Author Topic: DK JR restoration!  (Read 27337 times)
vwalbridge
Re: DK JR restoration!
« Reply #80 on: January 12, 2016, 11:18:31 am »
Any reason why I can't replace that with black poster board?
You sure can!
Cobolisdead
« Reply #81 on: January 12, 2016, 11:25:29 am »
Cool!
ChanceKJ
« Reply #82 on: January 12, 2016, 11:31:15 pm »
« Last Edit: March 19, 2021, 03:17:51 am by ChanceKJ »
Cobolisdead
« Reply #83 on: January 12, 2016, 11:46:55 pm »
Well, I got the capkit done and the monitor reassembled. I got it back installed in the cabinet, and turned it on. Fortunately, it did not catch fire. It looked a lot better, with much better colors than prior to the capkit. However, the vertical collapse still remains!
Cobolisdead
« Reply #84 on: January 12, 2016, 11:47:52 pm »
Any ideas on what to try next?
Cobolisdead
« Reply #85 on: January 13, 2016, 09:48:20 am »
The original schematic for the sanyo called for a 100uF 16V cap. The later revisions of the schematic have 10uF 50V there. I don't believe it will be harmful either way so if you already have a cap kit, use it if you want.
Just for your own sanity. check the cap that is on your sanyo. I ran around my basement looking for all the sanyos I haven't capped yet to verify and they all had 10uF 50V. So I am going to keep packing the 10uF 50V in mine.
Hey Ian, can you tell me if these two are the transistors that are in the pic attached?
https://iankellogg.com/index.php?main_page=product_info&cPath=1_4&products_id=94
It was recommended that I replace those to try to fix this problem.
Cobolisdead
« Reply #86 on: January 13, 2016, 10:11:38 am »
It seems that someone else on KLOV confirmed that those are the ones that I need to replace! So, I ordered those from Ian and got the two day shipping. Hopefully I will have them this weekend to get cracking on this!
vwalbridge
« Reply #87 on: January 13, 2016, 10:38:01 am »
Yo...you need some Simple Green up in that monitor chassis.  ;)
Cobolisdead
« Reply #88 on: January 13, 2016, 10:56:11 am »
LOL!
Yeah, that isn't mine, its just the one that someone posted on KLOV to show me what parts they believe that I needed to replace. Not that my Chassis is that much better mine you.
Cobolisdead
« Reply #89 on: January 15, 2016, 04:59:58 pm »
I did pick up some mean green yesterday to clean up the monitor with.  Hopefully it will do a decent job. Capkit with the missing Capacitors is on the way and should be here tomorrow, thanks to Ian! Hopefully I can get this thing up and running!
Cobolisdead
« Reply #90 on: January 16, 2016, 06:11:53 pm »
So the parts are here, but quick question. Can the Bipolar Caps be inserted either way or is there a trick to them?
vwalbridge
« Reply #91 on: January 16, 2016, 06:27:16 pm »
Bipolar caps can go either way. They don't have polarity.
Cobolisdead
« Reply #92 on: January 16, 2016, 07:36:44 pm »
And the problem is fixed!  :applaud:
Now to cut out a new shroud and and then to fix the side art!
Cobolisdead
« Reply #93 on: January 19, 2016, 12:22:51 pm »
Anyone know where to get a bulb and starter for this cabinet? The place they recommended on KLOV wanted $21 for shipping.
vwalbridge
« Reply #94 on: January 19, 2016, 12:44:19 pm »
Here is the bulb
Here is the starter
Alternativly you can go to TopBulb.com
Then type in the following part numbers.
Here is the fluorescent bulb ($1.75):
F10T8/CW
Here is the starter ($3.75):
FG-7E
All of the above goes credit to John's Arcade.
HOWEVER,
If you really want to keep in simple you can just get a Fluorescent Light Fixture from Home Depot. I'm told a 120v light fixture will still work on the 100v plug in a DK cab. (This is what I will be doing for my DK. It was missing the entire fixture)
Cobolisdead
« Reply #95 on: January 19, 2016, 02:01:08 pm »
Bulbtronics is the place that wants $21 for shipping. Topbulb only wanted $9, so for $14 shipped, that works for me.
SlammedNiss
  • Last login:January 30, 2026, 11:45:25 pm
  • Mine Drags the Ground!
« Reply #96 on: January 19, 2016, 05:47:11 pm »
HOWEVER,
This is what I did when I bought my DKJr. cab 15 years ago. Still going strong.
Cobolisdead
« Reply #97 on: January 19, 2016, 09:25:47 pm »
I will have to remember that for the next one then.
The wife and I cut out the new shroud and it fits! Just need to work on the sides tomorrow and get the adhesive residue off of them so I can put on the new side art and this project will be finished!
Cobolisdead
« Reply #98 on: January 20, 2016, 10:24:18 pm »
So I worked the side of the cabinet with a plastic razor, goo gone adhesive remover, and a wire scrub brush and I still couldn't get all the old adhesive off of it!
« Reply #99 on: January 20, 2016, 10:33:23 pm »
Been following, stop teasing, it's time for some pics!
I kid of course...  ah adhesive residue the arcader's proverbial hemmroids.
Cobolisdead
« Reply #100 on: January 20, 2016, 11:38:21 pm »
Here is the cab side after I initially worked it over for around an hour or so.
And here it is once I stood it up again and worked it with plastic razors swapping them out every three minutes or so.
Somewhat improved but not really.
Cobolisdead
« Reply #101 on: January 22, 2016, 09:26:52 am »
New side art has been ordered, and hopefully should be here by next weekend. Then I can finally finish this project!
Cobolisdead
« Reply #102 on: January 30, 2016, 09:34:31 pm »
new side art is on! I need to get some double sided tape for the shroud, but then she should be all done! Pics coming soon!
Cobolisdead
« Reply #103 on: January 31, 2016, 07:04:57 pm »
Here is my video!
Finally done with this project!
vwalbridge
« Reply #104 on: January 31, 2016, 07:37:24 pm »
Watched the video. Nice DK Jr. You have there.
It's cool you know the history behind it. I was wondering about the decals on the side. Enjoy it!
Nice work and thanks for sharing!  :cheers:
SlammedNiss
« Reply #105 on: January 31, 2016, 10:40:45 pm »
Looks good!  But...
Cobolisdead
« Reply #106 on: February 01, 2016, 01:11:58 am »
Thanks! Yeah, the decals are just stamps that they put on each machine. Goes back to the early 90s on this one. I thought it was neat and left them on there.
Cobolisdead
« Reply #107 on: February 01, 2016, 01:12:53 am »
Looks good!  But...
LOL! Well, if you saw the rest of my packed garage, you would be telling me to turn that camera. :)
