Author Topic: Retro Wonder - Mini Bartop  (Read 11526 times)
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« on: July 09, 2016, 05:37:35 pm »
My latest little project is now complete, the Retro Wonder:-
Retro Wonder 02 by Andy Baker, on Flickr
The concept
After finishing my cocktail cab (http://forum.arcadecontrols.com/index.php/topic,148135.0.html) I fancied building something else and as my daughter was so keen on the cocktail I thought it would be a perfect excuse to build her something. Then knowing the wife wouldn’t want another big machine in the house I decided on a bartop and taking inspiration from these two machines (http://forum.arcadecontrols.com/index.php/topic,113690.0.html & http://forum.arcadecontrols.com/index.php/topic,143657.0.html) I decided it would be a mini bartop.
Finished it today and just in time for her birthday next week.
Criteria
 * Small but useable
 * Artwork suitable for a 12 yr girl and not game/character specific
 * Utilise a Raspberry Pi (as RetroPie had caught my interest)
 * Fun!
Some pics of the finished article and if I can find the time tomorrow I'll collate the build pics and put a write up together.
Retro Wonder 01 by Andy Baker, on Flickr
Retro Wonder 03 by Andy Baker, on Flickr
Retro Wonder 04 by Andy Baker, on Flickr
Retro Wonder 05 by Andy Baker, on Flickr
Retro Wonder 06 by Andy Baker, on Flickr
thomas_surles
Re: Retro Wonder - Mini Bartop
« Reply #1 on: July 09, 2016, 06:06:40 pm »
Looks good. No build pics?
Vidiot
  • John 3:16
« Reply #2 on: July 10, 2016, 08:47:12 am »
Mission accomplished! Beautiful little bartop. I think the weecade style looks best when it's scaled down like this. Cool name, cute color scheme - especially for a young girl. Job well done.  :applaud:
I would love to see more on the build process.
GSXRMovistar
    • CoffeeCade
« Reply #3 on: July 10, 2016, 11:18:29 am »
Thanks. :)
The Build
No 3D mock up this time, due to it’s small size it would be easier to create the cab around the components.
First job was to break out an old tupperware box to test that all the components work.
 * Raspberry Pi3
 * 9” HDMI screen (via eBay)
 * USB Zero Delay encoder
 * Cheap stick and buttons
 * Pair of USB powered speakers (wanted a set with a physical volume control)
Once tested it was on to the fabrication side of things, new speakers immediately stripped down.
Control panel drilled (button layout drafted in illustrator first), then glued on the front panel. I Didn’t have an appropriate sized drill bit for the smaller buttons so some careful sanding with my Dremel to enlarge the holes worked. I used 12mm MDF for this with a router to round the edges.
With the control panel and other components to use as a size reference I made some side pieces out of cardboard, once happy with shape cut one from 18mm MDF. Router used to clone the second side.
With shape decided I could then finish off the artwork, I found some public domain vector art as a starting point, modified and coloured to match my daughters room (and favourite colour purple). Added a logo and was happy with the result.
Next I cut the speaker panel, rounded the edges, and made recesses on the rear to drop the speakers into.
Top piece cut, joined, with ventilation holes drilled. As you can see from the below I’ve been using Isopod P38 for all filling, fantastic stuff.
Last piece to cut was the base plate, decided I wanted under cab lighting, yes it’s blingy but I’m sure my 12 year old daughter will like it so I routed out a recess for  purple LED strips.
Slot cutter used on the sides in readiness for t-molding then test assembly to see if all the panels fit.
Connector blocks used to hold it all together and also allows me to easily disassemble/re-assemble throughout the build.
Test placement of components
For speaker grills/covering I was able to carefully remove the speaker cloth from the original USB casings and then with a little trimming and hot glue I attached them directly to the actual speakers.
Bracket for screen fitted
Then disassemble ready for paint. Nothing too fancy here just rattle cans of high build primers and then gloss white (with lots and lots of filling and sanding in-between).
Next up time to break out the wire cutters and soldering iron for the electronics. To power all the components I didn’t have space inside the cab for multiple AC adaptors  and I didn’t fancy having multiple cables running to the cab from the wall sockets so decided to use one of these (https://www.amazon.co.uk/DROK-Output-Universal-Adaptor-Display/dp/B00HY3AA3S/), a small dual output PSU board that provides 5v for the Pi and speakers and 12v for the screen and lighting.
As you can see from the above the under light strips were also fitted and soldered up
A little pause/delay at this point while I waited for my artwork to be printed and delivered before I could progress. I used http://rockstarprint.co.uk who printed to laminated glossy vinyl; really impressed with the quality and finish of their work.
