Author Topic: About to start Groovymame portion of my project - need some clarification  (Read 7711 times)
jtb1987
  • Last login:August 15, 2021, 01:08:10 am
Hi guys,
So I'm finally getting time to continue work on my arcade cabinet and my next big project is to get my computer connected to my arcade monitor using a JAMMA board + JPAC + Radeon HD 6850 + Groovymame + CRT Emudrivers.
I'm following this guide:
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=65
...and also this as a secondary reference:
Before I get started, I can't seem to find a Groovymame 0.175 version.
I'm looking at the versions available here:
https://drive.google.com/drive/folders/0B5iMjDor3P__aEFpcVNkVW5jbEE
My mame romset is 0.175. It's my understanding that normally your mame version must be the same as your rom set. is this also true for Groovymame? Or is the Groovymame software universal?
Can I simply use the latest version of Groovymame and it will work with my romset 0.175, or do I need to upgrade my romset to be a version of Groovymame available for download? Thank you for any help!!!
buttersoft
  • Last login:Yesterday at 05:00:02 pm
  • Is running at 15kHz
That's not the guide for the 5000 series and up cards that you've linked, it's a download for crt_emudriver, and the wrong version of crt_emudriver for your card. Make sure you're using the CRT emudriver 2.0 build you need (read the list on the download page!) for the 6850 on Win 7.
GM also took a break for a few versions, IIRC. So no, there's no 0.175. MAME roms get updated a few at a time with each new release. 99% of the games you have will work, and you can always hunt down newer roms in specific cases.
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
Just go with the latest GM version which is 0.183 (or you can use the patches for 0.183 on the source for 0.184 if you want - I tested it and it works). There's no point having an older version of the emulator which is continually being improved upon.
jtb1987
Whoops you're right -
This is what I'm supposed to use I believe:
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=301
I think I'm going to look into what is all involved in updating a mame romset.
As another question, I have my frontend (hyperspin) setup all configured with the standard mame; once I'm ready to proceed with the groovymame setup - how much should I expect to "re-do" with my hyperspin/rocket launcher configuration?
Again guys thanks so much for the help, really appreciate it
Jonny G
Regarding HS, switching it to use GroovyMAME SHOULD  be as simple as replacing the standard mame.exe with a GM one in your MAME directory. Making sure it is named exactly the same of course. You shouldn't have to do any other work on your HS setup.
I would recommend that you get it all running via the command line first to check CRTemudriver, VMM, etc is all working correctly.
buttersoft
Yeah, leave the nagscreens on to make sure GM is picking the closest super resolution :)
big10p
  • Mmmm, arcade classics!
You can also see what modeline switchres has chosen to run a game in by hitting TAB->Machine Information
buttersoft
I didn't know that. Thanks :)
jtb1987
I think I'm stuck...
I'm attempting to to follow this guide below but the actual results are different from the expected results:
In my first image I see that in device manager "Calamity" is indeed the digital signer on the driver
In my second image, when attempting to run the video mode maker, it says "no compatible video driver found"
Question -
Is it true that ATI Radeon HD 6000 level cards are supported by the CRT emulation drivers for 64 bit Windows 7?
When I look here, it appears to only support up to 4000 for Windows 7?:
I'm working with an ATI Radeon HD 6850 card plus Windows 7 64 bit...I hope that isn't my problem :(
jtb1987
Let me also just add that even though the video mode maker stated, "no compatible video driver found <registry update disabled)" -
It still appears to have imported/generated 120 modelines...see attached
I"m just not sure how to troubleshoot why it's not seeing the driver. In the device manager it clearly says that the calamity driver is the digital signer -
Thanks everyone for any help
krick
  • Gotta have blue hair.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
jtb1987
You need CRT_Emudriver 2.0...
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295
Yikes, ok thanks, not sure why I got confused there but I just did a round 2 with driver version 2.0:
I successfully installed CRT drivers 2.0 and got to the step of actually hooking up my arcade CRT to the computer! There is an image; however, the image is slowly scrolling vertical. The entire picture is just scrolling down over and over - I'm thinking I've still did something wrong because it's not mentioned in this guide.
I'm supposed to move on to the Video mode maker step now but should I first be concerned with this scrolling action going on? Thanks for any help!!!
jtb1987
One more note -
I can actually slow the scrolling down to be very slow by adjusting the "v-hold" on a settings pad that came with the monitor, see attached image. While I can make the scrolling slower, I can't actually make it stop :(
krick
You should be able to make it stable with the vertical hold control (assuming your monitor is working correctly).  Mine is REALLY touchy and hard to get stable.
Hantarex Polo 15KHz
jtb1987
The closest I've gotten to hold stopped the scrolling but still jittered up and down and forth...then i gently laid down the panel with the v-hold knob onto my desk and it went back to the slow vertical scrolling....
Is 100% the arcade monitor or could it be I'm not using the correct frequency from the VMM settings? I selected the 15kh arcade standard option.
krick
Post your monitor information.  Maybe someone will have some ideas.
Also, a quick search found this thread.  Maybe it might be relevant...
http://forum.arcadecontrols.com/index.php?topic=98266.0
Hantarex Polo 15KHz
jtb1987
That does appear to be my same issue -
Here is my monitor -
The original game/jamma board did not have the scrolling issue (Tekken 3)
krick
This thread sounds relevant, but I'm not sure...
https://forums.arcade-museum.com/showthread.php?t=181899
Are you connecting through a J-Pac?
Hantarex Polo 15KHz
jtb1987
I am connecting through a J-Pac, I will take a look at the thread
jtb1987
The gist of that thread was that it could be a failing v-hold pot?
I guess I'd like to just rule out that it's not software related. I want to make sure since the JAMMA Tekken 3 game that it came with worked fine, no issues with scrolling/v-hod.
If not software related I think I may need to find a local show/repair technician (if one exists near me for this hobby lol).
buttersoft
You could always try flipping the v-sync polarity in a particular modeline to see what happens. Use ArcadeOSD from the emudriver package, then video modes, then pick one, then edit modeline, scroll down to the bottom, flip polarity, and test.
jtb1987
Well.
I feel dumb admitting it, but, the issue was that I didn't actually have the JPAC powered on by the additional usb cord.
Sigh.
It works now.
Thanks guys
krick
I didn't think to ask if the sync LEDs on the J-Pac were lit.  That would have tipped us off right away.  I accept part of the blame.  ;D
Hantarex Polo 15KHz
