November 13, 2025, 05:09:16 am
That's not the guide for the 5000 series and up cards that you've linked, it's a download for crt_emudriver, and the wrong version of crt_emudriver for your card. Make sure you're using the CRT emudriver 2.0 build you need (read the list on the download page!) for the 6850 on Win 7.GM also took a break for a few versions, IIRC. So no, there's no 0.175. MAME roms get updated a few at a time with each new release. 99% of the games you have will work, and you can always hunt down newer roms in specific cases.
I would recommend that you get it all running via the command line first to check CRTemudriver, VMM, etc is all working correctly.
You can also see what modeline switchres has chosen to run a game in by hitting TAB->Machine Information
You need CRT_Emudriver 2.0...http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295
You should be able to make it stable with the vertical hold control (assuming your monitor is working correctly). Mine is REALLY touchy and hard to get stable.
Post your monitor information. Maybe someone will have some ideas.Also, a quick search found this thread. Maybe it might be relevant...http://forum.arcadecontrols.com/index.php?topic=98266.0
This thread sounds relevant, but I'm not sure...https://forums.arcade-museum.com/showthread.php?t=181899Are you connecting through a J-Pac?
the issue was that I didn't actually have the JPAC powered on by the additional usb cord.
