Author Topic: Virtual pinball  (Read 13362 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
Virtual pinball
« on: May 22, 2015, 09:46:42 am »
Hi
I decided that my next project will be a virtual pinball.  This is something I wanted to do long ago. But I had no space in the room, until now.
 anyway i want to order some part, and i see this one http://nanotechent.com/mot-ionkit.php
 my question  is there simple way to connect Plunger With micro switch?
Thanks for the help
so far...
  • Online Online
  • Last login:Today at 03:48:43 am
Re: Virtual pinball
« Reply #1 on: May 22, 2015, 07:33:06 pm »
Check http://www.vpforums.org/ for more information on the pros/cons of the Nanotech kit vs. the newer VirtuaPin™ Digital Plunger Kit v2 -- users have reported issues with both options.  :dunno
The upside to these kits is the analog nudge feature.
Many builds have used a microswitch with a plunger, but the microswitch can take a pretty bad beating, depending on how it is mounted.
IIRC one build used a fender washer mounted on the tip of the plunger using a cotter pin through the plunger shaft.
When the plunger was pulled back, the washer would press the lever arm of the microswitch.
There were also blocks that kept the washer from pulling back so far that the switch is damaged.
jackiabu
Re: Virtual pinball
« Reply #2 on: May 23, 2015, 02:50:36 am »
from first look both of this prodcate look a lot of head case to operate ??? it's not because the price. i don't understand why the don't build a simple kit? like this guy did
http://arturosarcadelab.blogspot.co.il/2011_06_01_archive.html
Anyway Thanks scott for your help ;D i will check it out.
Speed Racer
  • Last login:March 14, 2018, 11:06:09 pm
Re: Virtual pinball
« Reply #3 on: May 24, 2015, 10:40:12 pm »
This. I think the micro switch would get hammered pretty bad if the plunger makes direct contact with it. You could rig it so that the plunger engages a switch when it is pulled back like in this old thread http://forum.arcadecontrols.com/index.php/topic,7361.msg53235.html#msg53235
Something to bear in mind with these setups that use a microswitch is that although they have a "real" plunger, they effectively reduce it to a "button". You could just get one of those large "launch ball" pinball buttons that were found on later pinball machines http://www.pinballlife.com/index.php?p=product&id=1685
On my pinball build I have gone with the V2 from virtuapin, but can't really comment on how good it is yet. I suspect it is better than the nano tech because it auto calibrates everytime the PC is turned on. I think I read than the old version regularly went out of calibration and was a pain to fix.
The advantage of these expensive plungers is that they adjust the power of the shot based on the position of the drawn back plunger (distance). The microswitch option adjusts the power based on how long (time) you pull it back for. They should be more "authentic" (and I use that term pretty loosely), but whether it is worth the extra $$$ is up to you  ;D
jaharr01
Re: Virtual pinball
« Reply #4 on: May 25, 2015, 12:18:55 am »
Microswitch- may as well have a launch ball button.
Nanotech plunger- I have one on my pincab, the analog nudge is crap, everything else works great.Initial calibration is a bit querky. Only the nudge loses calibration. Unless it's a big cab, i wouldn't use analog nudge. I would put buttons in front of the flippers for nudge, but it's your cab. If you use analog nudge you better make sure everything is mounted solid, or you will be chasing down wiring problems. i thought about trying one of these on mine http://www.amazon.com/Parts-Express-Mercury-Tilt-Switch/dp/B0002ZPBKM
Mouse plunger thread http://www.vpforums.org/index.php?showtopic=14861
A DIY nudge device I made but never hooked it up http://forum.arcadecontrols.com/index.php/topic,143794.msg1493345.html#msg1493345
Another tidbit is I spent a ton of time setting up my nanotech plunger for each table. Some are easy, some are hard,and some the plunger won't work.
Martijn
  • Akira!
    • ModMyBox
Re: Virtual pinball
« Reply #5 on: May 25, 2015, 03:59:31 am »
I have the VirtuaPin™ Digital Plunger Kit v2 and been using it for about a year now. Its working great, plunger and nudging is working like it should.
And i have all the buttons also wired to this kit , so you dont need something like a ipac
jackiabu
Re: Virtual pinball
« Reply #6 on: May 25, 2015, 01:02:47 pm »
thanks you guys for your advice :)
i think i will order the Digital Plunger Kit v2 . i only need to know or see how all its pluged in? some pics please?  i send a mail to virtuapin...but no response :-\
can someone recommend me a good site for all this stuff to my pinball cab? i need allso Chrome Legs...in ths same site i see this bundle  http://virtuapin.net/index.php?main_page=product_info&cPath=3&products_id=9
it's extremely high price...
Anyway today i continue to work on the cab...
Peabo
  • Pinball junkie
    • Virtual Pinball Build
Re: Virtual pinball
« Reply #7 on: May 26, 2015, 07:02:40 am »
http://www.pinballlife.com/ is a good source for parts.  I have a standard cab virtual pin using Zeb's controller/plunger http://www.zebsboards.com.  I also have a mini pin that's in the works, I'm just using a mini Ipac on it, no plunger.  If your going to use a plunger, keep in mind that it's about 10" long and will have to slide under the monitor.
Here's my mini pin that's in the works:
jackiabu
Re: Virtual pinball
« Reply #8 on: May 26, 2015, 11:26:03 am »
Nice cab you build there :cheers: and thanks for the links
i have some question to you...can you show me pic how you connect your The Digital Plunger Kit v2 with all the wire, pcb, to your cab?
allso i have some difficulty to put my LEd tv on my cab :banghead:  can you show me how you put your  led/plasma on your cab?
