Author Topic: nsm wall performer display problem  (Read 7659 times)
chrisf1
  • Last login:February 09, 2023, 09:36:50 am
« on: May 07, 2015, 01:50:06 pm »
Hi again everyone I hope someone can help me out here i have a performer wall with 100 cd's and after laying dormant for a year I had a board battery replaced and it is working again but my title display cards are not moving and when i press the shift button i get error 90 i have been told  i need to empty the displays out completely and then try to operate it, it should then free up and be back to normal can someone talk me trough this process as they obviously have to be positioned in there correct places and the person who told me this says he is to far away to do it
  • Last login:Yesterday at 06:22:50 pm
Re: nsm wall performer display problem
« Reply #1 on: May 07, 2015, 05:44:01 pm »
the process is a real bugger to reset. (even with experience, it can take an hour or more) it involves removing literally EVERYTHING and resetting it.
I'd check the wire connections to the title rack unit and try to clear the error first and see if it comes back to life before i'd go ripping into the title rack.
chrisf1
« Reply #2 on: May 07, 2015, 06:43:55 pm »
would love to please tell me how thanks Chris
ed12
« Reply #3 on: May 07, 2015, 09:17:39 pm »
his first problem is this
>I had a board battery replaced and it is working again<
what he means by board battery ? <  has me confused
backup battery chip >dallas-xx-xxxx fine
or the conplete control board ?
if  #1 he did not do a full p setup,thus getting that error
chrisf1 u will need to refer to the service manual section 3 start at pg 303 and read to 328
just about any cd-100 manual will do the job
if the full board then u will need to clear back-up ram >dallas chip< and or for the 12.00 replace it with a fresh 1
1 way is going to take u up to 2 hours of programming
the other way about 45 mins and some solder time.
but do as shawn sujest's and chk your connector's them title stip movers are a bugger
ed
p.s my med must be holding
chrisf1
« Reply #4 on: May 07, 2015, 10:13:56 pm »
I believe you are right back up battery chip anyway the box had been on my wall dormant for over a year anyway the fella who did that posted the board back to me which i installed and thought everything was fine then i noticed that the title movement button was not lighting up and i could not move the titles so rung the chap again who by this time was getting  quite pissed off and he said that a lead was off which I found and put on and then found that the cards will not move it makes all the noises  but is stuck and when i told him this he said the only way to do it is to remove all the cards to free them up which is great if you have a manual but i do not so can anyone talk me through what i know is not going to be a pleasant job thanks Chris
« Reply #5 on: May 08, 2015, 02:40:39 am »
http://arcarc.xmission.com/PDF_Jukebox/NSM/NSM_Grand_2_Technical_Manual.pdf
read PDF page 123 and 124
(manual page numbers 903 and 904)
it's not EXACTLY your machine, but the title page unit is the same. this explains the reload procedure. good luck, you'll need it.
chrisf1
« Reply #6 on: May 09, 2015, 01:25:43 pm »
Well i have removed all the display covers and stacked them in the order they came out so the box is now empty when using the shift button with it empty i am getting error 91 and 92 it appears to be working but i am not sure what and when should be moving can anyone make sense of what i am saying or offer any advice or failing that give me a number of someone who will come and fix it for pay thanks Chris
ed12
« Reply #7 on: May 09, 2015, 01:43:42 pm »
error 91= blocking title display while left movement
error 92= blocking title display while right movement
cure: blocking remedy
to me it sounds like a pad and or reversed plug from the opto's in the title controller
ed
chrisf1
« Reply #8 on: May 09, 2015, 02:06:48 pm »
when you say reversed plug do you mean the plug from the dispaly cabinet to the board that i had chip done on is on the wrong way i am not in front of it at present but i thought that could only go back one way
chrisf1
« Reply #9 on: May 09, 2015, 02:32:19 pm »
Hi again i have just found another plug that was not connected but looked like it obviously should have been so have connected that from display cabinet to board , should these errors come up if operating the shifter while  cabinet is empty if so I will have a go at putting them back as it now appears as if all is as it should be
ed12
« Reply #10 on: May 09, 2015, 04:28:41 pm »
if u are correct
straight with 1 on the left hand side and step it all the way through to 50 then let it carry on the right to carry on with it 51-00
it should clear your error
ed
chrisf1
« Reply #11 on: May 10, 2015, 08:46:16 am »
I was not correct nothing moved and if I cannot find anyone who i can pay to sort this i will scrap it, it is now much cheaper to do the music thing by computer it has just cost me £55.00 to have chip thing done the annoying thing is it is now playing but if i cannot select what i want to play what good is it, anyway if anyone wants to get paid for sorting this out i am in kent uk please contact me before i take a hammer to it and knock it off the wall thanks Chris
« Reply #12 on: May 12, 2015, 12:21:36 am »
yeah these things are a real bugger. when we were still running them, we had 2 spares on hand to swap them out with in case of a jam.
then we'd take it back to the shop and spend an hour or more getting it sorted and put back together.
leave it to the germans to over-engineer a product.
I have another instruction sheet someplace that outlines step by step the reloading of the pages. It was a technical bulletin put out by NSM. I'll try and dig it up tomorrow and scan it and post it here. it may explain a little more than the manual does.
chrisf1
« Reply #13 on: May 12, 2015, 01:55:09 am »
That would be great thanks as it is not staying on my wall if i cannot get the thing to work Chris
ed12
« Reply #14 on: May 12, 2015, 11:32:09 am »
there is a few other things u could do
"feild repair=1"
start at the very back of the title box (49) left hand side
place (2) titles in  so 48/49. hit right button so now u have 49/50 loaded
then repeat ^^^ until u get all 100 loaded,takes 45min's, :be-careful: of the worm gear's >feed<..
"feild repair=2"
replace drive board.opto board,these thing's fail in a very strange way
care must be taken to match the build # like 142-44-a will not work with 142-44-b
ed
chrisf1
« Reply #15 on: May 12, 2015, 12:19:34 pm »
well thanks everyone for your help but this has beat me i will ring round a few fruit machine companies in the morning to see if they have anyone who can repair it if not the scrap heap is looming
