Author Topic: Jamma 412-in-1 cocktail problems  (Read 1603 times)
Terry St
  • Last login:February 01, 2016, 01:20:00 pm
« on: March 26, 2015, 11:21:30 pm »
I have just finished building a cocktail cabinet and installed the jamma 412-in-1 controller. I went over the directions and have quadruple checked all the details. But I am unable to load any games. Aslo when in the setup mode I can not do a system I/O check. The system just stays in the menu screen and never goes to the I/O screen. I am able to go through and do everything else in the menue system. When I try to load a game it scrambles the screen and then returns to the game list screen.
Any suggestionson what the issue could be? And pin 27 is not to ground.
behrmr
Re: Jamma 412-in-1 cocktail problems
« Reply #1 on: March 27, 2015, 12:59:55 pm »
Did you buy it new or used? Did you or the prior owner attempt to hack/mod the SD image?
Terry St
« Reply #2 on: March 27, 2015, 01:50:13 pm »
It is new. Purchased it as a kit with power supply, buttons, joystick and monitor.
behrmr
« Reply #3 on: March 27, 2015, 01:56:12 pm »
Try doing a factory reset in the system menu. If that doesn't work consider returning it.
BobA
  • What Me Worry?
« Reply #4 on: March 27, 2015, 03:58:43 pm »
The 60 in 1 jamma boards require a coin inserted before you can move around the selection menu.   You need a way to toggle the coin insert before it starts to work.
behrmr
« Reply #5 on: March 27, 2015, 06:52:00 pm »
Does not sound like a coin issue OP says a game starts to load and then goes back to menu.
Terry St
« Reply #6 on: March 30, 2015, 09:15:33 am »
Thanks for the input guys.
I found the problem. On player one side the prong on the B push button was bent up touching the other and causing it to be going to ground all the time.
