Author Topic: Elf and Pandora box won't expand edge to edge  (Read 3137 times)
actman
  • Last login:April 18, 2024, 12:17:27 pm
« on: July 26, 2016, 11:28:33 am »
I run computer set up with Hyperspin in my arcade cabinet with a 25" arcade monitor, and the games work fine. When I connect a Elf or Pandora box 4 to my system the screen will have a 1" boarder on each side. I could try and adjust the horizontal coil but I doubt it will have that much adjustment in it. Its not a big deal but my fav game is joust and it's not very good when your bird gets to the edge and takes awhile to come out the other side.
Anyone have the same issue when running one of these multi game boxes? The Pandora box 3 actually was fine and displayed edge to edge!
« Last Edit: July 26, 2016, 11:32:11 am by actman »
Slippyblade
Re: Elf and Pandora box won't expand edge to edge
« Reply #1 on: July 26, 2016, 01:23:56 pm »
That's a known bug with those boards.  I run my Pandora from the VGA port and don't have the problem.  I wish I had a solution for you, but I don't think there is one.
actman
« Reply #2 on: July 26, 2016, 01:49:06 pm »
Thanks..... I did try the width coil but it only varies it slightly. I will build another cabinet with a vga monitor and set it up. The other two boxes I had worked fine on VGA and I will test this one now.
Funny how the first box Pandora 3 I bought worked fine!
Slippyblade
« Reply #3 on: July 26, 2016, 01:51:32 pm »
From what I've read, it's a bug that seems to present itself randomly per board.  Some boards do it and other don't, even within the same model.  It's probably a weird batch of hardware used in manufacture.
actman
« Reply #4 on: July 27, 2016, 04:01:13 pm »
Connected up a 20" VGA monitor and it also does not go edge to edge. It has adjustment for horizontal and vertical adjustment but not to expand outward or inward only to center the picture. Will have to find a monitor that does both
paigeoliver
  • Awesome face!
« Reply #5 on: July 27, 2016, 06:09:11 pm »
I have found on the multiboards that they are essentially impossible to adjust for width and the menu and the games are never the same width in the first place.
  • Last login:March 08, 2026, 07:17:46 pm
« Reply #6 on: July 27, 2016, 10:39:00 pm »
i've had this issue as well. it usually a matter of ramping UP the pixel clock and turning DOWN the horizontal.
haven't the foggiest why they do it.
maybe it's a 50hz vs 60hz thing.... board outputs 50 hz but the monitor expects 60? china is 50 hz.
 :dunno
paigeoliver
  • Awesome face!
« Reply #7 on: July 27, 2016, 11:18:22 pm »
 :dunno
They only care that it appears to work, not that it actually works.
actman
« Reply #8 on: July 28, 2016, 09:13:33 am »
While I have a Vertical issue along with the Horizontal width. The top of the screen is squished so the high score ect  is not readable in certain games.
It also does this with the menu system and in Test mode the title is all messed up. It just does not sync proper with an arcade monitor or at least mine.
Best bet is to use it with a VGA monitor. Seems all the new 24" monitors won't let me adjust vertical/horizontal size (expand in and out)
They only allow for position left and right adjustments and auto adjust. Does anyone know a monitor that handles V/H sizing?
« Reply #9 on: July 28, 2016, 10:36:23 am »
As I said in the other thread, if you want that, get a CRT.
actman
« Reply #10 on: July 28, 2016, 10:59:24 am »
Not sure what you mean. An arcade monitor is a CRT
« Reply #11 on: July 28, 2016, 11:16:39 am »
My mistake. I was thinking 24" LCD based on your other post.
