Author Topic: Super Pac-man restore  (Read 10218 times)
  • Last login:Yesterday at 07:09:41 am
« on: September 16, 2015, 01:59:39 pm »
Well, I've had this thing in storage for about a year.  Picked it up here in the forums from user stan2323 and planned on working on it once I bought my house.  This summer I was finally able to bring it outside to clean it up and sand it down.  My plan is to restore the outside (may make some cosmetic changes/sacrifices here and there).  But I still want the overall theme to be Super Pac-man.  (I may change the CP overlay and marquee, not sure yet).  I want a multi-pac eventually, but for now I may just put either a 60 in 1 in there with all Pac-man games enabled, or an old PC with MAME and all the Pac-man games.  Either way, I love the notch in the cabinet so I MUST have the Super Pac-man on the sides.   ;D
First, I would like to give a shout out to stan2323.  He was moving from down south up to West Point, NY which wasn't too far from me.  He PM'd me and asked if I would want it or he was going to toss it.  He said he could have it shipped up here along with his household stuff at no cost.  I agreed in order to save it.  When he moved here he contacted me and patiently held it in his garage for a while (thanks so much for this!).  My buddy and I finally came and picked it up, where we moved it to storage for about a year in my buddy's garage (thanks Chris!).
Here's the condition of the machine when I got it:
Monitor has some burn in, but I plan to attempt a tube swap (Compatible tubes for the G07's are hard to come by I hear but I need to be patient).  In the meantime I may just put a de-cased PC CRT in there until I find a donor TV that fits.
My buddy Chris and I picked it up in his truck:
~~~  Then it sat for a year.  ~~~
Once good weather hit, I decided to strip it down and remove the paint.  That way I could bring it inside and work on the paint over the fall.
The hardware is in good shape as was the cabinet itself.
The monitor was filthy, so I cleaned it it up by giving it a bath in Simple Green and a garden hose.  It's completely safe.  Even captured it on video on my Youtube Channel.
Took pics of the paperwork since it would get ruined by the cleaning:
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=136713.0;attach=335627;image
Here are the "after" pics:
Here's a video that I made of the cleaning process:
And now for the sanding:
Original artwork.  It was pretty rough and I can see why they decided to paint over it.
I used bondo here and there to make it smooth as butter and ready for painting:
More sideart.  I needed to sand it down to the wood, since it was originally stenciled on you could see the bumps from the different paint layers.  So I needed to sand it smooth.
All done!  I lightly sanded the inside as well to prep it for paint.
Paint!  What a pain this was!  I had originally found a paint code on the forums, but when I brought it in to Home Depot they said that the paint code was outdated and then had a "new" color mixing system.  So, they attempted to punch in some numbers and it looked very dark (almost black).  So I didn't buy it and went back to the drawing board.  Then someone suggested that I used the back door to color match.  Brilliant!  Lucky for me I completely forgot to sand it when I was working on the cab and I was able to clean it and bring it in.  The result, a beautiful perfect match!
More to come as I prepare to paint this thing...
DeLuSioNaL29
« Last Edit: September 16, 2015, 02:09:07 pm by DeLuSioNal29 »
  • Last login:Today at 08:59:32 pm
Re: Super Pac-man restore
« Reply #1 on: September 16, 2015, 02:16:03 pm »
Nice. I have a SuperPac board that I converted to JAMMA, with the high score kit installed.
vwalbridge
« Reply #2 on: September 16, 2015, 02:22:10 pm »
Is is bad shameful of me to like Super Pac-man a teensy more that Ms. Pac man...and a lot more than original Pac-man?
« Reply #3 on: September 16, 2015, 02:22:50 pm »
I'm sure once I get the board that I want you will be helping me to burn to appropriate chips.  :-)
For now though, I'm pulling back the reigns and will be emulating until I can buy the right boards.
D
« Reply #4 on: September 16, 2015, 02:25:19 pm »
I was actually toying with the idea of running a single game on it (Pacman 20th re-union which has Pac-man, Ms. Pacman and Galaga on it).  I'm not too fond of the Super-Pacman marquee.  So I may change it out for the 20th re-union one.
D
behrmr
« Reply #5 on: September 16, 2015, 03:26:43 pm »
If you are looking to "multipac" as in Mike Doyle 96-in-1 you will not be happy with the Super Pac-Man game play.  It's pretty horrible.
Good luck with your project.
« Reply #6 on: September 16, 2015, 03:42:40 pm »
Thanks for the heads up behrmr!  I'm not quite sold on it yet anyway.
Correction:  It will play multiple versions of Pac-man. How I achieve this is still up in the air.
D
« Reply #7 on: September 16, 2015, 06:04:26 pm »
Nice cab, I always kinda liked the super pac cabinet look.
