Author Topic: GroovyMAME 0.227 - Switchres v0.017t  (Read 760592 times)
0 Members and 10 Guests are viewing this topic.
b4nd1t0
  • Last login:February 11, 2025, 01:35:18 am
    • b4nd1t0's repository
Re: GroovyMAME 0.200 - Switchres v0.017i
« Reply #800 on: October 22, 2018, 05:48:35 am »
Hello,
I'm using your build and i can't get hiscore to work...
What i did :
- create a "plugins/hiscore" folder and put hiscore.dat in it
- set "hiscore 1" in plugin.ini
- set "plugins 1" and "plugin hiscore" in mame.ini
- create a "hi" folder
Did i miss something or is it your mame version that is incompatible with hiscore support ?
hi, the version is fully compatible, to avoid mistakes I suggest you to download the unpatched version of mame, create the ini with mame64 -cc and then copy groovymame64.exe in the folder, I always follow this procedure and I never had problems
  • Last login:January 23, 2026, 06:10:10 am
Re: GroovyMAME 0.203 - Switchres v0.017k
« Reply #801 on: November 02, 2018, 08:12:56 am »
GroovyMAME v0.203 is out!
What's new in Switchres v0.017k (November 2018)
- Modeline generation now possible from 15 kHz up to 8K fulldome. Bandwidth limitations imposed by drivers still apply.
schmerzkaufen
« Reply #802 on: November 02, 2018, 08:21:34 am »
YEEHAAW!! time to ride that beast.  8)
pmc3
  • Last login:October 21, 2025, 04:15:51 pm
  • 404
« Reply #803 on: November 02, 2018, 08:26:06 am »
d3d9ex bin pliz ^_____^
« Reply #804 on: November 02, 2018, 08:27:30 am »
pmc3
  • 404
« Reply #805 on: November 02, 2018, 08:31:45 am »
lol, great. Thanks for your work ;)
« Last Edit: November 02, 2018, 08:34:27 am by pmc3 »
josete2k
  • Last login:February 07, 2025, 08:39:53 pm
« Last Edit: November 02, 2018, 03:39:27 pm by josete2k »
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #807 on: November 02, 2018, 05:52:33 pm »
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
« Reply #808 on: November 02, 2018, 08:43:37 pm »
Would somebody be so kind to compile the x64 d3d9ex nonag version?
Doozer
  • Z80 ERROR
« Reply #809 on: November 03, 2018, 04:51:56 am »
Hi Calamity,
As usual, many thanks for this release.
Would it be possible to have the system impacted together with the release of a new feature/function? I assume the modeline generation mentioned above is for Windows OS, am I correct?
Best
« Reply #810 on: November 03, 2018, 12:48:21 pm »
This change is OS-independent. Basically it's an update to the bandwidth sanity checks that were reasonable a few years ago but now were preventing Switchres from handling 4k resolutions.
Doozer
  • Z80 ERROR
« Reply #811 on: November 04, 2018, 03:04:23 am »
Thanks Calamity for the clarification.
The Groovymame Linux binary is now available on the drive as well.
Cheers!
b4nd1t0
« Reply #812 on: November 04, 2018, 05:40:30 pm »
Thanks calamity for the new patch.
The new version 0.203 groovyv0.017k+d3d9ex+nonag available ->here<- on the repo, as usual.
Simo
  • Last login:March 02, 2023, 12:02:26 pm
« Reply #813 on: November 05, 2018, 02:51:03 am »
Hi, but there isn't a 32bit version of .201?
schmerzkaufen
« Reply #814 on: November 05, 2018, 04:27:45 am »
No wolf version this time b4nd1t0, or is the link broken ?  ;)
b4nd1t0
« Reply #815 on: November 05, 2018, 04:58:07 am »
I'm working on it, give me two hours and it's ready  ;D
Update: groovywolf ready!
