Author Topic: What iron do you use?  (Read 3276 times)
Locke141
  • Never grow up.
« on: June 13, 2016, 11:06:22 am »
I know there are lot of threads on soldering irons but I know thing chanege. I'm looking ones on Alibaba as most all vender ship to where I'll end up over sea's.
I was looking at
this one but am open to ones as high as $150.00.
« Last Edit: June 13, 2016, 11:09:48 am by Locke141 »
  • Last login:Today at 02:02:09 am
Re: What iron do you use?
« Reply #1 on: June 13, 2016, 11:14:04 am »
Hakko. And I'll never use anything else.
*Cue comments on how the $5  Radio Shack special is just fine
Sent from my SM-G386T using Tapatalk
« Reply #2 on: June 13, 2016, 11:16:43 am »
With your budget I'd get a Hakko and then a separate knock off hot air station.
I have Yihuas (check out the electronics workbench thread) and they are surely serviceable but if you're willing to spend the money there is not reason not to go Hakko.
  • Last login:December 19, 2025, 12:57:19 pm
« Reply #3 on: June 13, 2016, 11:32:24 am »
Sure is.  That's how I got my custom title, with my el-cheapo radio shack special.
It's the technique, not the iron.
That being said, my Radio Shack one finally died after about 10 years of service so I picked up a Weller.
« Reply #4 on: June 13, 2016, 11:32:53 am »
Aaaaaaand there it is.
  • Last login:December 19, 2025, 12:23:29 pm
« Reply #5 on: June 13, 2016, 11:33:43 am »
http://forum.arcadecontrols.com/index.php/topic,146521.0.html
EDIT: Toward the end of that thread, there is some discussion of the soldering/desoldering stations similar to the one you linked to.
« Last Edit: June 13, 2016, 11:39:18 am by BadMouth »
« Reply #6 on: June 13, 2016, 11:34:21 am »
Although I will agree that technique is everything. I've done so much soldering in the past two years that I can now make money doing it. Remember to practice, kids! :cheers:
  • Last login:Yesterday at 02:18:20 pm
« Reply #7 on: June 13, 2016, 12:18:26 pm »
+1 on the Hakko.  I love mine.
DeL
Slippyblade
« Reply #8 on: June 13, 2016, 01:09:31 pm »
Yes, technique is important, but having a quality tool makes a HUGE amount of difference.  The Hakko gets to temp within a minute after being turned on and KEEPS the set temp.  Every cheap iron I ever had was literally plug in, go make a sandwich, come back and it *might* be up to temp.  Soldering a normal through hole lead was fine, but anything attached to a plane...  total ---smurfette---.
« Reply #9 on: June 13, 2016, 01:32:28 pm »
So getting the Hakko has cut down on your sandwich consumption, yes? :-)
Slippyblade
« Reply #10 on: June 13, 2016, 02:43:52 pm »
...Every cheap iron I ever had was literally plug in, go make a sandwich...
Pfft, silly Yots.  I've just found OTHER reasons to go make a sandwich.  As if a person actually needs a reason...
« Reply #11 on: June 13, 2016, 02:50:54 pm »
I herd dat!! :cheers:
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #12 on: June 13, 2016, 03:48:37 pm »
I've got a Solomon SL-30 and a Weller 51. Happy with both, but the Solomon is my regular iron.
« Last Edit: June 13, 2016, 04:03:51 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
  • Last login:Yesterday at 09:13:02 am
« Reply #13 on: June 13, 2016, 03:52:58 pm »
I've had a Weller WESD51 since the 90s, and it was well used when I got my hands on it.
I've replaced a couple of tips ($5) and one heating element ($15) and it's held up fine over many years of circuit work, spousal discipline sessions, and torturing of small animals.
« Reply #14 on: June 13, 2016, 03:59:27 pm »
Nearly all Weller here too.
  • Bitches love Centipede
« Reply #15 on: June 13, 2016, 09:36:40 pm »
My baby... One baaaad ---smurfette---...
%Bartop
Slippyblade
« Reply #16 on: June 13, 2016, 10:33:44 pm »
Tool porn!
