Author Topic: 1981 Coleco Ms Pacman Tabletop Arcade Repair  (Read 3328 times)
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
« on: July 06, 2015, 02:32:09 pm »
I would like to repair a Ms Pacman tabletop, the joystick does not go down. Does anybody know where I can get parts? Attached is a picture of the silver tab that needs to be replaced. I have no idea even what it would be called.
Re: 1981 Coleco Ms Pacman Tabletop Arcade Repair
« Reply #1 on: July 06, 2015, 03:54:28 pm »
You can't get her to go down? That's not normally an issue unless you married her.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: July 06, 2015, 04:52:49 pm »
I had several of these as a kid and they all went bad. I wish I still had them.
« Reply #3 on: July 06, 2015, 04:54:16 pm »
Is the tab cracked? I assume they're like the old Atari joystick switches, which are little domes that flex and pop up when not used, but make contact with a pad underneath when activated.
« Reply #4 on: July 06, 2015, 06:52:42 pm »
I would search the web for a broken one on the cheap.  (Google "Coleco tabletop")Then you can grab the part from the broken one.
That said, I would not take it from a working one, even if it was cheaper.  There is no sense destroying one for a part for another.
Update:  Try contacting the guy on this page.  Looks like he repairs them.  It can't hurt to ask him if he has that part available.  http://www.geekvintage.com/coleco-tabletop-galaxian.php
Del
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #5 on: July 06, 2015, 10:44:25 pm »
http://www.true-tone.com/
you have to get out the calipers and measure it and see if you can match something up
  • Last login:Today at 06:13:41 pm
    • GroovyGameGear.com
« Reply #6 on: July 07, 2015, 12:05:48 pm »
My first question is whether this is a "collector quality" piece, or whether it's beat up and you are just trying to get it working to give to the kids to play with?
If the latter, I'd be really tempted to hack in some low-profile PCB-mounted miniature switches.  Might even be able to drill a hole in the pcb for the actuators and bottom mount them.
But if it's in collector condition, I'd look for the parts.
« Reply #7 on: July 07, 2015, 12:28:24 pm »
Try ordering this free sample box and see if something fits:
http://www.snaptron.com/free-samples/
« Reply #8 on: July 07, 2015, 11:25:19 pm »
a handfull of iphone4s home buttons would probably work a treat and enough to fix all of them could be had for a few bucks.
http://www.ebay.ca/itm/Home-Button-Back-Menu-Key-Keypad-Flex-Cable-Ribbon-Replacement-for-iPhone-4S-/161695366801?pt=LH_DefaultDomain_2&hash=item25a5cb7e91
« Last Edit: July 07, 2015, 11:27:03 pm by lilshawn »
dendawg
  • Last login:February 03, 2026, 07:10:40 pm
« Reply #9 on: July 08, 2015, 01:23:53 pm »
OP, what you're looking for is called a Dome Switch.  Hope that helps in your search!
