Author Topic: Plastic L Channel?  (Read 3365 times)
mattsoft
  • Last login:January 30, 2018, 10:26:25 pm
Plastic L Channel?
« on: November 15, 2015, 12:50:17 pm »
Hi All - I'm building a couple of bartops and have seen people use plastic L channel to retain marquees/marquee plexi, and to beed the outside corners. A lot of kit vendors include custom-cut L channel for their kits. Does anyone know where you can buy plastic L channel? The local Home Despot does not have it, and the few places I've found online want orders with 25 pieces (at 8 feet lengths) or more. Any ideas? Thanks!
brihyn
Re: Plastic L Channel?
« Reply #1 on: November 15, 2015, 07:54:03 pm »
mattsoft
« Reply #2 on: November 15, 2015, 11:01:18 pm »
surprising that your local HD store doesn't carry it.
http://www.homedepot.com/p/Trimaco-1-1-8-in-x-1-1-8-in-x-4-ft-Plastic-Corner-Guard-Commercial-01184G/100118843
Yeah, they carry those larger sizes that work on a full size upright arcade, but for a bartop, you need 1/2" width and they don't have it that slim.
vwalbridge
« Reply #3 on: November 15, 2015, 11:12:37 pm »
I used drywall corner bead for my mini Donkey Kong. It's metal and you have to tear the paper off it and paint it black but I eventually got it to work. I too wanted it 1/2 inch.
Walk down the drywall supply isle in Home Depot, you will find it.
mattsoft
« Reply #4 on: November 16, 2015, 12:58:43 am »
http://displayproductsonline.com/extrusions/l-channel.html
Perfect! But too pricey. :( I may settle on Home Despot corner guard/bead.
Peabo
  • Pinball junkie
    • Virtual Pinball Build
« Reply #5 on: November 16, 2015, 07:17:57 am »
I use 1/2" x 3/4" aluminum angle.  The 3/4" gives more room for the screws and allows them to be counter sunk.  Home Depot near carries it
mgb
  • North East, US
« Reply #6 on: November 16, 2015, 06:59:54 pm »
I think the aluminum angle may be a better choice than plastic and it's available at Home Depot & Lowes
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« Reply #7 on: November 16, 2015, 10:57:53 pm »
Try Googling aluminum supply near you.  A decent aluminum dealer will have all sizes of angles for dirt cheap.  Might have to go to the industrial side of town though...  :D
RxBrad
  • Last login:May 31, 2023, 12:41:00 pm
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #8 on: November 17, 2015, 07:22:48 am »
I thought about using aluminum on my cab's marquee before settling on the plastic L channel mentioned near the top of this thread.
How would one go about about cutting the aluminum?  (Not knowing is why I shied away from aluminum.)  Would the same blade I used on my circular saw to cut the MDF work?  A hacksaw?  Some other special blade?
mgb
  • North East, US
« Reply #9 on: November 17, 2015, 09:27:58 am »
You can cut it with a hacksaw blade or you can put a diamond blade on the circular saw or a metal cutting blade on a jig saw
Worst case you can have someone cut it to size.
Peabo
  • Pinball junkie
« Reply #10 on: November 17, 2015, 09:40:49 am »
Hacksaw would work, I use a cutoff wheel in an angle grinder then use a stone in the dremel to clean up the cut edge.  Drilling, you can use the same bits you do for wood, including countersinking.  Aluminum is a soft metal and no special tools needed.
MartyKong
  • Last login:February 09, 2026, 10:02:08 am
« Reply #11 on: November 17, 2015, 10:41:01 am »
Also, I think EMDB had a post about using plastic poster L channel for his marquee. I've looked in the local stores but haven't come acrossed any.
mattsoft
« Reply #12 on: November 17, 2015, 07:16:41 pm »
Yeah, I'd love to use the plastic stuff, but kind find it for a reasonable cost. I guess if there was a sign supply store -- maybe art supplies? I'll have to broaden my search...
JudgeRob
« Reply #13 on: November 17, 2015, 09:55:46 pm »
If you cut aluminum,  get a blade with higher teeth per inch.  That will give you a clean edge.   I put a Diablo blade in my miter saw and it makes great corners.  If you have access to a band saw, they work great too.
