Author Topic: Hello from South England - Pinball machine Transformer hunt... any Ideas?  (Read 5576 times)
steveoc
  • Last login:July 29, 2016, 12:03:20 pm
Good morning to all, Newbie to this site, read a few posts and thought I would ask a questiion.
I have a Teenage Mutant Ninja Turtles pinball machine.
Was fully working until recently - (Moved To Hastings).
It started off with a large hum on boot, like  a bad earth on an amplifier.
Then it took longer and longer to fire up, I would switch on, the machine would hummm very loudly, even with volume turned right down.
After about 5 minutes, something would warm up and it would then switch on.
It is taking longer and longer now and also has a burning electrical smell to it.
I am assuming its the transformer, which has
010-5003-00   549-9121  115/230v 50/60hz
Before I splash out on an expensive replacement, anybody got any ideas whether this is it?
Are there any alternatives I can use - as a transformer is a transformer, what voltage does it step down too?
Thank you in advance
Steve
MTPPC
I'm not familiar with that specfic game, but your hum indicates either insufficient voltage in the 5VDC or A/C ripple on the 5VDC caused by a failing capacitor (prbably the largest one) on the power spply. Measure the 5VDC with both the DC reading and the AC. The DC should be 5.05-5.1VDC. the AC should be less than .15 VAC
http://pinballmd.com/
ed12
ya that's a data east
if u have the manual?
find the rectifier board, main power supply
start there
if u do not have the manual say so I will what I can dig up for ya
ed
Transformers work or they don't.  Your problem is elsewhere.
90% of the time with pinball machines, it's a connector problem.  Especially after a move.  Unplug and reconnect everything in the backbox.
If that doesn't do it, check power supply.