« Last Edit: November 05, 2018, 06:18:44 am by b4nd1t0 »
schmerzkaufen
« Reply #816 on: November 05, 2018, 06:28:19 am »
Thanks!  8)
Simo
« Reply #817 on: November 05, 2018, 03:46:53 pm »
thank you very much for your availability .
Wolf but I can’t see the 32bit version of .201
« Last Edit: November 05, 2018, 03:50:50 pm by Simo »
tom5151
  • Last login:September 16, 2023, 09:21:11 am
« Reply #818 on: November 05, 2018, 03:56:50 pm »
Thanks @Calamity and @b4nd1t0
Envoyé de mon ONEPLUS A5000 en utilisant Tapatalk
b4nd1t0
« Reply #819 on: November 05, 2018, 04:49:14 pm »
Sorry but I don't compile anymore the 32 bit versions.
Inviato dalla batcaverna utilizzando Tapatalk
Simo
« Reply #820 on: November 06, 2018, 12:42:55 am »
[/quote]
Ok, thanks anyway ;)
« Last Edit: November 06, 2018, 12:45:11 am by Simo »
Simo
« Reply #821 on: November 06, 2018, 12:46:46 am »
Ok, thanks anyway
pmc3
  • 404
« Reply #822 on: November 29, 2018, 05:45:42 am »
groovy32 is available on emufrance with each new version of official (mame+groovy).
edit: 204 here: http://www.emu-france.com/news/58037-multi-systemes-groovymame-v0-204-switchres-v0-017l/
« Last Edit: November 29, 2018, 10:40:33 am by pmc3 »
Re: GroovyMAME 0.204 - Switchres v0.017l
« Reply #823 on: November 29, 2018, 06:53:42 am »
GroovyMAME 0.204 is out!
What's new in Switchres v0.017l (November 2018)
- Fix issue where 4K pixel clocks caused an overflow in the modeline engine. Now Switchres can properly pick 4K video modes. However, AMD drivers will still reject custom 4K timings so, until this gets fixed, use the -nomodeline_generation in GroovyMAME when running on 4K monitors.
b4nd1t0
« Reply #824 on: November 29, 2018, 07:18:22 am »
Great, thanks!
New version 64bit, nonag etc. usual place ->here<-
« Last Edit: December 03, 2018, 07:58:58 am by b4nd1t0 »
josete2k
« Reply #825 on: November 30, 2018, 11:30:03 am »
Thanks Calamity.
As usual, the 204 arcade with nonag and 32 bit:
https://mega.nz/#!aUwAWIYI!BrKdjhObs4tfpCw3678k3e4Z6uoHc1TMf_kobcSoFZE
dilarconon
  • Last login:April 02, 2020, 03:27:34 am
« Reply #826 on: December 26, 2018, 06:48:57 am »
The 204 diff does not work with mame 0.205 (not surprising).
Is there diff file for 0.205?
haynor666
  • retro maniac
« Reply #827 on: December 26, 2018, 01:40:45 pm »
Nope
« Reply #828 on: December 27, 2018, 07:43:53 am »
Here's a diff for v0.205. I've dropped BGFX support on this one, temporarily until I find the time and mood to redo it (the BGFX library has suffered a major rework and everything needs to be redone, it took me weeks the first time).
haynor666
  • retro maniac
« Reply #829 on: December 27, 2018, 09:09:04 am »
Sliders saving function is not implemented in this patch?
schmerzkaufen
« Reply #830 on: December 27, 2018, 09:59:46 am »
He mentioned an issue with the frame_delay slider, so it's too soon to add this to the official diff I guess.
haynor666
  • retro maniac
« Reply #831 on: December 27, 2018, 10:51:39 am »
Right, I forgot about this.
« Reply #832 on: December 27, 2018, 11:09:48 am »
I'm working on it atm. The 205 diff I uploaded doesn't have the save sliders feature, I posted it just in case someone didn't want to wait.
donluca
  • Last login:January 23, 2026, 08:15:39 am
« Reply #833 on: December 27, 2018, 01:50:21 pm »
For us CRT users, does BGFX offer any improvement over other video drivers?
