Author Topic: To Jamma or not to Jamma  (Read 2242 times)
ark_ader
  • I glow in the dark.
« on: April 17, 2015, 11:13:01 pm »
Do I keep it or snip it to add my own wiring harness?
ark_ader
Re: To Jamma or not to Jamma
« Reply #1 on: April 19, 2015, 06:13:14 am »
Maybe I should be more clear.  I have a cabinet that I want to restore, but I am not going to replace the mainboard and just use Mame.  So instead of springing for the obvious Jpac (which I refuse to buy from Ultimarc) I am faced of adding my spare Xarcade controller board, the keywiz, or the use of two kades.
Do I use the existing Jamma harness or do I make my own and sell the existing one?
big10p
  • Mmmm, arcade classics!
« Reply #2 on: April 19, 2015, 06:19:46 am »
Why do you refuse to buy a JPAC? And how are you going to connect your monitor without one?
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #3 on: April 19, 2015, 08:23:16 am »
big10p is on the money. Why would you refuse to buy the obvious and best solution for your problem?
chopperthedog
  • Last login:Today at 02:57:59 pm
« Reply #4 on: April 19, 2015, 09:31:02 am »
Jamma fingerboard wired to your encoder.
good day.
ark_ader
« Reply #5 on: April 20, 2015, 04:45:35 am »
I decided not to buy any products from Andy due to the disgrace of poor business judgement, against a fledgling competitor.
I don't want to connect an arcade monitor as I will be using a LCD display.  I also want to add more buttons to the CP.  I didn't know if I should leave the cab wiring "as is" in case I sell it on or add an arcade display down the road.
Thank you Chopperthedog, a fingerboard would fit the bill perfectly.
Thanks for the replies.  :cheers:
  • Last login:Today at 08:02:29 pm
« Reply #6 on: April 20, 2015, 09:01:54 pm »
So apparently Andy is Big Arcade now or something like that?
Keep on ragin' against the machine, bro.
