Author Topic: Space invaders cocktail  (Read 3882 times)
trendy21
  • Last login:January 27, 2023, 08:11:48 am
  • Alright, Alright, Alright
« on: October 25, 2016, 09:09:08 pm »
Hello I recently acquired an old space invaders cocktail from my grandfather who passed and would like to restore it but I can't find the keys for the coin door or the back access panel and google is pretty scarce on answers any ideas.  Thx
Re: Space invaders cocktail
« Reply #1 on: October 25, 2016, 09:29:27 pm »
Drill the locks.  Start with a small bit and work your way up gradually until you strip the cylinder teeth.  Then you should be able to either push the lock cylinder out the back or turn it with a screw driver.  Just measure what you bore so you can get replacements at your local big box - usually in the same aisle as the drawer pulls.
trendy21
« Reply #2 on: October 25, 2016, 10:55:24 pm »
Any chance of getting replacement keys?
  • Last login:Today at 03:58:12 am
« Reply #3 on: October 25, 2016, 11:46:35 pm »
Close to zero.
It's much easier/faster/cheaper to drill/pick the lock than find a replacement key.
  • Last login:October 27, 2025, 06:16:21 pm
« Reply #4 on: November 02, 2016, 01:13:07 pm »
a new lock is like 6 bucks. you aren't losing anything by replacing it besides the inability to open it.
https://www.homedepot.ca/en/home/p.58-inch-chrome-cam-lock.1000109529.html
if you want to search your local stores you are looking for a "cam lock" the one I linked above happens to be 5/8ths of an inch long but go from almost nothing... all the way to 1 3/8 and bigger. so just keep the cylinder part that screws into the door and take it to your store and match up a new one.
if you are really stuck and don't have much for hardware stores in your area... a locksmith. it will be a little more expensive for the lock, but they will have one for sure.
8BitMonk
« Reply #5 on: November 02, 2016, 03:48:28 pm »
Whole bunch of videos on it, watching one done may make you more comfortable doing it.
https://www.youtube.com/results?search_query=arcade+drill+lock
