.sys doesn't exist.
Anyone have any ideas on what to try next?
  • Last login:February 20, 2026, 07:25:33 pm
Re: Need for speed carbon
« Reply #1 on: May 31, 2017, 10:11:21 am »
try just dumping a copy of pci.sys into the same folder that houses the INF for the drivers you are installing.  if its on a cd you may have to dump it into a folder on  the computer so you can add it and then run it from there.
its posibble originally the drivers where done in a specific order as to have already has pci.sys in the system.
spanks_4
« Reply #2 on: May 31, 2017, 10:38:02 am »
Is it possible to run NFS carbon on something like win7 or 10? I think that would probably solve all of our issues, but then we would fight the nytric drivers.. nevermind
ed12
« Reply #3 on: May 31, 2017, 11:57:26 am »
what shawn is saying is correrct
but your largest problem is trying to dump file's
a=in windows when they are linux
b=windows must be fourced to allow you to see  system files
pci.sys will be there but it could have an extenision to it .inf for example
this would
a=hide the file
b=make it un-readable to windows
shawn pointed you to a way
do this
make a folder on your c: harddrive >note i went root<
copy the contents of the rescue disk to it.
now start/run/cmd >run cmd in adim mode< this gives u full control
now c:\to the folder u made for the rescue disk
now look for it,i bet u find what u need
ed
  • Last login:Yesterday at 08:00:19 am
« Reply #4 on: May 31, 2017, 04:03:31 pm »
There is probably a program included with the ultimate boot CD that can see the file and copy it.
http://www.ultimatebootcd.com/
The computer is basically running from the disc, so the problems of the windows environment don't apply.
It's been so long, I don't remember the name of the program on there I used last time I monkeyed around with pulling files from an oddball drive.
TestDisk maybe? (parted magic looks promising)
Sorry I can't be of more specific help, but you've got the two most knowledgeable arcade techs helping you.  ;)
« Last Edit: May 31, 2017, 04:06:47 pm by BadMouth »
ed12
« Reply #5 on: May 31, 2017, 04:09:50 pm »
If you like trying out new stuff, please check out an early beta version of UBCD Live and give us your feedback. This is a Live Rescue CD based on Debian, which we hope will eventually be good enough to replace Parted Magic
exactley what i was stating (non windows)
if the op requires i will run it, as i run split system (winblows-linux/with debain
ed