With the control panel covered and buttons fitted I could then continue assembly and the electronics.
Screen next to go in, fitted a small panel to the back of the screen brackets which I mounted the controller board and controls to.
Speaker panel and speakers dropped in
As you can see in the above a bezel was also fitted, this is just a sheet of 3mm clear acrylic which I masked and sprayed on the rear side to cover up the physical screen surround. Indents were made to the screen bracket earlier that allow the bezel to hold the screen down and then the control panel and speaker panels both secure the bezel down.
Quick shot from the rear showing the messy wiring. plus the revised placement of the speaker controls (upper left).
The marquee was just a piece of clear acrylic with the vinyl artwork fitted and held in place with some small plastic L shaped edging I picked up. For lighting the marquee I’m using two short runs of cool white LEDs mounted to a scrap bit of white plastic cut to size.
I was actually very pleased with how this bit turned out, when lit you can’t see the individual LEDs and the marquee has a nice uniform glow.
Onto the finishing straight, fit top panel, apply side-art, and fit t-molding.
Done!!
Well almost…one exception I have a key lock access panel for the back however I ran out of paint so that will need to be done later in the week after my daughter receives it.
Fingers crossed she likes it!
« Last Edit: July 10, 2016, 11:36:51 am by GSXRMovistar »
Vidiot
  • John 3:16
« Reply #4 on: July 10, 2016, 02:34:34 pm »
Very nice! I'm sure she will love it. Lucky kid. :applaud:
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« Reply #5 on: July 10, 2016, 04:34:53 pm »
 :applaud: I love that! Want to do one for me. To bring at work!  :lol   :laugh2:
Masterfully done! :cheers: 8)
« Last Edit: July 11, 2016, 07:38:14 pm by ppv »
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
ballboff
  • Last login:July 22, 2024, 02:25:17 am
« Reply #6 on: July 10, 2016, 04:48:43 pm »
That's beautiful! Great job.  This is one of the smartest looking cabs i've seen.
Sent from my Fire Phone using Tapatalk
Scassidy24
  • Last login:October 12, 2023, 11:56:34 am
  • I love my Nostalgia Machine
    • forum.arcadecontrols.com/index.php/topic,150379.0.html
« Reply #7 on: July 13, 2016, 12:03:31 am »
Bravo! Excellent craftsmanship.  Nice use of the led lighting, and well it's all just top notch.
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #8 on: August 02, 2016, 03:49:09 am »
This little bartop is really awesome ! :applaud: :applaud:
GSXRMovistar
    • CoffeeCade
« Reply #9 on: August 03, 2016, 04:46:39 am »
Thanks for the positive comments. Was a nice surprise for my daughter which she loved and has since been playing various games on it (and so have I).
Just need to decided what to build next!  ;D
Wyo
« Reply #10 on: August 03, 2016, 05:42:45 am »
 :applaud: I love it! Nice work!
n3wt0n
« Reply #11 on: August 04, 2016, 10:44:39 am »
Nice build! I like the lighter colour palette and undercab lighting.
« Reply #12 on: August 26, 2016, 07:15:42 am »
Well done. Great compact design.  Nice artwork.  Clean construction.   :applaud:
Any chance you could post a video demo of the unit (and show us a peek on the inside)?
Titchgamer
« Reply #13 on: August 26, 2016, 09:09:20 am »
Lovely little machine that :)
GSXRMovistar
    • CoffeeCade
« Reply #14 on: August 26, 2016, 05:44:08 pm »
Okay just taken a few very short videos, quality sucks but hopefully shows you a bit about the cab.
Outside
Inside
Gameplay
« Reply #15 on: August 29, 2016, 02:08:44 pm »
Thanks man - appreciate the videos.  Looks like a heck of a lot of fun.  How's the screen working out for you? I was poking around and 4:3 monitors that size are hard to come by but the raspberry pi monitors are almost all 16:9 and you don't need all that screen to play the classics.  Do Pac-Man and Donkey Kong and other 3:4 games look ok?
markc74
  • Flipping out
« Reply #16 on: August 29, 2016, 03:11:33 pm »
Just picked up one of these for a when-i-get-a-day-off-bloody-work project.
https://shop.pimoroni.com/products/hdmi-8-inch-lcd-screen-kit-800-600
Plugs straight into the pi and can be powered from the same voltage. 4.3 8" screen. Think it's uk based.
Back to thread - really nice build. I don't need one but i want one 😄
« Reply #17 on: August 29, 2016, 08:11:39 pm »
Nice work, particularly clean woodwork and finish - lovely.
