Author Topic: loose balltops  (Read 1985 times)
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
loose balltops
« on: November 26, 2015, 03:25:48 pm »
Getting tired of having to tighten my balltops every other minute.
What do you guys use?
Im thinking blue thread locker  :dunno
  • Last login:Today at 09:39:55 am
Re: loose balltops
« Reply #1 on: November 26, 2015, 03:41:31 pm »
I've used HOT glue
 :dunno
Edit - damn autocorrect.  Anyway, drop of hot glue on the threads and tighten the ball top while the glue is still pliable.
« Last Edit: November 26, 2015, 11:09:47 pm by pbj »
johnrt
Re: loose balltops
« Reply #2 on: November 26, 2015, 03:41:48 pm »
I use this:
adder
Re: loose balltops
« Reply #3 on: November 26, 2015, 04:17:44 pm »
maybe some rubber/pvc/electrical tape on the thread would be enough
ivwshane
    • My first mame cab! (WIP)
Re: loose balltops
« Reply #4 on: November 26, 2015, 04:38:54 pm »
I just had the same exact issue. My fix was some loctite on the threads, problem solved!
adder
Re: loose balltops
« Reply #5 on: November 26, 2015, 04:55:23 pm »
if you dont ever need to get the balltop off again u might as well use one of the many available metal/steel epoxy putty products
mgb
  • North East, US
Re: loose balltops
« Reply #6 on: November 26, 2015, 05:00:30 pm »
Blue loctite all the way.
I use it mine. Works great.
I bought it in a small Chapstick like tube.
deezdrama
Re: loose balltops
« Reply #7 on: November 26, 2015, 11:01:04 pm »
That stick of blue loctite.... is it a thick texture? I have some regular blue liquid locktite but hate using it cause its so runny and even a single drop spreads out everywhere.
mgb
  • North East, US
Re: loose balltops
« Reply #8 on: November 27, 2015, 01:02:15 am »
The blue Chapstick style stuff doesn't run at all and the ball tops are completely stable after. Not spinning off but if you really need to get them off, you can
mgb
  • North East, US
Re: loose balltops
« Reply #9 on: November 27, 2015, 01:03:01 am »
Its like the consistency of Chapstick.
Not runny in the least.
Works great.
Sorry for the double post. My phone flaked
deezdrama
Re: loose balltops
« Reply #10 on: November 27, 2015, 01:05:25 am »
It sucks the stuff is $15 to only need 4 drops of the stuff lol
mgb
  • North East, US
Re: loose balltops
« Reply #11 on: November 27, 2015, 10:39:01 am »
$15 ????
I picked up a stick once for a dollar or two at the counter of home depot
« Last Edit: November 27, 2015, 10:56:34 am by mgb »
mgb
  • North East, US
Re: loose balltops
« Reply #12 on: November 27, 2015, 10:54:27 am »
wow, a quick google search and looks like it is more expensive than I remembered.
If you already have the runny stuff, just use it with an acid brush.
http://www.homedepot.com/p/Linzer-1-2-in-Tin-handled-Acid-Brushes-6-Pack-9002-0/100179140
squirt a little in small cap or something and use the acid brush to spread a small amount on the joystick thread.
« Last Edit: November 27, 2015, 10:56:16 am by mgb »
