Author Topic: Cherry Switch quick connects on ebay  (Read 867 times)
  • Last login:November 30, 2025, 12:59:41 am
« on: August 05, 2015, 05:05:04 pm »
I'm looking to buy daisy chain grounds, which I found here:
http://www.ebay.com/itm/Jamma-Sanwa-Button-Joystick-16-connection-110-Ground-Wire-Daisey-chain-cable-/171767893305?hash=item27fe2a0d39
But I'm also looking for single wires with a quick conenct (1 meter long or so). I can't figure out the search term to find wires, hell, I don't know if ebay is even the right source for these. Can anyone point me in the right direction. I normally solder these, but for this latest project, I'm going to go with quick connects
1 last question - whats the right size connector (.11 or .187) for happ cherrys?
Thanks in advance for the help!
jeremymtc
  • Last login:October 22, 2025, 08:45:06 am
Re: Cherry Switch quick connects on ebay
« Reply #1 on: August 05, 2015, 07:23:07 pm »
Cherry switches use a .187" connector.
Not sure about wire leads with terminals pre-installed. I did a quick Ebay search using the term "wire with spade connector" and there some results. Why not just use some crimp terminals?
  • Last login:Yesterday at 04:58:52 pm
« Reply #2 on: August 05, 2015, 07:33:39 pm »
« Reply #3 on: August 05, 2015, 09:23:54 pm »
Thanks Jeremymtc!
After doing some browsing, I settled on a jamma interface since it has the .187 ends on it. I'm helping my 17 year old cousin build this and I didn't want to mess with soldering or crimping. He's already cutting, measuring, gluing and screwing! Cutting the ends to length and installing in an ipac is enough work for now.
