Author Topic: An LED 4/8 way switchable joystick  (Read 1719 times)
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
« on: April 15, 2015, 02:12:35 pm »
Hey Guys,
Hoping you can shed some light - see what I did there - on a question I have.
I was checking out the Omni2 joysticks, which quickly change on the bottom from 4 to 8 way, but they don't have LED. Neither does the MagStick Plus, which I have in my bartop.
Is there an LED joystick that quickly changes from 4 to 8 way? Or maybe know of a way to modify the sticks above? Randy emailed me and said the Sanwa LED sticks may work, but I was wondering if any of you have done that with the Omni2.
Thanks for the advice!
I'm with stupid.
jeremymtc
  • Last login:Today at 12:29:19 am
Re: An LED 4/8 way switchable joystick
« Reply #1 on: April 17, 2015, 02:55:13 pm »
I have no knowledge of the Omnis myself, but did see that Paradise Arcade have hollow replacement shafts for lighting MagSticks/T-Sticks:  http://www.paradisearcadeshop.com/shafts/733-magstik-10mm-stainless-steel-hollow-joystick-shaft.html
mvolke1
« Reply #2 on: April 17, 2015, 04:59:18 pm »
Very cool! I could put a ball top on it, too.
How would I put an LED in there?
I'm with stupid.
roknrol
  • Last login:October 30, 2025, 03:51:17 pm
« Reply #3 on: April 17, 2015, 05:55:30 pm »
For some reason I thought I saw a post once where Randy was offering a hollow shaft with Electric Ice-type ball top for the Omni2 as a custom add-on. That way you could have a full control set (stick, buttons, and track ball) all matchy-matchy in Electric Ice. But maybe I was dreaming?  :dunno
jeremymtc
mvolke1
« Reply #5 on: April 17, 2015, 06:29:53 pm »
Viola
http://www.paradisearcadeshop.com/371-joystick-leds
You're good!  :applaud:
So I can just pop on a clear balltop and I'm good to go?
I'm with stupid.
jeremymtc
« Reply #6 on: April 17, 2015, 11:39:25 pm »
De nada.
You'll need a 10mm bushed balltop, but yeah. Paradise and most other vendors have those too.
mvolke1
« Reply #7 on: April 18, 2015, 01:04:57 am »
De nada.
I can't seem to find a bushed ball top, even on paradise.
I'm with stupid.
jeremymtc
« Reply #8 on: April 18, 2015, 02:30:40 am »
There are several 10mm threaded translucent tops on this page: http://www.paradisearcadeshop.com/670-paradise-
If you're going to use RGB LED, then there's this: http://www.paradisearcadeshop.com/paradise-arcade/560-hoku-38mm-ball-tops.html
