Author Topic: Old J-Pac Issues and Programming in DOS  (Read 1487 times)
lacanian
  • Last login:June 06, 2021, 06:59:26 am
  • Go FightCade!
    • forum.arcadecontrols.com/index.php/topic,143714.0.html
« on: March 12, 2015, 07:15:04 am »
Hi,
 I have an issue where P1SW2 and P2SW2 buttons don't work on my J-Pac. I have tested with a multimeter and get a signal even from the J-Pac fingers.
I contacted Andy and he told me "The very old type of J-PACs don’t have upgradeable firmware. Its possible (but unlikely) that these inputs have been de-programmed. You can check this if you have a PS/2 keyboard using this method: www.ultimarc.com/interact.html".
So I booted into FreeDOS with the PS2 keyboard I just purchased for this. Executed "copy con nulll" then pressed CTRL-ALT-P and a bunch of garbage (mostly @@@) shows up. I don't see any kind of menu. However I do try pressing "R" in hope I can reset the board back to default.
It appears it is locked in "T" test mode as I can push a button and see it displayed on screen.
Any help navigating this would be appreciated.
menace
Re: Old J-Pac Issues and Programming in DOS
« Reply #1 on: March 12, 2015, 01:52:57 pm »
This is going way back but once I had a JPAC with a fried chip and a bunch of keystrokes went missing--Andy sent me a new one and it was good as gold after--it might be too old for him to have those chips laying about though...
  • Last login:Today at 08:00:13 pm
« Reply #2 on: March 12, 2015, 02:50:55 pm »
If you've got one with surface mount chips, you're SOL.  If it's the socketed chips then maybe you can beg for replacements.
lacanian
  • Go FightCade!
CLOSED: Old J-Pac Issues and Programming in DOS
« Reply #3 on: March 12, 2015, 08:31:39 pm »
Out with the old and in with the new. I just ordered a new J-Pac.
« Reply #4 on: March 12, 2015, 08:40:29 pm »
Or just wire your buttons to alternative inputs??
 :dunno
lacanian
  • Go FightCade!
« Reply #5 on: March 12, 2015, 10:18:30 pm »
Yeah I considered that however I really need to program some shift keys.
« Reply #6 on: March 13, 2015, 07:47:58 am »
Not for mame you don't
