Author Topic: Mega Man and Duck Tales (woo hoo)  (Read 74325 times)
Titchgamer
Re: Duck Tales (Woo Hoo) and Mega Man
« Reply #40 on: November 18, 2016, 11:17:40 am »
My vote would go for this also.
Simple but easy to recognise.
Wyo
« Reply #41 on: December 09, 2016, 03:21:02 am »
So here is the speaker panel work in progress for a Mega Man.  I liked the suggested slot design, but It figured since I'm departing away from that style with Duck Tales, I might as well try something new, push it ,and challenge myself by trying to use the dimensional 8 bit "1 UP" Mega Man face.  It was really tricky to do because of all the drilling, which messed up the back of the panel so I had to do a lot of repair work.  Here it has two coats of primer, it still needs sanding and a bit more touch up to smooth it out more.
Also, I found this cool image while searching for E tank art references.  I thought one of the coasters would be a perfect inspiration for a bezel starting point.  I like the two on the left the best.  Since its winter now, I'd like to spend the next five months getting the artwork sorted out and complete before I even thinking about cutting wood.
« Last Edit: December 09, 2016, 03:30:21 am by Wyo »
  • Last login:Today at 09:19:57 pm
« Reply #42 on: December 10, 2016, 10:41:42 am »
Awesome work!
As far as messing up the back of the panel, I've had good luck clamping a backer board on before drilling and the technique I use is to reduce pressure about 3/4 of the way through and let the drill do the work and not force it through. Even with that, it's not always perfect, but it greatly reduced the blowouts I was getting.
Wyo
« Reply #43 on: December 11, 2016, 02:53:16 am »
Thanks for the tip, sir!  I will try that in the future.  Yeah, I've never had it happen that bad but I just assumed it was because of the large amount of drilling I was doing in such a small area.  I did clamp it down to another piece of wood, drilled pilot holes, then drilled in reverse with the bigger bit....but still it was pretty messy.  I just ended up bondo ing the back of the wood, then cleaning up most of the slots with a Dremel and drill the holes again.  A CNC machine sure would have been nice. Haha.
« Last Edit: December 11, 2016, 02:56:30 am by Wyo »
cj138
  • Last login:May 23, 2018, 06:56:39 pm
« Reply #44 on: December 13, 2016, 07:45:56 pm »
That Megaman grill looks sick! Outstanding!
Wyo
« Reply #45 on: January 05, 2017, 03:45:05 am »
I picked out the colors for the cabinets. Electric blue for MM, Purple for DT.  I will not purchase them until summer...but I did pick up a couple of bottles of flake, because...why not?  :)
THe MM will have dark contrasting blue t molding, which I already purchased.
« Last Edit: January 05, 2017, 03:49:01 am by Wyo »
Wyo
« Reply #46 on: January 05, 2017, 03:58:40 am »
I've spent the last month vectoring images for MM. I pretty much done, so I can start designing.  I came up with this marquee tonight.  I want the artwork to be prodominately dark blue, to contrast the lighter blue paint job and match the dark blue t-molding.
Also, I used "Nintendo" in the marquee.....as opposed to capcom....which I did vector a logo for.  I just liked Nintendo better.....but what do you guys think? Should I switch it...does it really matter? I don't really care but Any MM purists gonna be all, "but it's not a nintendo game!" Haha
Also, as far as theme.  Man, I really like Mega Man 2....widely considered the best MM game out of the series.  however, I'm using all Mega Man 1 artwork for this cabinet.  I tried to find a Image for Mega Man that was closest to the tiny black and white Mega Man in the original NES instruction manual....so it fits in with the rest of the artwork from that time.  if you remember, the original NES MM box art had some weird space dude on the artwork....not gonna use that.
I used the grid from the NES box art, which I will use with thr CPO and bezel as well.  I thought it would be cool to throw a pink laser beam across it, to mimic MMs gun.  i was thinking of lighting the underside of the cabinet with a pink LED light as well.
