Author Topic: rom loads in mame not mala  (Read 4668 times)
ocbot
  • Last login:May 27, 2015, 08:16:33 pm
« on: May 19, 2015, 12:09:57 am »
Hey everyone I am setting up this new machine . Most everything has gone to plan due to the advice and help from this and a few other forums. Unfortunately I have a issue with mala recognizing a handful of games. I've search around, but I can't seem to find a solution that works.
Running mame 161 with mala 1.74 on windows xp 32bit
Most everything is working fine but there are a few roms that appear and run in mame, but refuse to even display in mala (let alone run). I tried starting over re-installing both programs on another hd and added only the few roms that I wanted to test. I let mala rebuild a new xml file (which I thought could be the issue) and left all of mala's game collection filters unchecked. Roms still will not appear in mala... What am I missing?
Deckmega
  • Last login:August 03, 2015, 10:39:01 am
Re: rom loads in mame not mala
« Reply #1 on: May 19, 2015, 01:30:15 am »
if you marked ( search in subfolders )rom path,  clear.
if you marked (hidden)Dos window state, Choose ( normal).
ocbot
« Reply #2 on: May 20, 2015, 12:32:33 am »
Unfortunately that doesn't solve the issue.
thanks though.
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #3 on: May 20, 2015, 03:30:33 am »
You should use the last version of mala 1.820
You could enable logging and edit to try to see where the error is. You can see how can you enable the log in this link Sorry, in spanish).
Greetings.
« Last Edit: May 20, 2015, 03:56:21 am by empardopo »
ocbot
« Reply #4 on: May 20, 2015, 10:53:49 pm »
empardopo, eres mi héroe!  :applaud:
Updating to the beta verson resolved the issue I had with the roms. Thanks for responding!
empardopo
    • My personal forum
« Reply #5 on: May 21, 2015, 12:41:11 am »
I'm glad you've solved.
Greetings.
