Author Topic: Replacement for this small button?  (Read 1334 times)
« on: November 08, 2016, 02:50:11 pm »
Hi all,
I'm looking for replacement pushbuttons for my cocktail P1 and P2 buttons.  I tried ordering the same ones that were there and they are cheap and fire off randomly starting games on it's own.   :banghead:
Here's what I ordered (Exact replicas of what was on there):  https://www.walmart.com/ip/5-Pcs-AC-250V-3A-NO-SPST-Momentary-Red-Push-Button-Switch/46512580
What I'm really looking for is the diameter so that I can grab a quality arcade button and swap out the bad ones.
Any leads?  Thanks in advance!
DeL
JDFan
Re: Replacement for this small button?
« Reply #1 on: November 08, 2016, 02:54:34 pm »
Hi all,
DeL
According to the specs in the linked item
Specifications:
Item Name Push Button Switch Contact Type NO, SPST Switch Type Momentary Switch Working Voltage AC 250V, 3A Switch Color Black, Red Pin Number 2 Button Diameter 11.8mm/ 0.46" Mounting Thread Dia. 11.4mm/ 0.45" Total Size 39 x 18mm/ 1.53" x 0.71"(L*D) Material Plastic, Electronic Parts Weight 24g Package Content 5 x Push Button Switch
SO looks like total dimension for outside is 18mm - so maybe something like these 16mm mounting hole arcade service buttons would work - ( http://www.dhgate.com/store/product/20pcs-service-button-small-push-button-switch/255947417.html )
« Last Edit: November 08, 2016, 03:06:19 pm by JDFan »
  • Last login:Today at 12:51:52 am
« Reply #2 on: November 08, 2016, 03:15:10 pm »
Divemaster has "Type A Miniature Round Pushbutton, Red Center" here.
They are Happ part # 49-0577-00.
or
Arcadeshop carries the "Midway Cocktail player start Push Button (Red)" -- not sure about the diameter.
  • Last login:Today at 01:07:36 am
« Reply #3 on: November 08, 2016, 03:18:33 pm »
Should be some deals going at DHGate on 11/11....
