Author Topic: Janky Kong - The Final Frontier  (Read 92135 times)
  • Last login:February 01, 2026, 05:25:13 pm
Re: Janky Kong - Now in Phase Two
« Reply #120 on: August 16, 2015, 10:09:34 am »
Great job Yots! Dont you just love it when the plan comes together?
 :applaud: :applaud: :applaud:
  • Last login:Yesterday at 06:31:37 pm
« Reply #121 on: August 16, 2015, 01:28:05 pm »
You had me at CRT...
me three.
Thanks, guys. Last night when I was at Starfighters, I saw the exact monitor I would LOVE for this thing- a Wells Gardner 19" VGA monitor. Oh hell, it was so beautiful and easy to use.
Well, if you're going to have one of those hideous Nintendo cabinets laying around, the only thing that's going to make it look worse is an LCD.
Careful, you're gonna make Baby Chance cry....  >:D
But I completely agree. Having seeing one in person, yes, I don't want to keep the LCD in this cab.
Thanks, Ken. Yes, I do. Especially when you consider the state I got it in.
Next steps: Clean up the wiring inside, hunt for a CRT, and get a lower bezel retainer.
ChanceKJ
« Reply #122 on: August 16, 2015, 04:02:32 pm »
....Go on...
« Reply #123 on: August 16, 2015, 04:19:58 pm »
....Go on...
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%2014k3101-19k3102.pdf
jdbailey1206
« Reply #125 on: August 16, 2015, 06:46:00 pm »
I just picked up two arcade CRT's from my buddy Jawhn right now. I don't even want to tell you what I paid for them. They're both burn free, and probably need cap kits, but it's a nice problem to have.
« Last Edit: August 16, 2015, 08:24:45 pm by yotsuya »
« Reply #126 on: August 16, 2015, 06:58:07 pm »
$Free.99?
« Reply #127 on: August 16, 2015, 07:17:21 pm »
ChanceKJ
« Reply #128 on: August 16, 2015, 07:41:44 pm »
You'd honestly be surprised how often that works up here when we want to trap people from Edmonton. The stage part is, the bottom of the net is still on when it traps them, but they're too stupid to realize.
$Free.99?
$20 for the two.
You're not serious?
« Reply #129 on: August 16, 2015, 07:44:16 pm »
This space left intentionally blank.
« Last Edit: August 16, 2015, 08:23:13 pm by yotsuya »
« Reply #130 on: August 16, 2015, 07:45:17 pm »
Quote from: ChanceKJ
You're not serious?
I am serious. And don't call me Shirley.
« Last Edit: August 16, 2015, 07:46:57 pm by yotsuya »
« Reply #131 on: August 16, 2015, 07:46:00 pm »
 :woot
« Reply #132 on: August 16, 2015, 07:46:07 pm »
What can I say, it pays to network!
ChanceKJ
« Reply #133 on: August 16, 2015, 08:10:08 pm »
agreed!
« Reply #134 on: August 17, 2015, 01:03:30 am »
CRT or GTFO!!!
« Reply #135 on: August 17, 2015, 01:04:48 am »
And from the front!
But before I even think of firing it up, I gotta do some work on the flyback. But actually having the monitor is half the battle.
« Last Edit: August 17, 2015, 01:02:23 pm by yotsuya »
jdbailey1206
« Reply #136 on: August 17, 2015, 12:59:43 pm »
« Reply #137 on: August 17, 2015, 01:06:24 pm »
....is half the battle.
I can't hear you. Come run repeatedly into my fist to see if that helps.
Ok, so looking at the flyback on this monitor, it appears that it's arching. My buddy wrote on the test tag "Sparks from the flyback. And flames. Seriously."
Looking at the flyback, there is a small hole near the focus knob. Doing some research, this is actually a pretty common thing. Ken Layton recommends hacking 1/4 inch away from the metal cage that surrounds the flyback, and smalltownguy has fixed the same issue using epoxy, so I'm going to try those two things first before I even fire this mofo up. Then we'll see what the next steps are. The other monitor I plan to throw in the Super Pac-Man cocktail project I'm tinkering with.
« Reply #138 on: August 17, 2015, 01:07:16 pm »
Looks good Yots!  I'm planning a MAME .vs build in the future too.  I'm really curious to see what you do with the front end.
D
« Reply #139 on: August 17, 2015, 01:13:29 pm »
D
I'm going to go with AtomicFE. I have it set up with a logo wheel/screenshot type setup. I'd like to try and use a motion background (just that Nintendo purple grid acting all floaty), and I'd like to try and give the logos more of an 8-bit look. Ideally, I'd like for it to look like the images were being "generated" in real time as opposed to simply being static images. I'll throw some pics up later tonight when I get home from work.
