Author Topic: Hi  (Read 984 times)
midd
  • Last login:August 01, 2025, 05:44:02 pm
Hi
« on: September 13, 2015, 09:17:03 am »
First post.  Just wanted to say hi and looking for a little help.
I have my Arcade computer with various systems installed.  I don't have any desire to build a cabinet for now as I'm ok with just hooking it up to my Tv and playing every now and then.  I use an X-Arcade dual joystick which I bought dirt cheap off craigslist.  And a Thrustmaster steering wheel for next to nothing.
I'm already wanting to swap the joysticks out of the X-Arcade.  I'm considering the Mag-Stik Plus because I want the convenience of jumping from 8 way to 4 way.  Will it be just a simple swap? I've seen some Youtube videos for swapping other sticks that require a dremel.
Thanks.
jeremymtc
  • Last login:October 22, 2025, 08:45:06 am
Re: Hi
« Reply #1 on: September 13, 2015, 04:50:06 pm »
Hi midd, welcome aboard.
Magsticks will require a little bit of modding to fit your X-Arcade case, but it is easily doable.
The easiest way is to use a pair of these adapter plates to replace the original Magstick top plate: https://www.paradisearcadeshop.com/mounting-plates/1280-universal-arcade-joystick-adapter-plate.html. Using these plates you won't need to drill new mounting holes in the panel and you can use the original X-Arcade mounting hardware.
If you don't use an adapter plate you will need to reroute and redrill the panel.
Hope this helps   :cheers:
midd
Re: Hi
« Reply #2 on: September 13, 2015, 06:05:10 pm »
Yes it does help. Thanks for the info!
