Author Topic: Think I accidentally hit the the report to moderator.  (Read 21327 times)
Locke141
  • Never grow up.
« on: February 25, 2015, 09:15:39 am »
Your IP address is shown only to you and moderators. Remember that this information is not identifying, and that most IPs change periodically.
You cannot see other members' IP addresses, and they cannot see yours.
Close window
The above popped up in a window and I don't know why. Does this mean I hit the "report to moderator" If so it was in error.
Generic Eric
Re: Think I accidentally hit the the report to moderator.
« Reply #1 on: February 25, 2015, 09:24:32 am »
Close window
You hit the word logged, or maybe the icon next to it.
When you click report to moderator, it gives you a text window to explain why you think it should be moderated.
  • Last login:February 20, 2026, 09:07:40 am
« Reply #2 on: February 25, 2015, 10:17:11 am »
reported for reporting.
  • Last login:Yesterday at 01:27:04 am
« Reply #3 on: February 25, 2015, 10:27:14 am »
Snitches get stitches and wind up in ditches.
jdbailey1206
« Reply #4 on: February 25, 2015, 11:04:43 am »
...bitches.
« Reply #5 on: February 25, 2015, 11:06:45 am »
Snitches and talkers get stitches and walkers.
  • Last login:Yesterday at 08:30:37 am
« Reply #6 on: February 25, 2015, 11:14:10 am »
There may be some men in black suits show up at your door step very soon, I highly suggest you do not try to run.
BorgDog
« Reply #7 on: February 25, 2015, 11:15:40 am »
Drawn on my phone a couple years ago doing rhyming with the grandkids, seemed appropriate to the discussion  :cheers:
My Projects:
Locke141
  • Never grow up.
« Reply #8 on: February 25, 2015, 01:18:31 pm »
Thanks Generic Eric, I was unsure and just wanted to put it out there that if I did it was a mistake.
« Reply #9 on: February 26, 2015, 09:42:32 am »
You can also use the report link to suggest that a topic be moved to the correct forum as well.  Many users have used this option when they inadvertently started a topic in the wrong forum.
Reporting is not always negative.   ;D
D