Also, on Christmas I downloaded Street Fighter X Mega Man.....omg (I never use omg, but this game deserves it) what a badass game! We spent most of the day trying to beat it....and now I really want to build a cabinet for it! Ha.  It's an exe file...so I might end up throwing it in this cabinet.
« Last Edit: January 05, 2017, 04:26:37 am by Wyo »
Wyo
« Reply #47 on: January 06, 2017, 10:46:44 am »
I spent the night designing two rough drafts for the MM bezel.  With MM, I am still doing s "donkey kong style" of artwork....where the corners have main characters and then minor scenes or characters along the borders.  When I do Duck Tales, I want to get away from that....and make the art more like Popeye, DK JR, DK3, etc....where the bezel and CPO art are not contained within a structured design.
Here was my first design....kinda busy....but uses the boxes for all the bosses like in the game menu. Sorry for the usual crappy art pics...but you get the idea.
Here is my second design....I like this one more because I get to see the bosses full bodies...and a lot more negative space.   I may shrink/move around the secondary bosses....may have a slight hierarchy issue.  Also, I may get rid of the logo on the bottom and replace it with something else....like MM shooting at something.  Seems kinda redundant.   May or may not incorporate blue chrome where the light blue artwork is....I was planning on it....but now I'm thinking I may just let it stand on its own.
« Last Edit: January 06, 2017, 10:55:43 am by Wyo »
Titchgamer
« Reply #48 on: January 06, 2017, 11:06:14 am »
I actually prefer the 1st one.
Not sure why, I think it just fits better with the boxes and looks more symmetrical.
But I would agree loose the logo, maybe more game controls in instead?
markc74
  • Flipping out
« Reply #49 on: January 06, 2017, 11:18:11 am »
I prefer the 1st one too. Seems less busy and distracting.
« Reply #50 on: January 06, 2017, 11:40:07 am »
why not screencap or snipping tool? You're like my end users, sending me cell phone pics of computer screens for support issues.
Wyo
« Reply #51 on: January 06, 2017, 11:40:24 am »
Hmmmm....interesting.  I can see why you guys prefer that one...tough call.  I'll play around with both and see what I can do.
 I like the first one as well....but the only thing I'm thinking about is losing to much of the dark blue with that design.   Maybe I change the sub bosses box colors...or the darken the backgrounds in the to differentiate/contrast them from the four corners...
Thanks for the input!
BorgDog
« Reply #52 on: January 06, 2017, 11:48:06 am »
It's even better when they put said crappy cell pic in a word document and e-mail you the word document.
I actually like the second one better, but agree with all about the logo at the bottom.
My Projects:
« Reply #53 on: January 06, 2017, 11:57:42 am »
I've gotten power-points because "that's only way I know how to put a picture in an e-mail!"
Wyo
« Reply #54 on: January 06, 2017, 12:07:22 pm »
Sorry dudes, Ive already said it a million times I'm the worst computer user ever.  I'd rather be up  and about doing something hands on.....then click, click, clicking away.  The less clicking in my life, the happier I am....so again...sorry.  However when I do design proofs professionally, know I always make jpgs.  Just lazy for my friends here, I guess.
---my bottom--- was literally numb from sitting for hours working on this art.  I don't know how you IT/computer genius guys do it. Better men than me.  :)
vwalbridge
« Reply #55 on: January 06, 2017, 01:50:57 pm »
Mega Man II > Mega Man
Street Fighter II = Mega Man II
Mega Man = Street Fighter
markc74
  • Flipping out
« Reply #56 on: January 06, 2017, 02:55:37 pm »
You'd make a terrible coder  >:D
vwalbridge
« Reply #57 on: January 06, 2017, 02:57:43 pm »
You are correct! Rep for you!
sokignano
  • Last login:February 09, 2022, 01:52:41 pm
« Reply #58 on: January 06, 2017, 09:58:40 pm »
I choose #2! But I also like the boarders around the characters too. But if I am honest with myself. I like 2 the best :)
Wyo
« Reply #59 on: January 07, 2017, 01:25:54 am »
Thanks! #2 is more than likely the one I'm gonna go with after resizing the sub bosses, eliminating the logo, and moving some things around.  However, I have an idea for one other design I want to try.
