Author Topic: Splash in MALA (see the snap of the launched game)  (Read 6515 times)
empardopo
  • Last login:March 14, 2026, 06:46:29 pm
    • My personal forum
« on: March 03, 2015, 06:04:04 am »
Do you know the old HyperSplash in HyperSpin?
Now when you launch a game from MALA you will see the full screen snap before playing.
You can download splash from here.
The zip contains four files that you must put in your mame (emulator) dir. Those files are:
splash.exe
splash.ini
In MALA,
1.- You must put splash.exe like your exe emulator.
For mame, the command line will be
In splash.ini
[option]
Executable=mame.exe
PathSnap=C:\mame\snap\
SnapFullScreen=1
Executable is the name of your exe emulator. I've only tested it with mame but it must work fine with some emulator.
PathSnap is the path to your snaps ending with \
SnapFullScreen is equal to 1 to see the snap in fullscreen or 0 not.
Greetings.
« Last Edit: March 03, 2015, 06:06:19 am by empardopo »
arquillos
  • Last login:March 02, 2026, 07:31:26 am
Re: Splash in MALA (see the snap of the launched game)
« Reply #1 on: March 03, 2015, 09:34:29 am »
Nice idea!
Thanks Empardopo!
« Reply #2 on: March 03, 2015, 10:21:44 am »
Nice.  I can think of some other uses for this like displaying game controls or flyers.
empardopo
    • My personal forum
« Reply #3 on: March 04, 2015, 02:25:15 am »
You can use the path you want. The png files must be named with the same name of the selected rom.
Theoretically, the program should work well for any emulator.
In the last version of my AllInOneFYC program (1.055b) you can see a screenshot pressing the button that you have defined.
Greetings.
empardopo
    • My personal forum
New version Splash v0.3b
« Reply #4 on: March 05, 2015, 04:27:57 am »
New version here.
Now, the ini file is thus:
[option]
Executable=mame.exe
SnapFullScreen=1
Log=1
Log can only contain the values 0 or 1.
If Log=1 then Splash make a splash.log file with important information.
empardopo
    • My personal forum
« Reply #5 on: March 13, 2015, 02:57:24 am »
Soon, Splash is going to have a new feature. You can add customized text to see it in your window when you launch a game from MALA.
Greetings.
empardopo
    • My personal forum
« Reply #6 on: March 16, 2015, 02:12:57 pm »
empardopo
    • My personal forum
« Reply #7 on: July 02, 2015, 11:16:38 am »
Last version of Splash.
If you want to see text over the snap, you'll have to write a text file with the same name of rom (eg outrun.txt) with the next format.
[txt]
Title=A pasear a la rubia!!!
TitleX=260
TitleY=250
TitleW=590
TitleH=60
TitleFont=Tahoma
TitleFontSize=38
TitleFontColor=0xFF0000
TitleFontBold=bold
TitleTransparent=1
« Last Edit: July 02, 2015, 11:21:38 am by empardopo »
