Author Topic: SUPER CHASE CRIMINAL dont work on mame  (Read 4304 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« on: February 26, 2016, 04:36:58 pm »
Hi
SUPER CHASE CRIMINAL dont work on my MameUI32.0.151, I all ready change other rom from working version :dizzy:
any idea please?
  • Last login:February 11, 2026, 07:46:44 pm
Re: SUPER CHASE CRIMINAL dont work on mame
« Reply #1 on: February 26, 2016, 05:04:22 pm »
Don't use 151?
Mame just went through yet another core change, so it might be that the game is broken in that version.
jackiabu
« Reply #2 on: February 26, 2016, 05:10:49 pm »
Don't use 151?
Thanks men fot that info. but this a bad news for me, because i already changed computer and its win7 32 bit :-\
« Reply #3 on: February 26, 2016, 05:18:28 pm »
from http://www.progettoemma.net/
Bugs:
 - The screen occassionally flickers/flashes with incorrect graphics. Twisty (ID 00025)
Is this what you mean by not working?
Game is labeled as working in MAME though.
If it's not launching, there should be a message telling you what it can't find.
You might be missing a separate sound board file or something.
I will try to launch the rom by itself tonight in v.170 and see if it is looking for anything else.
MrThunderwing
  • Last login:February 12, 2026, 06:28:28 pm
« Reply #4 on: February 26, 2016, 05:21:12 pm »
Alternatively you could just re-download an older version of MAME that you know will play it properly.
http://mamedev.org/oldrel.html
POOTERMAN
  • Last login:March 15, 2025, 05:41:08 pm
    • My PC Desktop Icon Atwork
« Reply #5 on: February 26, 2016, 05:27:24 pm »
working in the latest mameuifx32_0171.exe
« Reply #6 on: February 26, 2016, 06:17:17 pm »
Bugs:
Yeah I've got it on my machine..... it plays fine but the road has a tendency to disappear.
jackiabu
« Reply #7 on: February 27, 2016, 03:32:46 am »
   this is what i get....sorry for the bad pic
  • Last login:Today at 06:12:21 am
« Reply #8 on: February 27, 2016, 05:43:43 am »
All the files in the screencap should be in superchs.zip -- contains 29 files, zipped filesize = 8,699k, unzipped filesize = 18,436k. (I'm running 0.152)
Are you sure your ROM version matches your MAME version?
From mameinfo.dat:
WIP:
- 0.154: Converted Super Chase to standard MCFG_PALETTE_FORMAT [Alex Jackson].
- 0.152: Unigame added clone Super Chase - Criminal Termination (1992/10/26 20:24:29 CHASE 3 VER 1.1, prototype). Like the other Taito prototypes this is a significantly different version with different graphic data etc. Changed default layout to upright 4:3 [hap].
- 0.148u4: Porchy and The Dumping Union added Super Chase - Criminal Termination (World). Corrected main CPU clock, corrected some rom labels. Added PLDs to the sets [Porchy, Brian Troha, The Dumping Union]. Changed 68EC020 CPU1 clock speed to 20MHz. Renamed (superchs) to (superchsu).
jackiabu
« Reply #9 on: February 27, 2016, 10:36:47 am »
From mameinfo.dat:
WIP:
Yes i am sure...any way i install  in 0.146 its working. but i need it in my 0.151 V :-\
« Reply #10 on: February 27, 2016, 11:09:51 am »
If you are trying to use the same "superchs.zip" ROM file for both 0.146 and 0.151 you are definitely not using the correct version of the ROM.
From mameinfo.dat:
jackiabu
« Reply #11 on: February 27, 2016, 11:21:26 am »
From mameinfo.dat:
NO i replace other rom, only when i see it didnt work. I have The both roms 0.146 and 0.151...
« Reply #12 on: February 27, 2016, 12:48:33 pm »
The version of MAME you are using in the picture is not finding what it is looking for in superchs.zip
It probably is a problem with using a rom meant for a different revision of MAME, but if you want to take a hammer to it..... ;D
Unzip all the roms.
Add all the files listed in the picture to superchs.zip
(find them in the other superchase rom zip files)
Zip it back up.
I haven't tried doing this with newer versions  of MAME, but I did it with older versions and it worked.
Good Luck.
jackiabu
« Reply #13 on: February 28, 2016, 03:10:26 pm »
Thanks guy for your help ;D problem solved :applaud:
I get another ROM from friend.
