Author Topic: Favorite wood for arcade cabs?  (Read 11467 times)
DarakuTenshi
    • Card Fighters Project
« on: February 20, 2017, 03:01:59 pm »
What is your favorite wood to build your cabs out of? I've used both plywood and MDF and I seem to like MDF much more. What are your thoughts?
thewisteron
  • Last login:May 03, 2020, 08:04:40 pm
Re: Favorite wood for arcade cabs?
« Reply #1 on: February 20, 2017, 03:16:35 pm »
Don't use particle board. I know from experience. Takes a lot more effort to get it smooth if you're painting. Going through this headache right now.
  • Last login:Yesterday at 04:55:22 pm
« Reply #2 on: February 20, 2017, 04:26:37 pm »
Laminated plywood.   :cheers:
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
« Reply #3 on: February 20, 2017, 10:45:03 pm »
Where can you gets sheet of that from?
« Reply #4 on: February 20, 2017, 11:37:04 pm »
I wish MDF wasn't so heavy.
gumby510
  • SR-20 NX 2000
« Reply #5 on: February 21, 2017, 12:33:26 am »
Where can you gets sheet of that from? Tried home depo they can't order black melamine. Maybe try a cabinet shop?
DarakuTenshi
« Reply #6 on: February 23, 2017, 08:08:22 am »
Yes, the first cab that I built was mostly MDF and not only did I not feel it was very structurally sound, but I hated working with the wood.
One cab that I worked on I just added laminate to the outside.
This is my conundrum.
bdn103
  • Last login:September 05, 2023, 09:29:59 pm
    • Classic Arcade Cabinets - FREE arcade cabinet build plans, printable PDFs and CNC plans
« Reply #7 on: February 23, 2017, 08:21:34 am »
You might want to take a look at MDO.
It is much more expensive, but it is basically plywood with a thin layer of MDF on the outside. It is light and strong like plywood, but perfectly smooth and easy to finish like MDF. It also comes pre-primed. The additional costs are easily made up with time and money saved during finishing.
Brian
Free arcade cabinet build plans. CNC drawings, CAD drawings, and printable templates. http://www.classicarcadecabinets.com
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #8 on: February 23, 2017, 06:40:16 pm »
Melamine.  No need for painting after :)
DarakuTenshi
« Reply #9 on: February 26, 2017, 08:44:25 am »
Brian
Never heard of it. I'll have to see if they have that in my area.
Laythe
  • Last login:February 18, 2026, 06:54:56 pm
« Reply #10 on: March 15, 2017, 09:21:31 pm »
I'm a big fan of 3/4" plywood.  I get 3/4" A/B birch-face at about $65 a sheet at my local home depot, it doesn't have many voids, and it doesn't take an insane amount of work to get an adequatel (not Ond-level) paintjob on it.  It's lighter and stronger, if it ever gets wet it won't become oatmeal, and the sawdust isn't evil.
(Well, ok, it isn't actually 3/4, it's something absurd like 35/48ths inch because plywood sizing is stupid - but it's basically 3/4, close enough that T-mold looks alright.)
« Reply #11 on: March 15, 2017, 10:08:25 pm »
I've evolved quite a bit on this, worked in MDF, MDO, particle, hardboard, hardwood plys, and el-cheapo sandply.  My personal fav right now and pretty much from now on - sandeply with laminate over the top.  Works out to be cheaper and lighter and stronger and more water resistant than the other options (not all of those for all the options but at least cheaper once you factor in paint/primer/sand/etc).
If I need to do shaping then MDF is still the best option out there but if it's not going to be complex edges or sculpture it's going to be sandeply with laminate over the top.  Easy peasy.
ugleymatt
  • Last login:October 11, 2022, 12:13:37 pm
« Reply #12 on: March 16, 2017, 08:58:02 am »
I've been using plywood and so far its been an enjoyable experience. Always loved working with wood and this feels close to being that, albeit it manufactured.
NIVO
« Reply #13 on: March 27, 2017, 06:04:06 pm »
1/2" MDF is mah personal fave. Strong, versatile and a helluva light lighter than 3/4" MDF over an entire large build. MDO is exceptional as its the way alot of folks go when updating cabinets in the house. We use it on job sites and kitchen makeovers and the cost diff is negligible over a large build. Especially considering you value your time as one of the key factors.
gamepimp
« Reply #14 on: March 28, 2017, 10:08:05 am »
If you can find it, this stuff is pretty awesome for arcade machines:
http://www.trupan.com/informacion2.asp?Submenu=2235&cat=3207&fin=3209&idioma=78
It's a type of MDF that is about 1/2 the weight of the regular stuff. It's not cheap, but it's a great smooth substrate if you're going to paint or apply sideart. I've laminated it with good results. However, plywood might be a better alternative when doing that since it is probably cheaper (and easier to come by).
DarakuTenshi
« Reply #15 on: March 30, 2017, 12:16:50 pm »
Wow, nice to see so many varied responses. Thanks all!
newimaging
  • Last login:April 10, 2017, 04:40:46 pm
  • Building an arcade for kids with homemade UE4 game
« Reply #16 on: April 02, 2017, 02:07:29 pm »
When you apply laminate onto the Sandeply, which is what I build with, did you prime it or paint it to prep for the Laminate, or glue straight onto the sandeply ?
« Reply #17 on: April 03, 2017, 04:09:31 pm »
Glue to wood.  You don't need to prep paint ---- but if you have any areas you aren't going to laminate (inside panel lip by t-molding) rattle can those first.
Qawsed11
  • Last login:September 23, 2017, 12:32:01 pm
  • Bartop maker and arcade restorer
« Reply #18 on: April 10, 2017, 12:13:48 pm »
I really like using 3/4" mdf. Easy to shape. Strong as heck.
newimaging
« Reply #19 on: April 10, 2017, 04:41:33 pm »
Thanks, have any of you taken the graphics right up to the edges and then folded them over to be tucked under the T-Molding for clean edges ? How well did that work with rounded edges and scoring them?
« Reply #20 on: April 10, 2017, 05:28:14 pm »
I do that with all my art.  Rounded edges just slit every few mm and tuck it down.
  • Last login:Today at 12:37:37 pm
« Reply #21 on: April 10, 2017, 05:42:18 pm »
Watch from 8:35- 13:53.   ;D
sKott
  • Last login:October 11, 2018, 12:19:09 am
« Reply #22 on: April 12, 2017, 01:06:50 am »
Laminated Russian Birch Plywood
sKott
