Author Topic: Grounding Control Panel Contols  (Read 1985 times)
Lamaman1971
  • Last login:February 06, 2026, 11:21:46 am
« on: May 04, 2017, 08:54:20 pm »
Hi everyone, Ive a large 4 player CP with spinner and trackball attached. They work ok but - if im honest - Im not happy with the grounding. The wiring of the panel is complicated by using LED buttons (of which there are many). Frankly its no as neat as I would like.
As I say,  it works and at the moment the ground from all the controls is tied into my Ultimarc iPac controllers ground pin.
Does anyone have a better recommendation?
syntax_x
  • Last login:October 27, 2019, 09:32:44 pm
Re: Grounding Control Panel Contols
« Reply #1 on: May 04, 2017, 09:06:05 pm »
Post up a picture of the rats nest so we can make a call.
Lamaman1971
« Reply #2 on: May 05, 2017, 01:48:19 pm »
To be fair, Im not looking for a critique of my wiring - just advice or alternate points to ground my controls - unless everyone is grounding into their controller PCB?
TheDotEater
  • Last login:October 12, 2025, 02:34:14 am
  • I did build my own arcade controls!
« Reply #3 on: May 05, 2017, 02:32:49 pm »
Not sure I fully understand your problem. Is the problem that you don't like having all your individual grounds running to your encoder?
Are you daisy-chaining?
Either way you could have all your grounds run to a single terminus that connects to your ipac's ground pin. For instance, terminate all your grounds with a ring terminal, secure them with a nut and bolt, and have one lead running to your ipac.
  • Last login:Today at 12:19:32 pm
« Reply #4 on: May 05, 2017, 03:38:51 pm »
A picture would be really helpful.