Also, thanks to Sokignano for once again hooking me up with a great starting point for the CPO instruction card.
« Last Edit: January 07, 2017, 01:28:01 am by Wyo »
Wyo
« Reply #60 on: January 07, 2017, 05:49:41 am »
I reduced the size of the mini bosses, eliminated the logo on the bottom....I would eventually replace it with something else. I like this design a lot....but I felt like its missing something...like uniqueness...and I really want to incorporate an embossed look again with this cab.
I had a new idea tonight for a third design while running on the treadmill....and I think Im leaning heavily towards it.  In the begining I wanted to capture the mechanical aspect of the robots...I thought about using gears or soemthing in the artwork, but then I thought about using PCB traces.  I thought it would look really cool cut out of blue embossed chrome foil...so I came up with this third design tonight. I like it because I can use the trace elements on the CPO as well for the buttons.
« Last Edit: January 07, 2017, 05:52:23 am by Wyo »
thomas_surles
« Reply #61 on: January 07, 2017, 06:05:29 am »
I really like the circuit board design of the bottom one, but I still can't decide between the two.
Titchgamer
« Reply #62 on: January 07, 2017, 06:27:00 am »
Ime liking the PCB design :) Would look ace with the foil you mentioned.
I think It would be better putting the boss on the bottom on the left (2 on each side) and the having a instruction card or something at the bottom though.
Wyo
« Reply #63 on: January 07, 2017, 06:34:38 am »
Looking at it now I can see the left and bottom traces are smooshed a bit more than I'd like.  I will spread those out more...I think I need to flip Fireman around too...so he's facing inwards.
I see what you are saying about having two bosses on the left.  I can't really do an instruction card on the bottom of the bezel tho because I'll have an instruction card on the CPO as well as below the bezel above the CPO, the standard Nintendo placements.   I will think about your sugestions...maybe I can find something else in the bottom center....I just wanted to differenciate this bezel from my LOZ build...where I put the triforce in the center.  Open to suggestions.
Thought about putting Dr. Wiley's castle in the center bottom of the top design....but that wouldn't work with the PCB design i don't think.
« Last Edit: January 07, 2017, 06:38:21 am by Wyo »
Titchgamer
« Reply #64 on: January 07, 2017, 06:39:17 am »
Afraid I never really played MM so wouldnt know what else to suggest that would be cool or fit with the theme :p
Maybe another logo/title or a scene or something?
Wyo
« Reply #65 on: January 07, 2017, 06:40:21 am »
Thanks! I can't decide either....I'm leaning towards the PCB design because I think it'll be more fun.  Maybe I'll print both! Haha.
Wyo
« Reply #66 on: January 07, 2017, 06:47:24 am »
Maybe a slightly bigger circle with Dr. Wiley's castle inside.  Thanks! I'll try it out.
Titchgamer
« Reply #67 on: January 07, 2017, 06:57:29 am »
Happy I could not help in the slightest LOL  :lol
Wyo
« Reply #68 on: January 07, 2017, 07:37:05 am »
Haha.  :cheers:
thomas_surles
« Reply #69 on: January 07, 2017, 07:42:08 am »
After staring Thursday them for an hour now, I am set on the pcb design. I've seen the grid a million times on mame cabs.
« Reply #70 on: January 07, 2017, 02:51:49 pm »
Did you get the speaker panels cut yet? I was wondering if it would make more sense to use a solid piece of wood instead of plywood.
Wyo
« Reply #71 on: January 07, 2017, 03:56:17 pm »
Yeah, the speaker panels are done. See post #41 at the top of this page.  Why about the solid wood as opposed to plywood? Less blowout?
