Author Topic: Powering LED's from IPAC  (Read 2352 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: March 07, 2015, 12:14:16 pm »
Hey there,
I have 4 LED Nova Gem coin lights that I want to light up in my cab. Everyone generally hacks into their computer power supply to get the juice to light up their LED's but can I power them through my IPAC?
Or maybe use a Groovy Game Gear Switching Power Supply?
Again it is just to light up 4 LED's, thats it. the Power Requirements are : 100ma @ 5v DC Per button.
Thanks for any help!
Kevin
Re: Powering LED's from IPAC
« Reply #1 on: March 07, 2015, 12:18:21 pm »
That's because it's the easiest, least complicated way to do it.  :cheers:
« Reply #2 on: March 08, 2015, 09:39:20 am »
Hey there,
Kevin
With 5v wall warts everywhere, it's way easier to put in a power supply just for the LED's. Not only that, but I've had to pull out my ipacs over the years to do maintenance (like wires that got loose, or adding a button, etc) and I'm glad I didn't have wires holding down some LED's. It really costs nothing to use an old wall charger from a old iphone or blackberry or whatever.
Good luck!
05SRT4
  • Check out my Pow Pow
« Reply #3 on: March 08, 2015, 06:36:50 pm »
Unless you have the Ultimate I/O I dont think you will be able to. with an ipac. Someone correct me if I am wrong.
Actually I just looked at the pics on their site and in the middle of the i-pac I see 2 prongs that have 5v next to them. Guessing thats 5v out? Maybe try there but I was unable to find any docs supporting the output.
So do you just not have a power supply, or are you not sure what wires or how to splice them in, or just dont want to touch the power supply?
lisowskikevin
« Reply #4 on: March 08, 2015, 07:07:10 pm »
Actually I was just looking for the easiest way to do it. I actually have a power supply I bought from groovy game gear and I also have a usb power tap cable from them as well.
I just wanted to avoid opening up the computer power supply. I'll prob just use my power supply.
Thanks for your help though!
Kevin
05SRT4
« Reply #5 on: March 08, 2015, 07:18:00 pm »
I dont remember needing to open anything. On my PC power supply I just snipped the Red and Black wires on the Molex  connector. Then just attached them to the daisy chains to the buttons.
« Reply #6 on: March 08, 2015, 09:16:49 pm »
What 05SRT4 said. You don't need to snip anything. Lew's suggestion is a good one, too.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #7 on: March 09, 2015, 03:05:05 pm »
400mA is actually quite high for drawing from a USB device, so it would be best to use a PC power supply molex as already mentioned.
lisowskikevin
« Reply #8 on: March 09, 2015, 03:33:50 pm »
ya that's the route I will definitely be going.
thanks everyone
