Author Topic: Does a seimitsu shaft fit a sanwa joystick?  (Read 2059 times)
Daikath
  • Last login:February 17, 2024, 05:49:01 am
« on: March 22, 2016, 03:11:58 pm »
I live in the netherlands and since germany is right next door I'd prefer to order from ArcadeShop.de because shipping would be faster.
But I'd also like my sanwa JLF balltop to have a LED in it,,, they do have a hollow shaft for the Seimitsu LS-32..
I made a custom arcade stick for a friend some while ago and I ordered from them, but I don't know if I used the Seimutsu shaft and it fitted fine or if they had a specific Sanwa shaft which was hollow as well..
So can you put a shaft for the Seimutsy LS-32 into a Sanwa JLF without it being different? I tried looking for pictures of both shafts side by side but could not find them. Any help is greatly appreciated.
edekoning
Re: Does a seimitsu shaft fit a sanwa joystick?
« Reply #1 on: March 23, 2016, 05:31:25 am »
I really can't tell you, but you might find an answer here http://www.slagcoin.com/joystick.html or here http://forums.shoryuken.com/
As an alternative to ArcadeShop.de take a look at this UK based shop: http://www.arcadeworlduk.com/. They have a catalog that is a lot bigger. I'm also from the Netherlands and have ordered from both. Shipping times were fine from both shops, though ArcadeShop.de was faster.
Daikath
« Reply #2 on: March 23, 2016, 10:22:00 am »
finally found my old orderform from arcadeshop.de. They did sell hollow Sanwa shafts back then. So it probably wont fit.
I checked out the new store, it sadly doesnt carry hollow shafts for either Sanwa or Seimitsu... I'll look further.
Franco B
« Reply #3 on: March 23, 2016, 04:08:28 pm »
Seimitsu and Sanwa shafts are unfortunately not cross compatible.
I would avoid ordering from arcadeshop.de at the moment, there are currently a lot of unhappy customers waiting on unfulfilled orders at the moment.
If you want to excellent service within the EU I can highly recommend http://www.arcadejapan.co.uk/