« Reply #72 on: January 07, 2017, 04:31:15 pm »
Yeah, I saw the post, but I actually couldn't tell if the white megaman strip one was cut from wood or drawn on a piece of paper.
The idea was that cutting it would give you less splintering.
Wyo
« Reply #73 on: January 07, 2017, 06:44:46 pm »
Oh, okay.  No, the Mega Man grill panel is wood, I just primed it already.
You know, Now that you mention it when I made my fix it Felix I used a piece of pine lumber for the speaker grill and had essentially no blowout on the backside.  I got away from using that wood because I read it was more unstable as far as expansion and contraction than the plywood.   But there was never an issue with it once it was done.  I'll keep that in mind for the next one....and try switching woods.
« Last Edit: January 08, 2017, 11:16:49 am by Wyo »
OldSkoolFool
  • Last login:November 26, 2018, 08:07:39 pm
    • CosmotronsGame.com
    • Cosmotrons
« Reply #74 on: January 08, 2017, 06:04:38 pm »
Absolutely love it.  I am looking forward to seeing further progress.  The artwork looks great so far.  I am partial to Mega Man 2 so would have gone that direction though.  This might be a bit too much but what about adding a topper (like pinball machines might have) or even some plastic "toys", also like some pins have.  Maybe blue etched and lit plexi, multiple layers on the top side of the machine or even as the marquee.  Behind the bezel, maybe something like this or smaller and lit up with blue LEDs or something when the game is turned on:  https://youtu.be/uhxADc8Tto4?t=2m43s
Our custom arcade project has turned into an actual arcade product now in arcades from the West Coast to the East Coast.  Check it out at:  www.CosmotronsGame.com
Wyo
« Reply #75 on: January 09, 2017, 07:18:25 am »
Thanks to Sokignano for giving me a great starting point for the instruction card. Its about 98% there....I need to make some minor tweeks like move the "robots" line over a bit to the left in the title heading.  Add an exclamation point after "press the jump button" and maybe mess with the type spacing.    Im about 75% done with the CPO as well.  Hope to get a finished proof by tomorrow.
« Last Edit: January 09, 2017, 07:45:17 am by Wyo »
Wyo
« Reply #76 on: January 09, 2017, 07:48:56 am »
That helmet is awesome! I gotta get one....for a topper, like you said.  Yeah,I was thinking of adding pink LED lighting somewhere.  Sokignano suggested making it pulse to the sounds of the game....not sure of how to go about that....but I'd like to try.
Yeah, I get it about Mega Man 2.  I felt that I had to start at the beginning though...I like the bosses better in two as well.  However, this will be a Mega Man multi so I'll at least get to play the others. :)
« Last Edit: January 09, 2017, 07:54:48 am by Wyo »
« Reply #77 on: January 09, 2017, 08:45:49 am »
Ya know, if you go to your very first post in the thread, Wyo, and edit it...you can change the title and then I won't get all excited and get the Duck Tales theme stuck in my head.  Freakin earworm for dayz bro.  I mean, unless duck tales is happening.  is it happening.  I want ducktales!
Megaman art is looking good btw, I like the approach.
« Last Edit: January 09, 2017, 08:47:25 am by Le Chuck »
Wyo
« Reply #78 on: January 09, 2017, 09:43:16 am »
Hahaha. ;D sorry man.   There is some Duck Tales happening on this thread....well, just the speaker panel. Ha. I switched it around to reflect MM being worked on first. :)
As soon as I get the artwork squared away for MM (should be done next week, yes including sideart) I'm gonna start vectoring and designing Duck Tales.  And yeah, I put the "woo hoo" in the title for a reason. It's just So catchy!  :cheers:
« Last Edit: January 09, 2017, 09:56:44 am by Wyo »
Locke141
  • Never grow up.
« Reply #79 on: January 09, 2017, 09:44:59 am »
This is looking very nice.
Have you ever played "Mega Man: The Wily Wars"? It's like Mario All-Stars but it's the first 3 Mega mans ported to the Genesis.