Peabo
  • Pinball junkie
Re: Virtual pinball
« Reply #9 on: May 26, 2015, 01:29:47 pm »
On my Fullsized cab, I routed the sides and just set the LCD on rails attached to the sides.  The I cut strips that fit the gap in sides above the LCD and attach them through the side rails using binding posts.  The glass channel still fits in place like originally.  The plunger was moved down so that it passes under the LCD on this cab.
The mini cab is just a simple tray that the monitor sits on:
Here's a picture where you can see the plunger and the controller for it.  This shot is the Nanotech plunger kit bottom center. I'll have to snap a new photo with Zebs board installed.  These just use a USB cable to the PC.  Each button/flipper connect to a port on the board.  The LEDWiz controls my LEDs and Contactors
Photos of both pinball cabs and my bartop on my flickr page here:  https://www.flickr.com/photos/dclracing08/sets/72157645521699503
jackiabu
Re: Virtual pinball
« Reply #10 on: May 26, 2015, 02:48:09 pm »
Peabo thanks for your pics... i will see how can i put my led Tv on my cab.
one more thing about the plunger is it plug n play? or need some setup?
« Last Edit: May 26, 2015, 02:55:43 pm by jackiabu »
johnrt
Re: Virtual pinball
« Reply #11 on: May 26, 2015, 04:43:59 pm »
How did you cut your panels? They look like they're laser-cut or something. Very nice work!  :applaud:
Peabo
  • Pinball junkie
Re: Virtual pinball
« Reply #12 on: May 26, 2015, 07:55:40 pm »
The plunger (Zeb's) is plug and play.  You calibrate it once like any other gamepad/joystick and that's it.
jackiabu
Re: Virtual pinball
« Reply #13 on: June 02, 2015, 02:35:44 pm »
Update:
SpaceHedgehog
  • Almost done ...
Re: Virtual pinball
« Reply #14 on: June 02, 2015, 04:34:04 pm »
Very shiny :) Enjoying watching this come together  :cheers:
Click a pic for a video tour
jackiabu
Re: Virtual pinball
« Reply #15 on: June 03, 2015, 09:40:11 am »
thanks men ;D
danielmarokoi
  • Last login:July 30, 2015, 05:58:20 pm
Re: Virtual pinball
« Reply #16 on: June 03, 2015, 09:50:26 am »
Clean and sharp  ;D keep it up  :applaud:
jackiabu
Re: Virtual pinball
« Reply #17 on: June 05, 2015, 12:38:50 pm »
Update:
now waiting for the packaging from virtuapin :P
All ready order a glass  5mm.
danielmarokoi
Re: Virtual pinball
« Reply #18 on: June 06, 2015, 05:05:55 am »
nice men :P
I think the thin of the glass should be 6mm ???
jackiabu
Re: Virtual pinball
« Reply #19 on: June 11, 2015, 02:39:45 pm »
Update:
meanwhile there is a big delay to my second package from virtuapin  http://virtuapin.net/  :angry: :angry: :angry:  only because they out of stock "Launch Ball buttons " :timebomb:
jackiabu
Re: Virtual pinball
« Reply #20 on: July 27, 2015, 10:44:15 am »
Well after a big delay of a month. the second package has arrived... they split my package. :badmood:
anyway continue the job
jackiabu
Re: Virtual pinball
« Reply #21 on: July 27, 2015, 11:01:03 am »
I order a glass for the backbox  and  Playfield.
jackiabu
Re: Virtual pinball
« Reply #22 on: July 28, 2015, 12:47:14 pm »
I can see the light...continue work ;D
brihyn
Re: Virtual pinball
« Reply #23 on: July 28, 2015, 10:58:50 pm »
I might have missed it, but what are you using to make it so nice and shiny?
And can you give details of how you fashioned the lockdown? doesn't look metallic....I'm trying to come up with ideas.
jackiabu
Re: Virtual pinball
« Reply #24 on: July 29, 2015, 03:09:18 am »
i am using black formica ;D  by the way with all my projects .
The lockdown its all so from wood...but my plane is to cover it with metal aluminum.
danielmarokoi
Re: Virtual pinball
« Reply #25 on: July 30, 2015, 05:12:11 pm »
I hear that this plunger kit have a lot issue problem  pinball :-\  is it the same situation here?
Nice job you doing :applaud:
jackiabu
Re: Virtual pinball
« Reply #26 on: August 04, 2015, 04:21:58 pm »
Yes there are some problem ???
its not work like Ipac, it's "emulate joystick" kind of...so  you can't play pinball fx  for instance :dizzy:  anyway i have a lot work on Hyperspin And future pinball.
so i will get it later...
jackiabu
Re: Virtual pinball
« Reply #27 on: August 05, 2015, 11:01:09 am »
Well the big day has arrived ;D i finally get the pinball from my carpenter.
so in need space in my arcade room...
this my computer: P6TD Deluxe.  I7 ,16gb Ram, 1gig ati graphics card.
connecting the plunger kit
The boy can't wait :D
Start...
some tweaking on FP
Magical ;D
Vid:  https://www.youtube.com/watch?v=UuDPBbQ-Vi0&feature=youtu.be
Re: Virtual pinball
« Reply #28 on: August 05, 2015, 11:56:50 am »
Nice job so far!  Subscribed!
D
jackiabu
Re: Virtual pinball
« Reply #29 on: August 06, 2015, 02:35:50 am »
D
Thanks man ;)
jackiabu
Re: Virtual pinball
« Reply #30 on: August 06, 2015, 12:15:49 pm »
Update:
Add some  button
need to think how do i add this frame ???
meanwhile i'm getting hard time in SETUP the right res in FP....there is some lag in future pinball.
so i decided to replace a new nvidia graphics card 4GB ram...and uninstall the ATI 1gb card/
The new one