It's only got Vs. games on the wheel, although I did set up a sub-wheel with NES games I like playing. I didn't make it part of the hierarchy, but it's there.
jdbailey1206
« Reply #140 on: August 17, 2015, 05:35:15 pm »
« Reply #141 on: August 22, 2015, 06:48:13 pm »
Mini-update-
This back power plate is going to need some love... Fuse holder on the way, let's see what we can salvage...
« Reply #142 on: September 03, 2015, 02:20:20 am »
Spent the evening doing a cap kit on the monitor.  Just gotta patch up the flyback, then hopefully all will be good.
ChanceKJ
« Reply #143 on: September 03, 2015, 03:48:23 am »
What chassis is that?
« Reply #144 on: September 03, 2015, 05:50:05 pm »
It's a Kortek chassis. See that big ol' block of metal around the flyback? Yeah, that needs to be trimmed away. That's what was causing the flyback to spark and arc. According to Ken Layton, chopping a half-inch off the opening should be fine. I'm also going to patch any pinholes with epoxy.
Oh, and I love janky stuff like this:
http://www.ebay.com/itm/Original-Bite-Monster-Pac-Man-Style-Arcade-Marquee-Sign-Banner-Video-Game-/291553075100?hash=item43e1eadf9c&rmvSB=true
« Reply #145 on: September 03, 2015, 08:57:42 pm »
Here comes a flurry of pics! Chassis hacked to open up the flyback area.
« Reply #146 on: September 03, 2015, 08:58:39 pm »
Look at the size of that hole on the flyback!
« Reply #147 on: September 03, 2015, 08:59:54 pm »
Cleaned and patched with epoxy, as per smalltownguy's recommendation.
« Reply #148 on: September 03, 2015, 09:01:23 pm »
Installed. I'm gonna let the epoxy dry so I probably won't hook this up until the weekend.
« Reply #149 on: September 04, 2015, 08:33:19 am »
Why not just get a new flyback?  I'd be afraid that it would fail and cause a fire.
« Reply #150 on: September 04, 2015, 09:11:07 am »
Because I trust smalltownguy when he tells me that this fix worked. If it doesn't I will, but in the DIY spirit, I want to see if this works for me.  :cheers:
vwalbridge
« Reply #151 on: September 04, 2015, 09:47:25 am »
I like how you cut right through the word "CAUTION"  :)
Also that looks like JB Weld?
  • Last login:February 02, 2026, 07:47:27 pm
« Reply #152 on: September 04, 2015, 09:48:46 am »
Looks like a legit repair to me.  That glue is probably sturdier than the original casing.
« Reply #153 on: September 04, 2015, 09:53:16 am »
That right there gentlemen is the PBJ frugal repair seal of approval....
« Reply #154 on: September 04, 2015, 10:46:09 am »
Yeah, it's a two-part epoxy.
The "hole" if you will, results from the proximity of the flyback to that cage. Since the metal is so close, any pinholes result in arcing. Ken Layton recommends trimming back 1/4 inch, I went 1/2. I'd ditch the cage altogether, but there are some transistors mounted on it.
Yep, you are correct, sir. I checked it after it had set for 4 hours, and it was solid.
I'm not a foolish American with deep pockets and an impulsive behavior. A new flyback would cost me 3x what I paid for the whole monitor. I'll try a posted, tested fix first, and if it doesn't work, THEN I'll spend the $$$.
« Reply #155 on: September 07, 2015, 11:51:02 pm »
Another shout out to my homeboy Wyo for the awesome Nintendo coin door he sold me when this was still a Creamsicle mess....
« Reply #156 on: September 07, 2015, 11:52:07 pm »
Fergot the pix!
ChanceKJ
« Reply #157 on: September 08, 2015, 12:16:53 am »
Those coin mechs look so shiny.  :laugh:
« Reply #158 on: September 08, 2015, 01:12:46 am »
Yep.
I'm pretty excited to get the monitor running in Janky Kong. I found my isolation transformer right now, so I'll wire it up tomorrow and see what happens.
« Reply #159 on: September 15, 2015, 02:57:15 am »
So my line filter came in. I went ahead and wired everything up on the old iso/power supply board inside Janky Kong. I dug through my boxes o' stuff for all the Molex connectors that I needed and was able to get everything connected satisfactorily.
This monitor was the one with the sparking flyback, the one I repaired with epoxy as recommended by Smalltownguy and trimmed the flyback cage as recommended by Ken Layton. With all that done, and a new capkit, I hooked up my CraftyMech TPG and gave it power....
And as you can see, she's alive!
Next step is to set up the new computer I'm using for this one with AtomicFE and the J-Pac, then plug it in and see how my Multi-Vs. setup works.
