Author Topic: T-Molding Install or Covering Art Edges  (Read 1497 times)
ladysephiroth
  • Last login:September 26, 2016, 05:40:24 pm
« on: June 25, 2016, 08:16:23 pm »
I'm looking at the T-Molding sites, and I realize that the cutter is a 1/4" shank and the Dremel/Router I have won't accept anything bigger than a 1/8" shank.  How else can I cut the slots for the T-Molding along the face of the MDF?
Contrary to that, what else can one do to conceal the edges of printed art? I want to get adhesive vinyl printed with my art but I know I want to protect the edge.
EDIT:  If this should be in the woodworking forum, mods please move as needed.  Thanks!
« Last Edit: June 25, 2016, 08:44:16 pm by ladysephiroth »
lamprey
Re: T-Molding Install or Covering Art Edges
« Reply #1 on: June 27, 2016, 04:50:47 pm »
Realistically, you need to use/buy/rent/borrow a router.
behrmr
« Reply #2 on: June 28, 2016, 12:59:31 pm »
You need to get at least a cheap trim router. If you have a Harbor Freight near you they're around $20.  Then get a t-molding slot bit and arbor.  If you don't want to use t-molding you could always try self stick edge banding.
langlem
  • Last login:May 27, 2025, 04:58:19 pm
« Reply #3 on: June 28, 2016, 04:18:35 pm »
Just break down and get the router and bit set.  I tried to go the cheap route a few times and always end up redoing it correctly...as suggested previously.  It may cost a few dollars more now...but will only need done once.
« Reply #4 on: June 28, 2016, 04:33:20 pm »
My experience with the trim router from harbor freight is that the depth adjustment won't stay put, so my t-molding slot would veer off course.
Others here say they've had no such issue.  I ended up using it as a dedicated circle cutter.  The depth still doesn't stay put, but it's less important.
