Author Topic: Piforce: A Pi-based Console  (Read 3678 times)
jeffrock
  • Last login:June 11, 2016, 02:12:25 pm
« on: May 29, 2016, 09:01:17 pm »
After months of free time hacking, I've finally completed a prototype of my first console case. Since it was going to go under my TV, I wanted something made from premium materials that felt more like a console than a computer case. I decided that it would be primarily classic Nintendo games going onto it (NES, SNES, GameBoy, Advance) so it should support native SNES controllers.
After iterating through three full designs, I finally landed on one that requires no glue or fasteners to hold the case together; only tension. I cut slits into the acrylic in a special configuration that allows it to expand like an accordion and hook into notches on the feet, and engraved grooves into the inside to hold the front and back panels in place. That way I can easy get into the case if I need to access / replace / add / upgrade components.
The front and back pieces are 1/4" solid walnut. The wrap is 1/8" specialty matte black acrylic sheet I got from a plastics distributor (really nasty stuff to work with but has a stunning finish). There is small acrylic plate that holds the SNES ports and LED to the front panel and a 1/8" panel that holds the Pi 3 between the front and back panels. I went with a ControlBlock to make it easier to implement the ports, LED, and power switch. The dimensions of the unit are 6" W x 5.5” D x 1.5" H.
Piforce was designed in Illustrator and all pieces were cut with an Epilog Fusion 60w CO2 laser. There are a half dozen or so components as well (terminals, fasteners, etc) which I am happy to list if anyone wants to know, as it took me forever to track it all down!
Anyway, here's a few photos of the project. Next steps are to make a few modifications and really tune in the design. After that, I'll move on to designing a custom Piforce ES theme and video splash screen. Thanks for checking it out!
Re: Piforce: A Pi-based Console
« Reply #1 on: May 29, 2016, 10:20:24 pm »
That's pretty bad ass, my friend!
Sent from my SM-G386T using Tapatalk
bplail
  • Last login:October 11, 2023, 11:11:24 pm
  • Currently building a DK cab
« Reply #2 on: May 30, 2016, 12:26:48 am »
man that is sleek!
n3wt0n
« Reply #3 on: May 30, 2016, 06:46:15 am »
Nice job! That is really cool.
Scotty_C
  • Last login:December 28, 2024, 08:40:26 am
  • The addiction is strong!!
« Reply #4 on: May 31, 2016, 10:58:20 pm »
ah yeah!! I like that!
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #5 on: June 01, 2016, 11:24:06 am »
Nice clean look!
What converters/adapters are you using for the snes controllers? Did they take a lot of fiddling with the pi to work?
  • Last login:February 23, 2026, 08:25:01 am
« Reply #6 on: June 01, 2016, 11:39:20 am »
How are you handling shutdown?
  • Last login:February 23, 2026, 02:55:37 pm
« Reply #7 on: June 01, 2016, 03:49:00 pm »
Sexy.  :cheers:
stigzler
    • Mago Arcade
« Reply #8 on: June 03, 2016, 02:10:16 pm »
Love it. Awesome idea with the shell - guess you get ventilation built in too..
Slippyblade
« Reply #9 on: June 03, 2016, 02:16:44 pm »
#1 question.
welash
  • Last login:February 01, 2020, 04:52:44 pm
« Reply #10 on: June 04, 2016, 12:37:20 am »
He said he is using a controlblock http://blog.petrockblock.com/2014/12/29/controlblock-power-switch-and-io-for-the-raspberry-pi/ which provides the interface for the SNES controllers (it can also be used to hook up buttons through a couple of i2c i/o chips) and an interface for a power switch that it runs through an ATtiny.  It sounds like the power control uses a couple of io pins on the rpi, one that signals that it wants the pi to shut down, and the other coming from the pi that says it has shut down.  It runs the power through a power FET hooked up to the ATtiny.  It also provides an LED output that indicates if the pi is on, off, booting, or shutting down.
They also provide code for the rpi side for the power control and also for the snes/button controller functions.
darthpaul
  • Last login:February 22, 2026, 10:22:50 am
  • Join, It's your duty
« Reply #11 on: June 05, 2016, 12:20:16 am »
Very, very nice  :applaud:
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
