Author Topic: Push Pull Spinners  (Read 2449 times)
alexportugal1212
  • Last login:February 17, 2019, 10:24:20 pm
Push Pull Spinners
« on: March 10, 2017, 04:31:20 pm »
Hi what are the buying option for a push pull spinner? Thanxs
TheDotEater
  • Last login:October 12, 2025, 02:34:14 am
  • I did build my own arcade controls!
Re: Push Pull Spinners
« Reply #1 on: March 10, 2017, 04:36:25 pm »
alexportugal1212
« Reply #2 on: March 10, 2017, 09:13:54 pm »
haynor666
  • retro maniac
« Reply #3 on: March 11, 2017, 06:26:16 am »
Sadly I didn't find any other :/ Nice spinner but really too expensive.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #4 on: March 13, 2017, 12:06:02 am »
What ive been doing (works most of the time) is set the fire button (for those types of games) to left and right axis on a regular spinner and each joystick direction as fire too.  I play forgotten worlds and Tron like this among others.
Is there a better way anyone?  I'd love to hear about it :)
alexportugal1212
« Reply #5 on: March 13, 2017, 10:59:39 pm »
I have a pedal from a wheel DFGT, so i put the fire button to the pedal and step on it when want to fire, it works pretty well but im getting the push pull spinner anyway, im sick i know... its like a drug to have the perfect arcade to me, cant stop and this is the last piece of the puzzle...
equlizer
« Reply #6 on: March 13, 2017, 11:22:07 pm »
is this pedal usb? have a link to it? :cheers:
alexportugal1212
« Reply #7 on: March 16, 2017, 05:27:33 am »
Its a pedal from a logitech racing wheel that i had, but any usb pedal will do :)
  • Last login:Today at 05:35:55 pm
« Reply #8 on: March 16, 2017, 06:06:00 am »
If you want to play Discs of TRON and some racing games you may find it easier to use a 2-switch rocker pedal instead of using two pedals with one switch.
The 2-switch rocker pedal here can be connected using a stereo audio jack  (or similar) to wire the pedal switches in parallel with two buttons.   ;D
Works great for the high/low function in Discs of Tron.
For high/low turn the pedal so the cable is in the back.
For gas/brake turn the pedal so the cable is on the left.   ;D