2.- Inflatable dolls
u-man
  • Last login:May 20, 2024, 03:53:16 pm
« Reply #834 on: December 27, 2018, 02:12:18 pm »
IMHO the only advantage over other drivers is that it works with any OS (Linux, Mac OS X, Windows), but thats all. In theory there could be more advantages, if the Full potential would be used, but this would require more improvements in the coding.
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
schmerzkaufen
« Reply #835 on: December 27, 2018, 03:16:39 pm »
It was supposed to cure cancer and turn water into wine, but it's still worse than D3D/D3D9ex overall.
No, to be fair some games perfom better with it, but that's all I can remember for the pros.
The cons: no solution for the lag yet, and shaders settings don't save.
In short it tells people to stick to D3D/groovy, or retroarch...
dilarconon
« Reply #836 on: December 28, 2018, 03:34:22 am »
I really appreciate this attitude. I know we're just at the mercy of your schedule and you had full right to release anytime, but thank you so much for that diff file.
We were able to have friendly comp at our lan party with the best version of MAME  :applaud:
« Reply #837 on: December 28, 2018, 07:09:33 am »
With regards to BGFX, the author has added an option to set max frame latency, in the same way we do it in D3D9ex. As far as I know, baseline MAME is not benefiting from this feature yet, but it'd be trivial to add it.
The main concern for us with BGFX is that it doesn't support full screen exclusive rendering. Its documentation says "not implemented yet". Based on the web the feature has been requested to the author a few times already. He probably has other priorities, that's understandable. Probably he expects full screen exclusive mode will be deprecated anyway in a near future, so if he postpones it long enough it will become unnecessary.
My previous "implementation" of fullscreen exclusive mode through BGFX was a hack around the D3D11 backend, which obviously got broken as soon as the author made a serious rework of his code. Now after thinking of it, I believe it's a bad idea to even try again.
The main problem, imho, is that the interface itself of bgfx initialization only takes width and height, while targeting video modes accurately requires at least width, height and refresh (3 params), I say at least because it's desirable to also take interlace as a param. This oversimplification of the video phenomenon is an issue with most emulators, by the way, and the reason behind most compatibility problems with custom video modes, due to emulator authors' indifference or plain ignorance about video nature.
Having to add more params to the interface involves bulk changes all through the api. This could only be done in a clean, consistent way, by the author himself. For me, even figuring out what that code does is very difficult. It's written by a genius, but he didn't write it for others to understand.
With regards to GroovyMAME, not having support through BGFX seriously limits the viability of the project in the future. It might lead to a final project stall, or maybe an unlikely scenario where there's a completely separate backend for CRTs without any fancy shaders or anything (a major and unlikely to happen undertaking), and BFGX (hopefully with proper latency) for everyone else.
dilarconon
« Reply #838 on: December 28, 2018, 08:35:10 am »
Hey Calamity, I couldn't get a clear answer from Google.
Is you have an LCD and G-Sync, how many GroovyMAME frames are improved in terms of input lag?
disable_loading_patch     1
monitor                   lcd
lcd_range                 50-145
frame_delay               2
Other than the settings above, do I need to look into other things?
schmerzkaufen
« Reply #839 on: December 28, 2018, 09:39:38 am »
Hmm...your settings seem to indicate you mistake frame_delay for run-ahead, but they're not the same thing.
Also more importantly I believe if you have a G-Sync or FreeSync monitor you don't need lag reduction features such as these to get the minumum lag MAME can produce anyway.
Normally you just play without any vsync feature on and you're set, the games should play with a refesh speed and delay equal to the original hardware+game program's intended*, and without tearing.
That's the point of these nVidia and AMD technologies (and also HDMI 2.1 VRR afaik)
*As far as MAME drivers accuracy go individually, of course (some drivers require the intervention of other software included in MAME that might add a thread and/or frame on top, which is also why in theory multi-core CPU should provide an advantage in response)