You can experiment with those tv plug and play units. Most have super-pac, but for some damn reason, they never include ms. pac. The only one I know of that has ms. pac is missing super pac.  :dunno
« Reply #8 on: September 16, 2015, 06:11:22 pm »
Good idea, but I'm planning on mounting the monitor vertically.  Those TV plug and play units have modded versions to fit the horizontal display.   ;)
D
behrmr
« Reply #9 on: September 16, 2015, 08:27:09 pm »
I'm currently working on a Super-Pac themed cabaret (was a converted and then gutted Omega Race cabaret).  I plan on using the old ArcadeShop programmable PCB in vertical mode.  An ArcadeSD would be my next choice.  The emulation on both of these boards is pretty freaking good.
« Reply #10 on: September 16, 2015, 09:01:54 pm »
Hmm. The Arcade SD has a hefty price tag though. Plus I will have most games disabled.
For now I think the 60 in 1 is winning. I'm also restoring a .vs cab so the budget is tight.
D
vwalbridge
« Reply #11 on: September 16, 2015, 09:30:47 pm »
« Reply #12 on: September 16, 2015, 11:32:18 pm »
Tempting, but that's 4.5 hours away each way.   I'm no ChanceKJ. Lol.
« Reply #13 on: September 17, 2015, 10:40:03 am »
D
Ah, yeah, I forgot about that. I haven't touched them in years, because my experience was the video quality sucked. Since I saw other people using them in projects, I figured they had improved. Didn't even think about monitor orientation.
Cobolisdead
« Reply #14 on: September 18, 2015, 09:54:55 am »
D
Yeah, I have that particular one, and I can attest that it is horrible.
« Reply #15 on: September 22, 2015, 11:35:30 pm »
Scored big tonight on Craigslist!   $40 got me this:
- Burn free monitor with Weiya universal chassis
- Ms. Pacman complete PCB
- Ms. Pacman daughter board.
- original Midway isolation transformers and fuse block
- original harness
The guy had gutted it a while back for a 60 in 1 and LCD and sold the machine. It has since sat in his garage... Until now. :-)
I'm stoked. It was listed As a Pacman in the ad.  It also has the speed chip installed. It was totally worth the 90 minute drive (each way).
Yotsuya: We have some EPROMs to burn!
DeLuSioNaL29
« Last Edit: September 22, 2015, 11:37:04 pm by DeLuSioNal29 »
« Reply #16 on: September 23, 2015, 01:02:04 am »
- original harness
DeLuSioNaL29
Did someone call the cops? 'Cause you STOLE that, mofo!!!!  :cheers:
« Reply #17 on: September 23, 2015, 11:56:21 am »
damn!  :cheers:
JimmyU
  • Last login:July 28, 2025, 08:19:07 pm
  • I believe I can fly!
« Reply #18 on: September 23, 2015, 01:16:59 pm »
Nice score!
Token
« Reply #19 on: September 23, 2015, 02:54:03 pm »
For all your painting supplies at the Depot: PM me for a Pro Rewards #.
20% discount.
« Last Edit: November 12, 2015, 12:36:42 pm by Token »
« Reply #20 on: October 23, 2015, 01:42:29 pm »
So I was researching coin doors today (since I need one for the completion of this project) and I came across 3-D printed ones.
Interesting:
http://www.shapeways.com/product/YFWC2HUU4/coin-door?li=gmerchant&utm_source=google&utm_medium=cpc&gclid=CPOr2I6M2cgCFVIXHwod3bUNeA&optionId=43343808
Not sure if I'd use one, but still, cool nonetheless.
DeL29
johnrt
« Reply #21 on: October 23, 2015, 02:16:47 pm »
Interesting:
Cool! This might open up some great possibillities at least on some bartops.
« Reply #22 on: October 23, 2015, 02:25:42 pm »
And they have coin slots!  http://www.shapeways.com/search?q=coin+slot
Could also be an interesting option for bartops.
« Reply #23 on: October 26, 2015, 01:20:30 pm »
Any one have any leads for Midway coin doors?  I'm needing everything including the mechs.
D
« Reply #24 on: November 12, 2015, 12:28:11 pm »
Figured it was time for a small update.  I moved my project indoors since it's been cold out.  I set up a section in the new game room just for painting.  :-)
The picture is crude, but it's the first coat of the color matched Super Pac-man blue that I grabbed from the back door of the cabinet.  Probably taken crudely on purpose, since it looks crappy close up  ;D.  Once I get multiple coats on there though I'll take better pics.
D
« Reply #25 on: November 23, 2015, 10:50:47 am »
Gave it a light sanding and another coat last night. Progress is slow. Haven't had much time to work on it.
vwalbridge
« Reply #26 on: November 23, 2015, 10:53:35 am »
Lookin' good DeL.  That a satin finish?
« Reply #27 on: November 23, 2015, 01:13:12 pm »
A little bit shinier:  Semi-Gloss.  The paint code is listed above on the can.
D
