Author Topic: Vertical monitor cab  (Read 2114 times)
Iceman81
  • Last login:November 30, 2018, 05:57:54 am
« on: April 05, 2016, 06:28:18 pm »
Was planning on a build for a vertical upright.  With only vertical mame XML possibly hyperspin, maybe pinball as well
From what I've been reading, I think originally most games like pacman were a 19" CRT on its side(please correct me if I'm wrong).
Anyway I have 2 questions.  How many buttons(only 1 player)
If I went lcd which is they way I'm leaning. What would be a good size(24" wide cab)
On a side note, I think pinball may be more an option. Never tried on my horizontal cab, but idk if I want to put buttons on the sides.
Any advice/experience would be much appreciated.
Slippyblade
Re: Vertical monitor cab
« Reply #1 on: April 05, 2016, 06:30:07 pm »
Yes, a ton of the old classics were 19" tubes on their sides.
If you go with an LCD, find an older 19" 4:3 one.  Then you have the right size/aspect.
Jamesbeat
  • Last login:February 11, 2019, 06:13:39 pm
« Reply #2 on: April 05, 2016, 07:14:47 pm »
 I believe most (all?) 19" LCD monitors are 5:4, not 4:3.
This doesn't really make much difference as far as I can tell - the aspect ratio looks the same to me.
I'm not saying this to be pedantic, it's just useful to know if you happen to be searching for one on eBay etc.
dmckean
« Reply #3 on: April 05, 2016, 07:38:19 pm »
You actually want a 21" PC monitor. Arcade monitors are measured by viewable screen size like TVs are and PC monitors include the bezel in it's measurement. So a 21" PC monitor is the same size as a 19" arcade monitor.
Jamesbeat
« Reply #4 on: April 05, 2016, 07:43:31 pm »
This is true for CRT's, but LCD's are measured across the viewable area.
Iceman81
« Reply #5 on: April 06, 2016, 10:59:04 am »
thanks for the input guys
« Last Edit: April 06, 2016, 11:01:57 am by Iceman81 »
  • Last login:Yesterday at 08:05:57 pm
« Reply #6 on: April 06, 2016, 11:03:48 am »
This.  If I can't use an arcade CRT, my next option is always a 21" computer CRT.
Iceman81
« Reply #7 on: April 06, 2016, 11:07:59 am »
i have 2 old crt tvs, but they only have RF in, probably more work than its worth to convert, i'll look on craigslist for a 19" pc monitor than.
« Reply #8 on: April 06, 2016, 06:09:48 pm »
Same here.  I'm actually considering on tossing at 21" PC CRT into my Super Pacman resto instead of the burned in 19" stock arcade G07.
DeL
