Author Topic: GroovyMame with Mala causing audio issues  (Read 3189 times)
alomar123
  • Last login:June 15, 2017, 01:36:25 pm
« on: July 28, 2015, 09:50:04 pm »
Is anyone running GroovyMame 163 with Mala 1.820?
When I run roms just using GroovyMame 163, everything is perfect. However, when using Mala, the sound is completely off and just sounds weird. Additionally, I cannot configure MAME in the Mala settings (it crashes each time I try, I have attached my mala log). Is mala not using the ini s associated with my Groovymame application?
Are the two most current versions, just not compatible right now? Does anyone have a working combination (I have to use GroovyMame)?
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: GroovyMame with Mala causing audio issues
« Reply #1 on: July 30, 2015, 02:16:30 am »
Perhaps, this link could be interesting for you.
Greetings.
