Author Topic: Spinner, ? about bearings  (Read 1295 times)
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« on: January 15, 2004, 01:41:17 am »
If I were to use this or somehting similar to mount my spinner...
Would I waant the shaft of the spinner to be a snug fit in the center hole, or should it spin freely of the bearing?
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
Re:Spinner, ? about bearings
« Reply #1 on: January 15, 2004, 03:07:33 am »
Is that a roller bearing or a sleeve bearing? I'd lean towards snug, but how snug is a matter of the type of bearing you'll be using.
Brad Lee
    • 666
« Reply #2 on: January 15, 2004, 09:04:06 am »
Sleeve I think for this specific one but there's all different kinds, BB, roller, sleeve, metal, plastic etc
www.mcmaster.com under Power Transmission/Bearings
Im gonna doodle up some stuff when Iget some time at work today, pretty much gonna rebuild it from scratch
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #3 on: January 15, 2004, 10:01:37 am »
Typically, the sleeve in that style of bearing pivots in the housing because they are normally used in self-aligning applications.  This means that there are a few degrees of movement of the sleeve so the shaft hole isn't necessarily always perpendicular to the flange.  If you are using 2 of them, then it should be okay.  But using a single one will cause your spinner shaft to move around a bit, possibly causing a problem with the encoder wheel/optic board alignment.
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #4 on: January 15, 2004, 10:21:12 am »
 A good cheap bearing can be found in Western Digital hard drives.  The bearing is  tight and has very good
weight  and I have been nothing but happy with the 2 I have made...just click on the controls link and follow the links to it
Brad Lee
    • 666
« Reply #5 on: January 15, 2004, 11:39:55 am »
Oscar- 2 is defintiely in the plan to eliminate wobble
I'm using the large encoder disk, from OscarsControls of course, and cant remember the size of the center hole.. I think it's 3/8" but mines installed and I dont wanna rip it apart while its still functioning fine  ;D
Is that the correct size- 3/8?
OSCAR
    • Oscar Controls
« Reply #6 on: January 15, 2004, 02:53:11 pm »
The encoder wheel has a 1/4" hole.
I had about (25) of the larger 66T encoder wheels made with a 1/2" hole, but I don't believe those ever made it out into the wild.  These would be good for a steering wheel project, or something like that that needs a larger shaft.  I still have these sitting on a shelf if anyone is interested.
