Author Topic: volume control  (Read 4105 times)
slotter312
  • Last login:June 13, 2017, 08:44:47 pm
volume control
« on: January 26, 2016, 11:03:59 pm »
Hi guys can I get a diagram of how to wire this in to my jamma setup. It only has the speaker  wires thanks
big10p
  • Mmmm, arcade classics!
Re: volume control
« Reply #1 on: January 27, 2016, 12:02:53 pm »
My guess would be:
Speaker + from the JAMMA edge connector to IN
Speaker - from the JAMMA edge connector to G
Speaker + wire to SP
Speaker - wire to earth/ground (the pin next to SP)
Amp power + wire to B+
Amp power - to earth/ground
chopperthedog
  • Last login:Today at 07:19:29 pm
Re: volume control
« Reply #2 on: January 27, 2016, 01:48:46 pm »
Connecting an amplified signal to an amplifier will have a real nice buzz. If you want to use that amp you will need to tap into the 3.5mm jack on the board to get a line level signal for the amp. You can skip the amp and wire speaker directly to harness. With speaker wired to harness you can add a rheostat inline ( https://www.radioshack.com/products/radioshack-25-ohm-3-watt-rheostat?variant=5717266181 ) that can act as a volume trim of the amplified signal.
good day.
big10p
Re: volume control
« Reply #3 on: January 27, 2016, 03:12:10 pm »
good day.
I have 12v amps in both my JAMMA wired cabs. One has a MAME rig in it so needs an amp. I get no buzz when connecting JAMMA boards, though. I just turn the amp down to an optimal, minimal level on the game PCB, then use the external amp to regulate volume.
ed12
Re: volume control
« Reply #4 on: January 27, 2016, 03:27:07 pm »
please do explain to me how u take a 4 ohm load to line level ??
where 4 ohm load is a speaker
where line level is 47k or better
and make this work without buzz ?
oh wait i c turn the volume controll way down,cannot hear it then..huh  :tool: :tool:
ed
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: volume control
« Reply #5 on: January 27, 2016, 03:57:17 pm »
Sometimes I think ed can be a little harsh, but he pretty much nailed what I was thinking.
I don't see how putting an amp inline with an amplified signal (e.g. JAMMA) makes any sense. I always put the amp on the MAME side of the harness. To do otherwise strikes me as defeating the purpose of using a JAMMA cab in the first place.
Working: Not Enough
Projects: Too Many
Progress: None
ed12
Re: volume control
« Reply #6 on: January 27, 2016, 04:00:41 pm »
i did say please
ed
big10p
Re: volume control
« Reply #7 on: January 27, 2016, 04:02:09 pm »
i did say please
ed
And then proceeded by calling me a tool. --missioncontrol--.
And I said I turn the amp to an "optimal, minimal" level, not right down. Learn to read.
« Last Edit: January 27, 2016, 04:05:11 pm by big10p »
CheffoJeffo
Re: volume control
« Reply #8 on: January 27, 2016, 04:13:14 pm »
Alright big10, I'll ask the question: WHY?
To the OP: Are you running JAMMA (already amplified) and just want a volume control -- or -- are you running a MAME box in a JAMMA-wired cab and need the amplification. If you are looking solely for volume control, listen to chopper. If you need the amp, put it on the MAME side of the harness.
Working: Not Enough
Projects: Too Many
Progress: None
ed12
Re: volume control
« Reply #9 on: January 27, 2016, 04:22:34 pm »
forgive me for saying please.. :notworthy:
from what u just stated. u sir have a problem with english,not I.
>And I said I turn the amp to an "optimal, minimal" level, not right down. Learn to read.<
i ASKED U BIG10
>oh wait i c turn the volume controll way down,cannot hear it then..huh <
that sir is a question and a statment
ed
big10p
Re: volume control
« Reply #10 on: January 27, 2016, 05:04:45 pm »
Why what?
So, following your logic, it's OK to tell someone to go f**k themselves. as long as you say please?
It would be more productive if you gave the OP some help/advice (as I at least attempted to do), instead of just trolling. If your opinion differs from mine, fine - just try not to be so bloody disrespectful in the future, please.
CheffoJeffo
Re: volume control
« Reply #11 on: January 27, 2016, 05:13:54 pm »
Why what?
Why put the amplifier on the amplified side of the harness?
Working: Not Enough
Projects: Too Many
Progress: None
big10p
Re: volume control
« Reply #12 on: January 27, 2016, 06:19:56 pm »
Why what?
Because I've fitted the volume control to a service panel that's accessed via the coin door. I can use this to easily adjust volume, whether I'm running a JAMMA board or my MAME rig.
CheffoJeffo
Re: volume control
« Reply #13 on: January 27, 2016, 06:37:51 pm »
I guess if it's not causing you trouble and makes you happy then all power to you.
I put an amp on the MAME side and, like chopper suggests, a volume control on the harness side (typically on a service panel along with service/test and sometimes credit buttons).
Working: Not Enough
Projects: Too Many
Progress: None
slotter312
Re: volume control
« Reply #14 on: January 27, 2016, 06:56:12 pm »
thanks guys ,I thought it was just for external volume,not amplifier. I will track down just a volume control unit. thanks from aussie.
slotter312
Re: volume control
« Reply #15 on: January 27, 2016, 07:11:04 pm »
1K 24mm Potentiometer Log Single Gang (A). found this in jaycar website. looks the same as radio shack one
