Author Topic: 80s style wrestling marquee....SIDE ART!  (Read 20504 times)
reptileink
  • An 8 bit hero
Re: 80s style wrestling marquee....SIDE ART!
« Reply #40 on: October 26, 2016, 09:33:53 am »
What else would you suggest? A full circle would look pretty silly running behind the text. This will be a die-cut image, not having a white background. Only thing I can see this morning is that the "circle" text needs to be a bit lower.
« Last Edit: October 26, 2016, 09:35:54 am by reptileink »
« Reply #41 on: October 26, 2016, 09:57:25 am »
shrink the circle and move it down, have the wrestlers head pop out a bit, like I did in the martijn style art
Just makes them pop more.
reptileink
  • An 8 bit hero
« Reply #42 on: October 26, 2016, 10:02:24 am »
I'll try that when I get home tonight. Otherwise, I think I have a good tie-in.
Does Stpcore do what I am calling "Die-cut" IE: The image has a transparent background (not the white you see), or does it need to have some kind of white border around it?
« Last Edit: October 26, 2016, 10:14:51 am by reptileink »
Titchgamer
« Reply #43 on: October 26, 2016, 10:33:50 am »
Yeah that will work better I think.
« Reply #44 on: October 26, 2016, 10:35:49 am »
POST IT AT THE FORUM!
I CAN'T SEE IT ON MY PHONE OR ON HERE AT WORK!
reptileink
  • An 8 bit hero
« Reply #45 on: October 26, 2016, 10:57:17 am »
You know what's weird is, I hosted it on imgur because Photobucket is blocked at work, and while I can go to the Imgur website and see it, I can't see it in the forum either. To add to that, I CAN see the marquee which is also hosted at Imgur. Wonder if it's due to the size? It worked fine at home last night. Sorry, I should know better as half the project threads I look at have no images due to work block. So dumb.
EDIT: Alright, was able to get it saved and uploaded.
« Last Edit: October 26, 2016, 12:22:06 pm by reptileink »
« Reply #46 on: October 26, 2016, 01:07:13 pm »
It's good, matches the theme you're going for, I agree with Malenko about the circle.
« Reply #47 on: October 26, 2016, 03:49:53 pm »
sli.mg is the new hotness.  Quit using imgur.
reptileink
  • An 8 bit hero
« Reply #48 on: October 26, 2016, 04:16:39 pm »
Also blocked....lol
reptileink
  • An 8 bit hero
« Reply #49 on: October 26, 2016, 08:27:45 pm »
  • Last login:Today at 02:35:06 am
« Reply #50 on: October 26, 2016, 09:03:28 pm »
Looking better.   ;D
Here are a few more things you may want to consider.
* The blue oval isn't visible through the gap between "SQ" -- not sure if it should be or not because of the curve.   :dunno
* Legs  cut off/not visible through gaps in the letters "UAR".
* The dot over the "i" is messed up.
« Reply #51 on: October 26, 2016, 09:06:58 pm »
If you're using a current version of photoshop to do the art you can render the text as a shape and do your strokes in the shape tool menu, that will give you sharp rather than rounded corners and help crisp up the red.  Looks a little soft as is.
reptileink
  • An 8 bit hero
« Reply #52 on: October 26, 2016, 11:20:38 pm »
Looking better.   ;D
Good call. I knew I had some things to fix. How's this?
Le Chuck, I have Photoshop Elements 7. Not sure what you mean about strokes (sorry, not the most learned PS guy). I like it, but I agree, the red could be a tad sharper
« Reply #53 on: October 27, 2016, 12:24:18 am »
The dot on the "i" looks great.
The legs look much better, but now there's a flat-top red-triangle copy/paste artifact at the bottom of the trunks.
I'm still not sure about the amount of blue visible through the "Q".   :dunno
Maybe it's just the vertical placement, but it seems like you should be able to see a bit of the gray center and the black oval-border.
How would it look if you bring the bottom of the oval down just a little so you can see the black border and gray background through the "Q"?
Titchgamer
« Reply #54 on: October 27, 2016, 04:41:54 am »
I think you want to make the guy a little bigger so his head sticks out a little more.
That will basically loose the oval and eliminate the abrupt stop thing I mentioned earlier as it will break it up.
You could also blur the parts where the blue meets the wrestler etc.
Or you could try a bevel/emboss on the wrestler/text that might make it pop a bit.
As a crazy idea you could also adjust his face paint to look like warrior lol
« Reply #55 on: October 27, 2016, 08:01:17 am »
Stroke is the outline of text.  Looks as tho you have a red inner stroke and a black outer stroke - but it could be two layered outer strokes.  At any rate, as Photoshop is primarily a raster tool is uses a few different functions to calculate radius for strokes.  It doesn't handle sharp corners well as it is move pixels around. More recent versions of the program allow one to convert the text to a vector object and using the vector values give nice sharp corners to the stroke.
AFAIK, elements 7 doesn't have that capability.  At any rate, it is a nit-picky thing.  Overall your art looks great so if it's beyond your software's capability I wouldn't even worry about it.
reptileink
  • An 8 bit hero
« Reply #56 on: October 27, 2016, 09:52:19 pm »
Work officially  "banned" me from coming here at work in the form of a warning  :angry:
Anyway, here is the final
« Reply #57 on: October 27, 2016, 10:06:21 pm »
Looks as tho there is some ghosting around your wrestler.  Might want to color match his black outline and hit him with a center aligned stroke of the same color a few pixels in either direction to clean up that edge a bit.  Should cover up that fuzzy whiteness.  (layers panel, edit, stroke)
« Reply #58 on: October 27, 2016, 11:11:26 pm »
Looks good.   ;D
reptileink
  • An 8 bit hero
« Reply #59 on: October 29, 2016, 01:35:59 pm »
Got it
mike boss
« Reply #60 on: November 20, 2016, 10:46:38 am »
As a wrestling fan I really like this.
I has a nostalgic feel to me.
Good work.
